Question about ECHO, Inc. 20 In. Double Sided Hedge Clipper
Echo hedge clipper difficult to start
My echo 150 is difficult to start.
Am using regular gas mixture. also in a sthil weedeater that does start.
    President:
  • 987 Answers
 Remove the muffler and spark plug, turn unit so the spark plug hole faces down and let gravity take it's course. Unless this is an old unit, there is no reed valve. If the problem persists inspect the piston, rings and cylinder by looking into the exhaust port. If vertical scoring is visible a top end rebuild may be necessary.
Posted on Jun 17, 2009
Echo 260 hedge clipper not showing gas in purge bulb -won't start.
If you cannot get bulb to fill then something is wrong with the valves inside the carburetor. That is not a repairable item.- you need to get new carburetor.
Aug 25, 2017 | Echo Garden
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
What is gas mixture for weedeater poulan pro 25cc 17" cut
40:1 ratio is the manufature spec for 2 stroke units. unless it is a four stroke then there is no mixture just a good quality gas.
Jun 03, 2014 | Poulan WeedEater Hedge Trimmer 25cc Engine
Echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Nov 26, 2013 | ECHO, Inc. 20 In. Double Sided Hedge...
My Echo SHC-212 will start and slow idle but when I give it gas it boggs and stalls. I've changed the spark plug and I'm using the proper mix. Any suggestions? I was thinking of trying to clean the carb...
The prior posters must be from the Briggs & Stratton era :0] This is an EPA carb. You can only adjust the idle speed. The Echo SHC-212 uses the Zama RB-K75 carb.
My SHC-212 had the same bogg/stall symptoms. I had to disassemble and clean the carb to get rid of it. There is an internal filter screen that sometimes clogs. I soak and use compressed air to blow out all orifices. But the real problem is leaving ethanol gas in the carb during storage. It warps the delicate gaskets/valves. So buy Zama rebuild kit.
Dec 24, 2010 | Echo Zama Carb Kit For Shc212 Hedge...
What is the current oil/gas mix for the excalibur 22" hedge clippers? How about the new oils like Echo an Brigg/stration that are used at 50/1. Would 50/1 be acceptable in the weed eater excalibur?
50:1 is 50:1 no matter whose 2 cycle mix you use. 50:1 is 2.6 ounces of 2cycle mix to 1 gallon (US) of gasoline. I recommend strongly to use a brand that contains fuel stabilizer. It will come in a 3.2 ounce bottle...still 50:1. The premium 2 cycle oils will be semi-synthetic or full synthetic and will claim "no smoke"
Sep 27, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
ECHO, Inc. 20 In. Double Sided Hedge Clipper Logo
171 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
