Question about Transparent Easy Translator 4 Deluxe for PC
Easy Translator 4 de-luxe.
Above installed OK in Windows XP but will not install in Windows Vista. Says that "unknown error has occurred". Can you solve please
    Genius:
  • 1,341 Answers
You need to check compatibility issues before you install on vista.
Posted on Jun 17, 2009
Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Jun 29, 2010 | Computers & Internet
Tip
How to Install any Driver/Software which isn't Supported by Windows Vista/7
Hello!!
There are lots of old Soft-wares and Drivers available which are not compatible with Higher Version of Windwos.
So some Windows XP exclusive setups can be installed under Windows Vista/7 As Under.
1. Try to install the drivers in compatibility mode.
2. For that right click on setup.
3. Go to properties.
4. Go to compatibility Tab.
5. Set it to win xp sp2.
6. Hit ok
7. Run setup as administrator
8. Ignore any error and hit continue anyway during installation
9. Restart pc
If the above trick doesn't work, then use the device in VIRTUAL XP MACHINE
You can use XP MODE or VMWARE or any other Virtal Machine Application.
Hope it Helps..!!
on Jul 13, 2011 | Computers & Internet
Error 101 (net::ERR_CONNECTION_RESET): Unknown error.
These errors occur when the Google Chrome installer is unable to create a temporary directory on your computer during the installation process.
Solution Check the permission for your temporary folder.
  1. Go to the Start menu > Run.
  2. Enter one of the following directories in the text field:
    • Windows XP: %USERPROFILE%\Local Settings
    • Windows Vista: %USERPROFILE%\AppData\Local
  3. Click OK.
  4. In the window that opens, right-click the Temp folder.
  5. Select Properties.
  6. Click the Security tab.
  7. In the "Group or user names" section, select your user profile name.
  8. In the permissions section, verify that the checkboxes for "Read," "Write," and "Read & Execute" permissions in the "Deny" column are not selected.
  9. Click Apply.
  10. Click OK.
Try installing the browser again
Jun 01, 2010 | Google Chrome
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
A unknown error has occured. The application will close when you click OK
When poeple create software, they test it in order to discover programming errors, and all sorts of unusual conditions that may make the software misbehave. For every error found they design a customized message to let you the user know what happened and what you can do to salvage your work.
Error conditions may also be created by the user and the input he/she gave the software. In the testing phase, the testers try to think of all possible data (good and garbage) that the user may enter and design a message if the input leads to a software misbehavior.
But programmers and testers are not omnicient and sometimes they miss errors conditions. For all these, there is message telling you that an unknown error happened.
You may reduce the number of such occurences by familiarizing yourself with the software and its use.
Hope it helps.
Nov 21, 2009 | Transparent Easy Translator 4 Deluxe for...
Scanner says sorry an unknown error occured The scanner seems to reconize it is connected to the computer, but it will not complete the scan
You don´t give enough information in order to allow us to help you (How are you trying to scan? What exactly happens? What OS is installed in your computer? Which software/driver did you install? Does your printer otherwise works?)
Start by reading these HP FAQs to see if you can solve the problem (2 are meant for Vista systems and one for XP). Post again if you still can't scan.
Sep 02, 2009 | HP Photosmart C4280 All-in-One InkJet...
Hpqgpcol.exe error
I would bet from the error the driver is not setup to run on 64 bit VISTA, or there is a Driver from Microsoft for this printer (Which I could not find), or one of VISTA' windows updates has caused this error.
My Solution is to uninstall it becauseit is not designed to work with VISTA 64.
Aug 21, 2009 | Office Equipment & Supplies
A disk read error occurred saying Press Ctrl+Alt+Del to restart
i would like to share few things to u.
1.you can see the vista drives in federa but can't see federa drives on vista.
2. 2ndly if u have burned any thing in the xp cd even a 1 kb file then the bootable disk will get corrupted and from next time u can not use that disk to install xp.
borrow from ur friend and try again keeping above things in mind.
one more thing if u want to use that 20gb then either u have to delete that partion from boot prompt only or u can also do it by partition magic only.
Jun 13, 2009 | Compaq Presario 700 470024-192 Notebook
C4400 printer will not install, error 1935 fatal error alert.
Hi Swreardon,
How are you doing?
The issue which you have posted will generally occur if there is a WinTools Easy Installer program on your computer or even it occurs due to corrupted registry.
I can provide you the complete solution but for your clear understanding of the solution and to have a clear view of the solution so that you can easily perform the troubleshooting let me provide you with the weblink which ahs clear instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00292756&cc=us&lc=en&dlc=en
Before using above weblink make sure you perform the steps below :
Step 1: Insert the HP printer software CD in the CD drive and folllow the steps:
If operating system is XP, Start>>run>> type" X:/util/ccc/uninstall_L3.exe and click OK. (where X is the Cd drive ) and follow the onscreen instructions.
If the operating system is Vista: open run window and type: " X:/util/ccc/uninstall_L3.exe" and click OK. (where X is the Cd drive ) and follow the onscreen instructions.
Here are the multiple steps to open run window in vista:
1. Press Windows Key + R to open the Run command window.
1. Open the Start Menu.
2. Click All Programs.
3. Click Accessories.
4. Run shortcut is located here by default.
Step 2: restart the computer and follow the steps given in the weblink above:
Step 3: once everything is completed download nad install the software by clicking on the weblink below:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3655574 (For XP)
and use this link for Vista: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-57266-3&lc=en&dlc=en&cc=us&os=2093&product=3655574
Do not use the CD.
I am sure the issue will be resolved.
Best of luck.
Oct 25, 2008 | HP Office Equipment & Supplies
Transparent Easy Translator 4 Deluxe for PC Logo
279 people viewed this question
Top Transparent Computers & Internet Experts
k24674
Rose li
Rose li
Are you a Transparent Computer and Internet Expert? Answer questions, earn points and help others
