Question about Walter Drake Garden Groom
I am trying to replace 30cm cutting blade on a Garden Groom maxi GG01. However the pozidrive heads are worn down. There is access to the nuts on the other side of the blade but extremely difficult to get at, has anybody else managed to negotiate this problem? Stephen J Johnson, Mirfield, W. Yorks
Cant get blades to full RPM replaced all idlers all belts greased spindles new elec. clutch new blades when cutting grass it leave rows of uncut grass
if the blades wont get up to speed or not cutting grass you have a belt that is slipping. could be the pulley is damaged or just a worn out belt. if it is leaving a strip of uncut grass you have a blade that is wore down on the ends not cutting the full path
Aug 05, 2017 | Garden
What drive belts fit the garden groom mini and pro?
Sorry we have no way to look this up.
Jun 23, 2016 | Garden
How do I fix a loose blade.
By loose blade I assume you mean that it can be moved up and down at the tip of the blade. It is most unlikely that the central nut has come loose, but check anyway. If this nut is tight and the shaft is loose in the bearing this means the bearing has worn out. Remove the deck from the machine. Photograph the run of the belt as this has to be removed. Also the direction of the grease nipple. Remove pulley from loose spindle. Turn deck on its edge or mount on two saw horses or similar so you can get to top and bottom of spindle bolts. Remove cutting blade. Remove spindle housing and clean area so no rubbish gets caught when reassembling. Otherwise spindle may be set different and mower will leave a line of differing cut. Take spindle to vise and remove any retaining nuts or circlips from shaft and clean as clean as new. Apply light oil or CRC etc to help move bearing along shaft. Open vise wider that outside of bearing, usually 44 to 50mm [1 3/4" to 2"] and refit nut on thread. Check nut is always spaced free of top bearing. With cushion of hardwood or nylon tap the shaft to move it down with lower bearing coming out of spindle housing. To remove top bearing from housing, turn housing up other way and use a wooden shaft such as a broom handle to tap bearing free of housing. Clean out grease and replace when reassembling. Do not reuse other bearing. They are cheap and likely to fail shortly anyway. These bearings usually have no seals on inside.
Sep 27, 2014 | Garden
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman edger model 358.796480 blade not cutting. Am I doing something wrong? Seems like looks OK but still not cutting.
Assuming the obvious that the motor is turning, the only thing that would keep it from cutting is that the nut holding the blade is not tight enough or the sping washer between the nut and the blade is missing or on backwards. The correct orientation of the spring washer is so the inside surface around the hole contacts the nut, and the outside circumfrance of the washer contacts the blade. P.S. the nut is tightened very tight.
May 18, 2014 | Garden
Husqvarna un even cut
Replace the blades sounds like the ends are worn down or your blades are bent then you would see a difference in hight of cut.
Apr 09, 2012 | Husqvarna Garden
Hi I bought Oster golden A5 clippers from ebay and I am not sure if they are fixable. I tried to use them to groom my dog and the blades wont cut the only solution was to tape the blade flush to the unit,...
it's seem that your clipper blade are out of adjustment and also dull, The Lever from what you stated your Lever is worn out also. The only way I can help is to send your clipper and blades to us so we can make all the necessary adjustment, replace the worn out part and sharpen your clipper blades.
I don't know how many blade you have, but we can work some thing out to help you solve your problem. You can e-mail at ask@mannyssharpening.com
We have been in sharpening business since 1990 You can check out my rating on Yahoo.com Manny's Sharpening
Mar 22, 2011 | Oster Golden A5 2-Speed Universal Motor...
My Swisher Rough Cut 12.5 HP 44 Inch mower - The blades stop cutting when I hit a dense patch of grass. The belt and the pully are still moving at normal speed but the blade slows. Also I can spin the...
I dont believe there is a shear pin on your blade spindles, what I have found on these machines is the the spindle nuts on the balde spindles sometimes loosen or wear and no longer squeeze the pulley on the blade spindle. To make this process easy on your self you need to tighten these with a impact wrench. However if you dont have access to a impact wrench you can use hand tools and block the blades you are trying to tighten with a wooden block. Just make sure you block the blade you are trying to tighten
Aug 13, 2009 | Swisher 44-Inch 12.5 HP Trailcutter...
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
Walter Drake Garden Groom Logo
63 people viewed this question
Top Walter Drake Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Walter Drake Garden Expert? Answer questions, earn points and help others
