Question about Plumbing
My shallow well pump will not pump to 40 lbs pressure which is the shutoff setting. tHE MAXIMUM PRESSURE IS 30 lbs so the pump runs continuously. What is the problem ? Pump is Red Lion 1/2 hp series RJS, about 3 yrs old. Well pipe is about 40 yrs old, 25 ft deep, condition unknown.
  • dgitlstudio
    dgitlstudio Aug 16, 2012
    My son's well has the same problem and new pump made no change. Our conclusion is the pipes from well to pump have pinhole leak letting in air which "cavitates" the pump. Temp fix was to adjust the pressure sw down so it would shut off. Working fine with lower pressure. This Fall we will dig up pipes and replace with modern materials. Hope this helps.
Installed new shallow well pump still only can get to 30 lbs pressure. when i turn pump off pressure drops to 20 lbs right away and stays there
Posted on May 27, 2011
  • 21 Answers
Sounds like the impeller inside the water box on the pump might be getting worn out.  did you ajust the pressure switch to turn off at 39 psi will at least work until you get a new impeller,
Posted on Jun 25, 2009
  • Cameron loker Jun 25, 2009
    sounds like the impeller inside the water box on the pump might be getting worn out.  did you ajust the pressure switch to turn off at 39 psi will at least work until you get a new impeller,
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
1999 flhr road king shock air pressure
Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
SHOCK LOAD TOTAL WEIGHT PRESSURE
LB. KGPSI kPa
Solo rider up to 150 up to 680 0
150-200 68-91 0-10 0-69
200-250 91-113 10-20 69-138
250-300 113-136 20-30 138-206
over 300over 136 30-50 206-345
Solo rider with capacity
luggage of 40 lbs (18 kg) up to 150 up to 68 10-20 69-138
150-200 68-91 20-30 138-206
200-250 91-113 30-40 206-276
250-300 113-136 40-50 276-345
over 300 over 136 50 345
Rider plus passenger ALL ALL 40-50 276-345
Maximum GVWR ALL ALL 50 345
If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
Do not exceed 50 psi (345 kPa) suspension pressure.
May 13, 2014 | Harley Davidson FLHR Road king Motorcycles
What is max air pressure for rear shocks on 2009 harley road king flhr?
LB. KGPSI kPa
Maximum GVWR ALL ALL 50 PSI 345 kPa
May 07, 2014 | 2008 Harley Davidson FLHX Street Glide
What is the air pressure for shocks on a 97 flhtc
I do not know but you could call a Harley Service department or better go there in person and ask.
Solo rider up to 150 LB up to 68KG10-20 0 psi0kPa
Solo rider up to 150-200 LBup to 68-91 KG0-10 psi0-69kPa
Solo rider up to 200-250LBup to 91-113KG10-20 psi69-138kPa
Solo rider up to 250-300LBup to 113-136 KG20-30 psi138-206kPa
Solo rider up to over 300LBup toover 136KG30-50 psi206-345kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150LB up to 68KG 10-20 psi 69-138kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150-200 LB up to 68-91 KG 20-30 psi 138-206kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 200-250 LB up to 91-113KG 30-40 psi 206-276kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 250-300LB up to 113-136 40-50 psi 276-345 kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to over 300LB up to over 136KG 50 psi 345 kPa
Rider plus passenger ALLWeights 40-50psi 276-345 kPa
Maximum GVWR ALL Weights 50psi 345 kPa
Apr 17, 2014 | 2001 Harley Davidson FLHT Electra Glide...
My Wel-Bilt 1hp Shallow Well Pump #109231 is continually recycling (every 30 seconds). It looses about 10 pounds of pressure as soon as it reaches 40 lbs. There are no obvious leaks anywhere. The tank...
It is hard to figure out but you have what I call a water bound system. There is no air in your pressure tank. The easiest way to resolve is to drain the tank, let it fill with air, then turn on the pump, problem should be resolved for a while. There is a device that regulates the amount of air in the tank, that has failed or needs adjusting.
Nov 03, 2013 | Plumbing
I have a flotec 1 hp pump. Wife washed 3 loads of clothes in a row and noticed we run out of water a while later. I shut pump off and noticed pressure tank low on air. I put 18 lb. air in tank and...
If in the past your system can build-up pressure up to 40 psi even if the supply valve is open and water is being used in your house, then your pump impeller maybe already worn out that's why its pumping capacity was reduced.
Nov 12, 2012 | Flotec Corrosion Resistant Shallow Well...
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I...
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
Jul 05, 2017 | Northern Tool Electrical Supplies
Fuel filter or pump. will start but will not continue. gage show 55 lbs of pressure when start, none when not key on.
Sounds like a pump. You should have 43 lbs of pressure after system is primed by turning key to ON. Pump will run for 5 seconds and shut off if engine is not running. It should hold pressure for 30 minutes with just a few lbs drop. If not, it is the check valve, internal to the pump or the fuel pressure regualtor on the fuel rail. Hardly ever the latter
Jun 23, 2011 | 2004 Ford Explorer
Pump will not shut off gives great pressure when running how do i fix this?
This pump runs off of a pressure switch either 30/50PSI or 40/60PSI. It would appear the switch has failed and will need to be replaced. Any Square-D pressure switch will do, head to a home improvement stire and they should have the right item for you. It will cost you @ $10-$15.
Please let me know if this had assisted you,
Tom
Apr 21, 2010 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
921 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
