Question about JVC AV-65WP74 Rear Projection Television
My 65' jvc tv looks foggy - JVC AV-65WP74 Rear Projection Television
  • acephx80 Jun 19, 2009
    thanks for the info
  • JVC Master
  • 5,138 Answers
You may need to adjust your screen/focus controls or change out Bad fliud in tubes.
Posted on Jun 17, 2009
  • ladywinn
    ladywinn Jun 19, 2009
    Look down inside tube lenses when TV is on if you can not see clear thur projection fliud then change which ever ones that are not clear.
JVC Modle HD-61FN97 2006 65 inch tv light went out replaced it now can not adj brightness
Aside from the customer controls you might be able to turn the screen controls up a bit to get more brightness, they are on a black block inside the set.
Nov 29, 2012 | JVC AV-65WP55 65" Rear Projection...
Dear technician, My TV has gradually built up a layer of yellowish with some gray cloudy patches (foggy like) across the screen. Can you tell what seems to be the problem? I had this TV for 4 years and...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 22, 2011 | JVC HD-61FN97 61" Television
Hi my jvc 65" projector tv decided not to work ,a flashing lite came on where it says 'lamp/rec
Hi, did you get a solution for this problem?. I've got the same model and problem and was wondering how you got it fixed.
Aug 15, 2010 | JVC HD-65S998 65 in. EDTV Television
Why does my television look foggy
probably your lenses need cleaning.......take out the cover and try to clean the three lenses which project lights by cotton.
Jun 22, 2010 | Mitsubishi WS-65813 65" Rear Projection...
JVC 65 inch AV-65WP55 tv, the color red is failing
The tube is old. You need to contact a service center. He may try to boost it from inside. If it doesn't work, then need a new tube.
Jan 09, 2010 | JVC AV-65WP55 65" Rear Projection...
Blue screen
It sounds like the cooling fluid in your picture tube(s) has become dicolored - this can be seen if you dismantel the unit and view the picture tubes directly - they will appear foggy - replacing the fluid can be a time consumming and expencive task.
Sep 18, 2009 | JVC AV-56WP74 56" Rear Projection...
65 inch Mitsubitshi hd dlp
The tv has a bad lite engine. Please call the manufacture's customer service and asked them for a concession for this repair. This a $700.00 to $900.00 repair. If you persist 95% of the time they will cover this repair for you. Use the word 'concession' that's there verbiage.Good luck.
Apr 03, 2008 | Mitsubishi WS-65513 65" Rear Projection...
65 in.JVC bad picture
You may have a convergence problem that means, there may be convergence ic's bad or related components.
If you know something about tv's, try checking things out.
You can get a repair manual from websites to download.
If you do not normally fix tv's the best thing is to call a tv repair technician.
Feb 22, 2008 | JVC AV-65WP55 65" Rear Projection...
Flashing Power Button
the flashes are a diagnostic blink code, tells a tech what the general area of the problem is, you of course have a shorted or open component in your set but thats all I can tell you because you didn`t give the blink count,
Nov 27, 2007 | JVC AV-65WP55 65" Rear Projection...
JVC AV-65WP74 65 in. Rear Projection... Problem:
I'm having a problem with my JVC 65WP74 the screen shows double pictures at the top and in the middle.
Oct 10, 2007 | JVC AV-65WP55 65" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
143 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
