Question about Palm Treo 650 Handheld
Treo 650 not enough power to activate the phone
I have problem with my treo 650 it can turn to mode to use. when i try to turn out it give this error treo 650 not enough power to activate the phone.
  • 11 Answers
SOURCE: treo 650 won't turn on
Could be a dodgy power connection this seems to be happening a lot at the momentif you look at other threads here.
Kevan
Posted on Nov 18, 2007
  • 537 Answers
SOURCE: Receiving MMS on Treo 650
This device should be compatible with MMS.
I found this thread which might help you set up MMS on your Treo 650. Look at the 2nd entry:
1. Start, Settings, Connections, and then tap the Connections Icon
2. Under "My Work Network" tap Add a New Modem Connection
3. Name it Picture Messaging and under Select a modem select (GPRS,3G)
4. Under Access Point Name type: wap.voicestream.com
5. Username, Password, and Domain is left blank and then click Finish
6. Now, go into Proxy Settings and check "This network connects to the Internet" and check "This network uses a proxy server to connect to the internet"
7. Under the Proxy Server box type: 216.155.165.050
8. Tap the advanced button and tap on the HTTP line. Make sure the HTTP settings shows 216.155.165.050:8080. If not, change it.
9. Click the OK button a few times to get out of the settings completely.
10.Now go to Start, Messaging, Menu, then Options, Advance, then Click Manual, and then the Edit button
11. Message center number +12063130004
12. Email center number is 500
13. MMS gateway address is 216.155.165.050:8080
14. MMS URL is http://216.155.174.84/servlets/mms
15. Finally under Network Profile select: My Work Network and then click ok.
Posted on Dec 13, 2007
SOURCE: TREO 650 Phone won't work
I was having the same problem and finally got it working by starting to do a hard reset, then selecting 'No' when prompted to erase all data. See PalmSupport for details. I then installed the software upgrade for good measure. (Treo 755p)
Posted on Jun 04, 2008
SOURCE: Palm Treo 650 Unlock Code.
do u have a unlock code for your treo 650?can u share me a code so that i can unlock my treo 650 here is my messenger and email account respetadong_pogi@yahoo.com i hope you can help me too.
Posted on Aug 16, 2008
  • 23 Answers
SOURCE: treo 650 phones turns off by itself
funny thing... the older palm treos like this one have some glitches. these glitches can normally be fixed by changing some of the settings.
1) go to your home screen, and select PREFS
2)select power
3) set your brightness level all the way to the right (NOTE: it takes more power to dim the screen then it does to brighten the screen.)
4) set auto off after: to the highest number allowed
please let me know if this helps!
Posted on Jan 26, 2009
Not enough power to activate your phone. What i do please?
Connect to the charger and than try to turn on, it should start charging and turn on.
Jan 25, 2011 | Palm Treo 650 Handheld
Treo 650 suddenly went to a palmone boot up screen then to a palmone powered screen and just keeps repeating without fully going to the normal screen mode for the phone.
When the first screen flashes, as the bar is loading, hold up. Let go once the bar finishes. If that doesn't work you may need to hard reset. Just google how to give it a hard reset and remember that you will lose everything that isn't backed up if you do.
Feb 12, 2010 | Palm Treo 650 Smartphone
Treo 650 reset itself and the phone app seems to
plz re-install da cell phone software...the old one is damaged badly
Nov 14, 2009 | Palm Treo 650 Handheld
Restarting of phone mode
You probably have a loose SIM tray. I had a loose tray and it would just shutdown if the phone go sat down or held.
Apr 07, 2009 | Palm Treo 650 Handheld
Treo 650 phones turns off by itself
2)select power
Nov 25, 2008 | Palm Treo 650 Handheld
Palm Treo 650
Ihave a PALM TREO butIT IS not a phone and I had the same thing happen to me.
What worked for me was # 2
If you have not tried it yet try this!
1). Press the reset set button on the back of the Palm.
2)This is a little bit more memory destructive and you might want to back up you data cause it will wipe out everything!
hold down the power key and press the reset button!
May 26, 2008 | Palm Treo 650 Handheld
Memory data error
Try a soft reset the next time you get the error.
If that fails, try getting a freeware called "Destaller". Programs like yours may leave a "footprint" of old data (sort of like Web cookies) that may be cluttering your unit. This small program allows deletion of these files if that's the problem here.
I get a similar problem with TomTom Navigator 6. Soft reset usually fixes it.
May 13, 2008 | Palm Treo 650 Handheld
"not enough power to activate wireless mode" problem for treo 600
call to your wireless provider and they will help you turn it on
Apr 03, 2008 | Palm Treo 600 Handheld
Resetting to Power Off
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
cropp
Mar 07, 2008 | Palm Treo 650 Handheld
Palm treo 650
The 650 seems to have a delicate headphone/mic jack. Dropping the phone, even gently, seems mess up that jack. I returned my first treo 650 as defective, and got a new one. The same thing happened to my new 650 after I simply compressed the phone in my breast coat pocket by holding my mail against my chest.
I can't get a new one because the replacement treo comes with no warranty of any kind. :(
My advice would be to find a PDA/phone repair service to repair the jack or diagnose the problem if it turns out not to be the jack.
Jan 12, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
175 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
