Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Lc-32pd5x its a roof mount antenna not sure what brand it works fine on my other lcd
  • Sharp Master
  • 13,433 Answers
So you could not wait 1 minute while I wrote to you how to reset it?
by default from factory the pin code is 1234
heres the full user manual for your tv
http://www.cleverhome.com.au/user/Sharp-Aquos-Piano-Black-LC37PD5X-LC32PD5X-manual.pdf
if the code doesn't work heres how to reset the tv
HOW TO SET THE FACTORY PRESETS
Turn off the TV by pressing POWER on the TV.
After waiting for about 1 minute, press and hold down RESET and press POWER on the TV to turn on the
TV.
All setting items (except TV channel) return to the factory presetting.
note Password will be cleared after running the factory presetting operation.
You can run the Auto Installation again by using the following steps.
1 Turn on the power of the TV.
2 Press MENU. (Make sure the menu screen displays.)
3 Press left or right to select “Setup”.
4 Press up or down to select “Auto Installation”, and then press ENTER.
5 Press left or right to select “Yes”, and then press ENTER.
Posted on Jun 17, 2009
My sharp tv lc-20b9u-sm there is a dark circle on screen when there is picture or antenna off
Can you include a picture of the screen here; Johson? If so, it will be more helpful to provide a solution to this problem. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Screen-shots to defective LCD are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Jun 26, 2014 | Universal Premium Wall Mount For Model...
Cb antenna warning
If your readings are below 0.5 with a dipole that is a excellent swr reading, most fall in the area of 2.0 or higher, you will not harm your RF output transistor, if you are getting antenna warnings see if you can recalibrate it.
May 04, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
When explaining that an antenna needs to be 'gounded', does this mean that the bracket the antenna is attatched to needs to be actually hard wired to the vehicle frame or when using a magnetic mount...
Hi, my name is John. Welcome to FixYa. Yes, That is not sufficient enough for your antenna. Need any further information let me know. Thanks for choosing FixYa...John
Nov 23, 2010 | Cobra 29 LTD CB Radio
I have a pickup with a fiberglass bed cover, inside is a Cobra 29. When the k40 antenna is on the bedcover (magnetic mount w/ 6x6 inch metal plate glued to the bedcover) radio will give me an antenna...
Well, the k40 is designed for roof or trunk mount,you would not be getting a good ground,plus you would be getting feed back from cab,no good transmit or receive. Get a good 102" fiberglass or steel whip that's bumper mount,mount it on right rear bumper and you will be good to go.
Mar 28, 2010 | Radio Communications
Antenna for XM not working
You should be able to pick up a new antenna from any sirius/xm retailer. One thing to try before you buy a new one is; make sure that the antenna has a good view of the sky- the best place to mount the antenna on a car is either on the back of the roof, or on the trunk lid of a car. If you have a SUV, mount the antenna on the back of your roof away from any luggage racks. Run the cable under the weatherstripping and your carpet so it will look "clean".
If your antenna is for a house, it will need to be placed in a window facing southwest. Delphi makes a great repeater for the house (i have one at work and at home). Good luck.
Jan 23, 2010 | Audio Players & Recorders
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do i install a cb radio on a pick up truck
You will need a CB radio antenna, The CB radio and mounting hardware as well as the power wire.
Choose a place to mount the radio. Mount it. Run the power wires from the radio to the fuse box. Put red wire in with the fuse that is hooked to switched 12 volt. Ground the black wire to any metal of the vehicle.
Next find a place to mount the antenna. If you use a mag mount, the roof of the cab is a best bet. Run the wire into the vehicle, it can go through the door, just make sure its not going to get pinched.
Hook the coax from the antenna to the radio
Now you have to tune the antenna. this is important because if you don't you you will blow the transmit final transistor out in the radio.
This link will take you to an article that will explain how to tune your antenna.
Nov 04, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra cb brand new and cant get it to work
get your swr checked by a cb shop. 90% of all cb problems are a poorly or not tuned antenna.
Sep 15, 2009 | Cobra 29 LTD CB Radio
DOES IT NEED A CONVERTER BOX
That depends on the signal coming to your house. If you use an antenna on your roof you need a converter box, if not your good to go.
Jun 12, 2009 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Dec 31, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
357 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
