Question about HP Photosmart 3310 Printer
3310 is disconnected
All of a sudden, the printer will not communicate with my PC (Dell Dimension DIM4550 running Windows XP).  I have spent 6 hours in "chat" with HP Helpdesk--6 separate sessions and I get the same responses every time.  I have uninstalled/reinstalled the All-In-One software multiple times, uninstalled USB ports, updated USB drivers, tried using a different USB port, tried using a different USB cable, all to no avail.  The USB port shows nothing when I hook up the other end of the cable to the 3310.  I can use the same cable with the same computer port and hook up to another USB device and it is immediately detected.  The 3310 itself also reports that it is not connected "to a network" when I attempt to use the Help button.
I'm beginning to suspect that the USB port in the 3310 has "gone bad"-- is this possible?  Is there a way to diagnose it?
FAX and copy work.  off-line printing works.
I do not have convenient access to another computer to see if the 3310 will work with another computer.
The 3310 was purchased in December 2005.
Thanks very much
  • photomaker Nov 02, 2007
    Thanks, Soulvisitor. You have provided additional insights, but I'm not sure we have a fix. One thing you mentioned was a remote possibility of loss of serial number; when I print a self-test diagnostic page, it includes the correct serial number. Is the main PCB what is being tested in the self-test?
    As far as drivers/software, I think I've tried every possible combination of adding updates, uninstalling and reinstalling, refreshing and updating USB devices, etc. A question is: if the USB port on the computer or hub works correctly with other devices (e.g. an external DVD drive), why would it need a new driver to talk to the 3310? Is the 3310 that special? I've also done several System Restores back to dates when I know for sure that the printer was connected (because I printed a file from the computer)--all of course to no avail.
    I will probably borrow someone's laptop and try connecting the printer just to confirm that it's really a problem with the printer and not my computer. Assuming that it is, how would I go about replacing the PCB? I checked the parts that HP sells and it seems like all they sell for this unit are consumables--do they just expect people to throw out a printer when a hardware component fails? Would I be able to buy a replacement at someplace like Fry's or CompUSA?
  • HP Master
  • 1,113 Answers
Lets put it this way, if you have a port problem on the usb, the fix would be replace P.C.B. that runs it, and connector if it looked suspect. This would be unecomical to repair.
A new inkjet  printer with new ink and a year warranty without any possible problem is the hassle free fix most economical fix.
Or you can fight with the possibility of driver issue (just dont count the hours), please check that in control panel / devices that your printer has not installed itself as another device, to do this look for any device marked with a ?, if you find one delete it! (that would allow it to identify when connected/disconnected)
You may have done thatr so disregard if you have
(twas a Stab in dark, installing as another device not even listed under or as a printer has got me a few times )
Yes the port stuffing up is possible but rare. no real check either it does or dont I have consisered it a few times when setting up various machines, but I usally prove myself wrong when I descover my driver/usb signiture problem (it can be very trying at times and I do it everyday).
 I have seen USB ports not work when printers lose serial number info on main p.c.b. and I have had a couple of broken/loose sockets, I see network port/cards fail moreso than USB but really all these cases are so rare compaired to it turning out to be driver/software related
Posted on Nov 01, 2007
  • Soulvisitor
    Soulvisitor Nov 02, 2007
    Hi HP do not carry many parts for HP small inkjets, If they break under warranty they replace them, even if you did get a board it would cost more than the printer sells for and still you would not if it would fix.
    Every printer needs it's own unique printer driver, even if I have two of one model machine and set one up, one cant just plug the other in and expect it to work it would need it own usb port id.
    On my laptop I might have 4 USB sockets but I have 50 usb ports set up to 50 diff printers. If I unplug a usb printer and plug in one that has not been given a unique identifier to my laptop it will not work on any of them untill windows labels a port for it.
    then evertime it is pluged in windows know what it is and what it can do, like I've said sometimes windows will alocate it not as a printer but as another device and do so everytime it sees it
    One must have printer makers correct driver to suit correct windows version to enable a connection.
    Restore will not put drivers as they were once changed nor usb ports.
    Confusing I know.
    New inkjets are cheaper than a set of inks these days, they want you to have a printer so you buy the ink, thats were the $$$ is.
    Repairing inkjets is seldom done out of warranty, I'm too expensive as are parts, I cant fix a printer cheaper than it is to replace. Modern world get used to it
    If machine has any fault that it knows about, it will not go to online status, nor test print.
I have a dell 5100 dimension desktop with ntldr issue. Have spent hours and hours on it but can't resole the issue
this is usually caused due to a corrupt MBR or boot code, if you have an install disc for I presume xp you can repair it with that, if you need further help, let me know and ill give you instruction
Nov 15, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Dell 942 all in one printet wont communicate to dell dimension pc
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
good luck. :)
Aug 30, 2009 | Dell 942 All-In-One InkJet Printer
Canon MF 4350d Wont install
Almost the exact same problem. New 4350d Canon printer trying to connect it with Dell 8300 with XP. The computer says it does not recognize. Tried everything - reinstall drivers, download drivers, tried every USB port, swapped cables, spoke with Canon support and finally took the printer back and got a new one (Canon support person decided the USB board must be bad). New machine - same old problem.
Feb 10, 2009 | Office Equipment & Supplies
Primary hard drive not found
since you already tried removing and reseating the hdds . The problem could be the motherbaord slot. To troubleshoot the same
1. First Disconnect all hardrives and optical drives from the system
2. Go to the system setup or BIOS
  1. Turn on (or restart) your computer.
  2. When the blue DELL™ logo appears, press <F2> immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again.
3. Hold down the ALT key and press "F"
4. Hit ESC , save changes and exit .
5. SHutdown the system
6. Reconnect the HDD IDE cable to the optical drive connector on the motherboard.
You can refer to the following motherboard diagram
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101668
7. Check if the hdd , is getting detected in the system setup
You can refer to the following link on how to read system setup screen
http://support.dell.com/support/edocs/systems/dim4550/syssetup.htm
Thanks
Proton
Jan 30, 2009 | Dell Dimension 4550 P4 Socket 478B...
Wireless communication to printer from pc is lost
You may be having an issue with an usb hub try connecting it to another usb port. If this is a notebook and you are connecting it through a port replicator disconnecting the notebook from the replicator can cause you to loose connection to the printers.
Jan 14, 2009 | Dell Dimension 8200 PC Desktop
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
HP 3310 ink cartridge not recognised
My HP 3310 wil not print black. The color prints fine. Spent 2 hours on the phone with HP support only to be told to buy a new printer. The machine is less than 2 years old. There must be a way to repair this. Any ideas? Barbara
Nov 08, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
93 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
