Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Dont know my pin code and i'm trying to tune my tv in to the atenna
  • 1 more comment
  • benjamin_c_8 Jun 17, 2009
    lc32pd5x not sure of the antenna but it works fine on my other lcd
    i have a sharp aquos lc32pd5x have lost the pin and am not sure how to tune the tv into the aerial and i know the antenna works fine
    excellent thats what i was after thanks guys
  • Sharp Master
  • 13,433 Answers
Can you send me the brand and model of the tv and details about the antenna. Thanks
Posted on Jun 17, 2009
  • Ekse Jun 17, 2009
    I'm not sure what pin code your talking about but I assume its the childlock since I don't see that it would have any other locks.
    by default from factory the pin code is 1234
    heres the full user manual for your tv
    http://www.cleverhome.com.au/user/Sharp-...
    if the code doesn't work heres how to reset the tv
    HOW TO SET THE FACTORY PRESETS
    Turn off the TV by pressing POWER on the TV.
    After waiting for about 1 minute, press and hold down RESET and press POWER on the TV to turn on the
    TV.
    All setting items (except TV channel) return to the factory presetting.
    note Password will be cleared after running the factory presetting operation.
    You can run the Auto Installation again by using the following steps.
    1 Turn on the power of the TV.
    2 Press MENU. (Make sure the menu screen displays.)
    3 Press left or right to select “Setup”.
    4 Press up or down to select “Auto Installation”, and then press ENTER.
    5 Press left or right to select “Yes”, and then press ENTER.
  • Ekse Jun 17, 2009
    please see my solution
  • 10,515 Answers
Look at the manual and set :-
http://www.cleverhome.com.au/user/Sharp-Aquos-Piano-Black-LC37PD5X-LC32PD5X-manual.pdf
Check and let me know.
Thanks for using "Fixya".
How to tune tv with remote?
if you dont know the code too use and have the manual now
try to find the type you have look in google for the manual
use
make model and add the works user manual or similar search
or.. just go to the £1 shop and buy a decent universal
i got one works for me
just press set and hold for a few seconds
the led comes on
then press the red power on
and it starts to transmit turn on off signals
so once it turns on be quick and press the TV buttons
its the button in a row to choose different devices
so this stores the new code
from the manual you can find the codes sometimes not
but you can also get the remote too tell you the code that works
and then note it and if anything goes wrong you dont need to do the set search again
try to use the manual for your one or find it saves any waste
Dec 10, 2014 | Universal Televison & Video
HOW TO FIND PIN CODE TO UNLOCK TV ?
Try one of these: 1536 1684 0088 0536 0056 0063 0065 7593 1014 1973 1221 0581 1317 1065 1969
Aug 07, 2014 | Toshiba REGZA Televison & Video
HOW TO GET UNLOCK CODE ?UNLOCK TV TOSHIBA
"If you cannot remember your PIN code
While the PIN code entering screen is displayed, press [RECALL] four times within five seconds. The PIN code will be cleared and you can enter a new PIN code."
Or you can trye this:
Step3Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
I forget the pin code for my 61' toshiba tv how do i clear it
Dont know what model or how old your TV is but try this,
While the enter PIN code screen is displayed, press the RECALL key four times within five seconds and the PIN code will be cleared so you can enter a new PIN code but it has to be with the original remote. Worked with my old Toshiba TV about 2 years ago.
If it doesnt work I only waisted about 10 secounds of your time and I'm sorry.
Nov 13, 2011 | Toshiba Televison & Video
I was given a technika hd ready dvbt dvd built in freeview with no instructions.I need instructions how to tune in freeview.It had previously had the freeview tuned in but now the channels are not...
hi,
First of you have to check the Atenna connection in the rare of your tv. Check for any loose contact on the connection of the wire to the pin. may be its the cause for showing signal as 0%. you can confirm the same by connecting the tv at the place where you doughters tv is connected. If there you get the picture then there is some thing wrong with the atenna connection.
If want information how to tune your tv then need information like BRAND and MODEL NUMBER of you TV.
ok
Aug 05, 2011 | Televison & Video
Cannot tune my technika tv due to a child lock?
have you tried to put in 0000 or 1234, this usually comes from the factory, unless to have put one in yourself.
Mar 25, 2009 | Televison & Video
Radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Dec 28, 2008 | Pyramid PDVD79 CD Player
Trying to find manufacturer of digilogic to tune dvd recorder into tv
What is the code for Digilogic television, Model number
D14PTV1
Mar 30, 2008 | Televison & Video
Toshiba that uses CT-90040 remote
Is the cable remote a programmable universal? If so, just a matter of finding the codes to reprogram functions.
Concerning the "tuning video", are you saying that you can't get to different input sources?
Oct 15, 2007 | Toshiba 36AF42 36" TV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
161 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
