Question about Inverter Welding Tools
Hitachi 200 gp2 tig welding set will only output is hf and no welding current.No current on the stick welding setting also
  • 2712 Answers
SOURCE: How to TIG Weld
TIG stands for Tungsten Inert Gas welding. Also called GTAW (Gas Tungsten Arc Welding) and HeliarcĀ® which was Linde's trade name for the TIG process when it was introduced many years ago. The arc is started with a tungsten electrode shielded by inert gas and filler rod is fed into the weld puddle separately. A slower process than MIG, it produces a more precise weld and can be used at lower amperages for thinner metal and can be used on exotic metals. TIG does require quite a bit more time than MIG to learn. It is similar in technique to gas welding.
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Posted on Dec 28, 2008
CarlGehrke
  • 169 Answers
SOURCE: miller syncrowave 200 makes buzzing noise from spark gaps.
Odd noises other than the normal sound of the spark gap working are often the result of dust and junk inside the case of your welder. That it also bogs down when it gets warmed up (fan comes on), also points to a need for some "annual maintenance" stuff being done.
Completely isolate the machine from the building power supply, pul the plug, open the circuit breaker, do whatever it is that makes the machine have no connection to any power.
Take off the covers with a 10mm or 3/8 inch socket (can't remember which)
Use a shop vac to **** out all of the dust and debris out of the machine. Low pressure (40 psi) air can sometimes be helpful to dislodge caked on dirt. Avoid any metal tools near the capacitor bank inside the welder.
Wipe off the fan blades.
Clean the spark gap electrodes by inserting and removing a matchbook cover, a business card, or a piece of white cardboard several times. Inspect the electrodes and adjust them according to the manual that came with the welder.
Check all of the power wiring connections for tightness by gently tugging on them. Look for signs of overheating on the power connections and on the internal connections to the welding terminals. Check the range switch for heating too.
With the cover still off, reconnect the power and turn the welder on. Look for obviously vibrating laminations on the main input transformer. If you see one buzzing back and forth, or if you notice lots of wear and tear on the varnish coating of the laminations, shut everything down and repair the loose laminations with some anti-fungal high voltage varnish.
Turn the welder off, disconnect the power, and put it all back together. Then turn the power back on and weld something, if htere is still a buzzing noise you'll need a Miller tech to solve the problem, you likely have a bad input transfirmer.
Regards,
Carl
Posted on Jan 26, 2009
  • 3 Answers
SOURCE: TIG 250/250
have you checked your regulator if its gone you wont get gas
Posted on Jun 02, 2009
stlthbmr
  • 6 Answers
SOURCE: linde welding machine when welding in tig mode
Check to see if the remote switch has been set, or if you have broken wire in your pedal lead. You might even want to open the pedal housing and take a look see. I've had more than my fair share that the contacts inside the pedal housing were worn or cooked. Good luck, hope it helps
Posted on Nov 15, 2009
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
I am getting holes appearing when I stop welding. There is nothing wrong with the gas (pressure/post/preflow checked) as i have checked it all out. I have put a new torch on and a new regulator but it has...
Wow what a great machine. You have so many options that you should be able to control the ending arc. Yes, you should be able to adjust the intensity of the HF. Also if you use the Sequencer Control, you should be able to finish the weld in a slope manner. I am including the owners manual. Operation starts on page 38. Miller has a team of welding engineer that will be able to help you set up your machine. Wish I had one.
Oct 04, 2017 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
I have a miller microwave 200. what settings should i use for aluminum welding? dcep, ac, dcen? i'm using a3/32'' tungsten and trying to weld on 1/4'' alum plate. the weld is not turning out to be a smooth...
I think you mean you have a Miller Synchrowave 200.
Typically, you would want to use AC below about 250 amps. In this case (to keep it simple), use AC, adjust your balance to about 4, use an 1/8" pure tungsten, pure argon at about 20CFh, and set the panel at 170amps to get things started. For general purpose, use 4043 filler.
Now - these are just generic settings, but they will get you going.
Jan 12, 2010 | ARC Welding Secrets Book - Mig/tig/oxy/arc...
I'VE GOT HI FREQ BUT NO ARC. SMILEY TOOLS MTC 160. PLASMA, STICK AND DC TIG MACHINE. I DON'T HAVE A MANUAL OR ANY INFO. THANKS
Its probably the torch. Turn off the hf , with the machine triggered Measure the open circuit voltage from the positive o/p socket to the negative with a multimeter set on d.c . The correct no load output voltage for the machine will be shown on the spec plate as Uo = ........and whatever the voltage is. If you get the correct voltage try another torch or try stick welding.
Sep 30, 2009 | Welding Tools
Welding Tools Logo
421 people viewed this question
Top Inverter Welding Tools Experts
Robert Lee
Level 1 Expert
Tom Chichester
Bud H
Are you an Inverter Welding Tool Expert? Answer questions, earn points and help others
