Ihave a G5 Tower running OSX.3.9. Computer totally froze while saving huge quark document. I had to shut it off with power button. upon restart I got nothing but a blank gray screen and later a flashing finder folder and flashing question mark. I fear my work is lost help
  • 1,305 Answers
Try using your OS disc, insert in your computer , power it on while holding down the C key.
You should be able get it running via the CD. Access the Disk Utiltity and attempt to repair your hard drive. If no luck, Disk Warrior may get your drive back.
Posted on Jun 17, 2009
Mac g5 wont start led light blinks once every 7 sec
Hold down the power button until the computer shuts off. The press the button to restart and see what happens. There are several different ways to startup. immediately upon hearing the boot tone, press and hold the shift key to boot in safemode. If this fails as well, then you will need to boot with the install CD. This is done by immediately pressing holding the C key upon powerup
Jun 27, 2012 | Apple Power Mac G5 Desktop
I have G5 PPC mac tower - power light is on, but the unit will not turn on. No fans are running. Just a bright white light on the power button.
First if side door or plastic shield is off, fans won't come on and unit won't start. Fans only run when unit is running hard and that's not always. Back to your original issue - not running, couple of things to try - first being side door and latch on back, make sure both are closed. Try restarting by holding start button on front of tower. If that don't cure it, disconnect power lead in rear for about 30 secs then try to restart.
Feb 26, 2011 | Apple Power Mac G5 Desktop
Compaq 615 froze with no display and fan whirring.
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test reports pass then perform installation of OS
else hard drive has gone bad
Apr 16, 2010 | Compaq Computers & Internet
Fist time ever after many years use. OSX runnining
Close QuarkXPress and navigate to HDD>>Applications>>QuarkXPress 4.1 folder and create a Preferences folder with "P" in upper case.
Now launch QuarkXPress and check the results
Dec 19, 2009 | QuarkXPress
I have a Mac G5 using Quark 7 on OS10.4 My hard drive failed and I put in a new one. My Quark had only 2 installs allowed. Both install were made on 2 different computers. Can I reinstall my Quark on my...
You should be able to if you are using quark license administrator as QLA uses the ethernet address commonly known as the MAC address and this is hard wired on the computer and not the hard drive to verify the license.
Nov 12, 2009 | Apple G5 POWER PC 2.0GHz BASE UNIT & 17''...
Screen became fuzzy and locked up
Most likely a hardware problem. Boot off your install disk and run disk utility as a first thing to make sure the disk is ok, and so you can take action if its failing to save your data. Try running the disk first aid. This may correct your problem. If not, try swapping out your ram.
Aug 22, 2009 | Apple Computers & Internet
Mac wont turn on
G5 will not boot off of OS9. Since you are more of a pc guy, think of it like this, you buy a used newer pc meant to run Vista, and you are trying to load Windows 98 on there. You can run any of the OSX flavors on there...
Depending on your Model (scroll to bottom) of G5 you need to be running...
2003 -> at least 10.2 Jaguar 2004 -> at least 10.3 Panther 2005 -> at least 10.4 Tiger
10.5 Leopard is Apple's newest operating system and it can be run on any of these models. You need to buy a retail copy (has drivers for every model) unless you buy exactly the right system disk for that specific model.
OS9 can be installed and run inside of OSX using something called Classic mode. This would be like running a virtual XP Pro inside of Vista.
Feb 01, 2009 | Computers & Internet
GeForce FX 5200
If your video card was not working correctly your problem would be evident in other applications as well, I suspect you have a software problem on the computer, most likely with the OS 10 software and possibly a conflict with the version of Quark you are running.
Oct 28, 2008 | Apple iMac G5 Desktop
Computers & Internet Logo
89 people viewed this question
Alun Cox
David Payne
David Payne
