Sharp tv TURN TV ON,ROUND COLOUR CIRCLES STAY ON ALL THE TIME,EVEN ON AV,CAN YOU TELL ME IF THE TV IS WORTH FIXING.THANK YOU
    Problem Solver:
  • 13 Answers
First chanage your tv direction if not work than
Use external degaussing coil to remove magnetic fields shows on screen.
Posted on Jun 17, 2009
I have a sharp lc30hv6u LCD flat screen TV I'm trying to only watch TV what cable do I need and what is the difference between inputs 1 2 & 3 thank you
You need to re-thnk how this tv works. The AVS system box that came with the TV which is at the bottom of your picture controls the inputs. So a TV antenna goes into the ANT-A in the top left corner of the back of the AVS system box. The AVS cable has to connect the TV to the AVS system. So the inputs 1 2 3 have to be all connected . I assume to watch TV you need to somehow tell the AVS system to switch the AVS to TV.
I have seen a similar system with an after market sound and video processor that switches the audio and video to the tv from many different sources.
Mar 13, 2017 | Sharp Televison & Video
How do degaussing tv
There is a built in deguassing that you hear every time you turn on the tv. But to fix colour issues you need a hand held deguasser where you energize it and circle the whole picture tube from the front and then slowly back away while still making a wide circle.
Dec 01, 2013 | Televison & Video
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
BMW 1999 mdl 323i, yellow light on in dash. round circle with 3 lines on each side. can you please tell me how to remove this warning light. thank you joe
A ROUND YELLOW CIRCLE LIGHT WITH LINES ON EACH SIDE MEANS BRAKE PROBLEMS FRONT BRAKES OR REAR BRAKES HAS A FAULT. NOW IF CIRCLE HAS LINES INSIDE YOUR POWER STEERING FLUID LOW NEED CHECKING.THE WARNING LIGHT WILL TURN OFF WHEN PROBLEM FIX.
Jan 24, 2011 | 1999 BMW 323 Series
Manual for samsung es65 camera I would like to view my pictures on my samsung TV I was told I could do this direct from the camera to the TV just by using the a/v cable Is this correct and if so what ports...
You can download a user manual from here:-
http://downloadcenter.samsung.com/content/UM/201002/20100202195655453/ES65_ES67_English.pdf
You should have a AV cable with the camera, that has 1 round plug at one end and 3 round plugs at the other.
The single end plugs into your camera, there is a socket on the side marked AV. The three plugs at the other end go intot the TV.
They are colour coded (White - audio left, Yellow - Video and Red - Audio right) you need to find three sockets on your TV which match. Once connected and a slide show running on your camera, select one of the AV tv channels on your tv remote control.
If there isn't the 3 colour coded sockets on your TV, there probably is a couple of SCART connectors on the back (Big black socket with about 20 holes) You can buy adaptors, from electrical stores, which convert your AV cable out to a scart. Its just a box with the 3 coloured inputs and a scart output.
Jul 03, 2010 | Samsung Cameras
Have plugged in digital terrestrial receiver to tv and colour is a pinky red colour. Tv colour ok when digital box switched off
Check the scart connections are in tight (if that's what you are using). You may also want to try another cable. Also, make sure you have the correct input selected on your TV; the button on your remote should be either a circle or square with an arrow through it and possibly labelled source or AV.
Regards
Zahc
Jun 14, 2010 | Televison & Video
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
SHARP LC-32SB24U. AV MODE KEEPS GOING BACK TO DYNAMIC FIXED .
I have the same tv and i just fixed it! mine was a display model at wal mart so it was set to reset to Dynamix (fixed) after 30 minutes of no remote activity
THE FIX: switch to TV MODE and select the EZ SETUP from the option menu
when you get to the TV LOCATION option select HOME
The STORE option resets the TV after 30 mins of remote control inactivity in case someone messes up the picture settings in case someone playing with it while it was on display at the store
Jan 18, 2009 | Televison & Video
JVC AV-32870 Power button is missing
I had a friend that had the exact same problem! We did use a remote to turn the tv on and then it was a matter of setting up the menu settings. It was trial and error, but it was worth it. As far as getting the power button replaced, I would recommend call and ask a TV repair person - but the remote worked just fine for my friend.
Jan 06, 2009 | JVC AV-32820 32" TV
Weird colors on my tv
If it is a tubed TV the spot suppressor is no longer working.
Mar 07, 2017 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
