Question about RCA RP5440 Clock Radio
Snooze alarm when i accidently hit the small nap button and it activates the nap timer. how do i cancel the nap timer? ie i'm going to sleep and accidently hit the nap button; i don't want to go to sleep and have the nap alarm wake me in a half an hour.thanks for your time.
  • Anonymous Nov 05, 2007
    I hit the nap button and i now can not turn that nap off!
    New Friend:
Like everyone else here I have accidentally hit the NAP button and couldn't turn it off. This morning at 2am I accidentally hit it with my husband in bed. I decided one and for all to guide this out. By flashlight and my cell phone i Googled a solution. I came across many, none of which worked. I resorted to trying methods that were posted for other models of this brand of clocks. The solution that I found that worked was to hold down the back part of the NAP button until the seat the time displayed and the nap light off. By back part of the button I mean hold down the tiny section closest to the rear of the clock. I got this solution from instructions for model RP3721A clock. It took me 17 minutes.That's just 3 minutes before the alarm would have gone off.
Posted on Apr 06, 2013
  • 3 Answers
According to the manual, you have to "hold the nap button" until the nap indicator turns off. This seems to work "sometimes". The only certain fix I have found is to unplug, remove the batteries and so reset everything.
Posted on Jan 02, 2008
We lost the remote for home theater system during our last move. Somehow, the sleep timer got activated, even though there is no remote. How do I shut it off again without the remote?
It's a bit weird that the sleep timer keeps coming every time you power up. Have you let it shut itself down by allowing the sleep timer do it? If it still does it then, and there is no button that will cancel it on the unit itself, try pressing them all, then you will to get either a universal remote or see if there is an original. As I don't know the make or model number of your system that is the best answer I can give.
Feb 02, 2016 | home Audio Players & Recorders
Toshiba Satellite L300D
I assume you mean it's in sleep mode and you can't get it out? Or you wish to put it into sleep mode, or perhaps you want to take a nap yourself? One word problems are very hard to solve.
If it's in sleep mode, take out the battery, unplug the AC, hold down the power button for 1 minute. Put the battery back in, attach the AC adapter, and press the power button. That should fix it. Putting it into sleep mode is generally done by pressing the power button for a second. And napping is generally done by putting your head down on your desk and closing your eyes.
Feb 16, 2014 | Computers & Internet
I am trying to turn off a sleep timer that is built into a rca universal remote
When you press a sleep timer, it sometimes is all you can do to activate it,
but when you press the button again shortly after, the time on the sleep delay
will change, eventually to being off/cancelled. ?
PLEASE RATE THIS ANSWER
Aug 13, 2011 | Televison & Video
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Thinking of getting the TI150 3-in-1 Timer - Can it set to repeat a countdown over and over?
Review at Amazon seems to say the timer can repeat the same countdown each time button is pushed and countdown is activated.
Amazon review says:
http://www.amazon.com/General-Tools-TI150-Visually-Impaired/product-reviews/B001TOJG7Y/ref=dp_db_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
The timer is easy to set. You just set the time, then hit the big "start/stop" button and the little "H" and "M" on either side of the timer display flashes.
To clear the timer, just hit both the "h" and the "m" buttons simultaneously. (so time has to be cleared)
To stop the alarm or to turn off the timer before the alarm sounds just hit the "start/stop" button.
On the back of the timer, there are 4 different on/off switches: flashing light alarm, sound alarm, vibrating alarm, and one for hours/minutes or minutes/seconds.
When I set the timer on my desk, it moved around when the alarm went off but when I turned off the vibrating function, the timer didn't move around.
If you need to turn off both the sound and vibrating alarms and use only the flashing light alarm, the light is quite noticeable by itself if placed nearby in your line of sight (within a foot or so). This would be very handy if you're near a sleeping baby! :) But if you clip it on a breast pocket, I would use both the flashing light and vibrating alarms. The vibrating alarm does make a sound, but it's not as loud as the ringing alarm.
Dec 27, 2010 | General Tools Hardware & Accessories
Accidently set television to sleep don t know how to cancel it
Sleep timers normally reset to zero after they have run there first setting. Unplug the set for 30 minutes or so and see if it clears. Thanks for using fixya.
Mar 02, 2010 | Televison & Video
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Nap Feature
i press the nap button and hold down the cancel button and it works fine
Sep 20, 2008 | RCA Radio Alarm Clock
NAP
JUST HOLD THE NAP BUTTON UNTIL IT NO LONGER IS BLINKING NAP, dont return it, its very good at waking you up in the morning, and is basically a good alarm clock, it just has a different way of turning nap off.
Feb 25, 2008 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
RCA RP5440 Clock Radio Logo
745 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
