Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
Blackberry flip phone is not reading my sim, says to insert Sim, worked in past and works in other phones. Phone is unlocked, problems seemed to occur after pairing with headset, (motorola H700), disabled headset still not reading sim. Any suggestions
  • cinbad_hale Jun 17, 2009
    Tried all above mentioned by Dakiro. Now phone shows SIM as OFF in upper right hand side of screen. Sim card works in other phones. Any suggestions.
    Problem Solver:
  • 12 Answers
Blackberry flip not reading sim.
First of all try this:
  • remove the battery and SIM card
  • replace only the battery
  • when the device has switched on remove the battery and replace the SIM card and battery.
Try this (from a forum) to access Safe Mode.
Accessing Safe Mode is simple: First you need to remove your BlackBerry battery to perform a hard reset.After reinserting the battery, the BlackBerry notification LED glowsred for a few seconds. Immediately after the LED dims, hold theBlackBerry Escape key—to the right of thetrackball—until a dialogue box appears to let you know the device isrunning in Safe Mode. The reboot process can take a few minutes, so bepatient.
To exit Safe Mode, simply perform another hard reset by removing and reinstalling your battery.
I would recommend this:
Go to options-security-general settings, then hit the menu key to the left of the ball. Then wipe handheld - it will wipe your phone memory.
If you are unable to use the sim, try a different one in your phone and eventually you will have to return the phone for repairs.
Posted on Jun 17, 2009
  • 32 Answers
Your sim is expired. replace your sim.
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Insert sim
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, unBBlock.com and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
May 01, 2013 | Cellet Blackberry T-mobile Curve 9360...
I am trying to use an unlocked Blackberry pearl 8220 on AT&T, it won't find a signal
If you are getting an error message saying, "Invalid SIM Card" or "Incorrect SIM Card", then you would need to unlock the phone first.
Unlock Blackberry 8220 Pearl Flip
Aug 01, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry bold 900,with initialization failed when i inserted my chip, when the network is activated it reads insert a Sim card,this was after swapping the chip into a modem but back into another phone...
You need to unlock your blackberry network. Go to find blackberry bold 9000 unlock code for your original network sim card so your phone will be unlocked for another network. You can get blackberry unlock code from your provider or you can buy from third party sites for the simple way.
Apr 18, 2011 | RIM BlackBerry Bold 9000 Smartphone
I have BlackBerry 8700g, and i dont know when i inserted the sim card into that, after displaying, in Screen shows invalid sim card, i using sim card in another phone, but it's working good, what's problem...
Your phone needs to be unlocked to use other sim cards. You can try getting the unlock code from your network service provider or a third party unlock code supplier (link below)
Blackberry Unlock Codes
May 27, 2010 | RIM BlackBerry 8700g
Invalid sim cardhas started to appear on my blackberry
if its showing that in valid sim cad
it means your phone is locked only one network.
try to do sim unlock your phone on line and you can do any phon unlocking shope
Dec 24, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
When i put my sim card into my blackberry it says invalid sim... what is going on? It's an unlocked phone I purchased on the internet and it is not working... can anyone help me?
It looks like the telephone is SIM locked.
If you go to Options > Advanced Options > SIM Card and type MEPD.
This will bring up another screen. If the Network option shows "Disabled" then it is unlocked.
If its locked go back to the seller or buy an unlock code online.
Hope it helped.
Nov 16, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My signal keeps sayin SOS and it tells me to insert sim card when
1.check the sim card if it is properly inserted.or try other sim card.
2.did you turn on your wifi?turn it on to have a signal from your network.
3.Is it unlock/openline already?
4.if the above mention is still not working its already a hardware problem.
Jul 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
452 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
