Question about Sony Playstation 3 (PS3) Console
PS3 Not Working
My PS3 turns on then the TV screen flashes and my controller starts blinking 4 lights. I also notice that the hard drive doesnt sound like it is turning and the PS3 is getting hot. Any ideas what it is? Is it an easy fix?
You using duplicate CD in PS3
Posted on Jun 17, 2009
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Ps3 controller is not connecting to console iv'e done tryed the reset button on the back of controller, connecting it to the USB an its still not working, im jus getting the 4 flashing lights
check your console and making sure those fans are not blocked off. If you notice a lot of dust on the console, clean it off right away. Once you fix the blinking red light of your ps3 and your console is working again, you will want to keep the vents clean and unobstructed.
better u download repair guide
click here to download repair guide
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
L try to turn on my ps3 and it does for one second then it only show a blinking red light
Hi, everyone knew that Xbox 360 had it famous 3 Red light of death but Sony Ps3 had it too. They called it as Red, Yellow, Green Light of Death. Although PS3 is the new generation of cutting edge high end technology console, it can still have problems like this common one where it flashes green lights instead of working properly.
It really annoying and frustrated if you face this problem and feel lost on where you actually can start to looking into it.Keep reading of this hub and share with you some basic troubleshooting tips that may help you to solve PS3 blinking problem and get your PS3 console work again.
You actually can start to look into the PS3 light flashing problem yourself, at least you can narrow down the error or can get your console work again on those fault alarm.
What you can do:
Tips 1 - Restart your PS3 console by turn it off and on it back. This to ensure a soft rest to your PS3 memory board. This can eliminate blinking problem that cause by in-proper shout down and memory interrupted.
Tips 2 - If tips 1 not working, try to check whether all the cable are well connected to the console with the power code. Make sure those cable in good shape, none of them are loose or damaged.
Tips 3 - If above tips not help, you need to unplug all those cables connect to your console and plug them back on. This way to ensure none of the cables are not connected.
Tips 4 - This could the final tips if none of above working. You need to take the hard drive out for 10 minutes and let it cycle its memory. Then re-hook it and try it again.
Above tips able help you to eliminate those common PS3 light flashing problem, but you may ask what else if those tips not work although you try all them out?
Take care.
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my xbox 360 controllers they blink a green light and won't do anything...whats the problem?
Everyone knew that Xbox 360 had it famous 3 Red light of death but Sony Ps3 had it too. They called it as Red, Yellow, Green Light of Death. Although PS3 is the new generation of cutting edge high end technology console, it can still have problems like this common one where it flashes green lights instead of working properly.
What you can do:
Aug 20, 2010 | Microsoft Xbox 360 Console
No sound, now the conrtoller doesnt connect
You gotta hook the controller back to the system via the usb cord and then press the PS button. Finish the format.
Let me know if you still have problems afterwards.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
Playstation3 startup problems
contact sony at 1800-345-7669 then can repair it for you your memory chip could be fried and that is where menu screen data is located
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Powers on, Controller wont connect, nothing shows up
switch the hard switch off in the back of the ps3. unplug power cord... press and hold power button located on the front f the ps3 for approx 10 secs, then let it sit for a few, then hook it back up and turn the hard switch back on and try to power it back up.
I have had this happen once before but it did return to normal.
Nov 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 problem, ps3 doesnt turn on (stays in red light flashing)
Sounds like a heat sync problem. you will more that likely need to re-seat the GPU and CPU as well. email dwdpcrepair@gmail.com for more assistance
Jul 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
148 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
