Which firmware version supports 4 GB MicroSDHC card for sansa e250 V1?
    President:
  • 828 Answers
Here is the link : http://www.10001downloads.com/s/sansa-250.html
Posted on Jun 17, 2009
My sansa e250 having video option, but it not supot any video file to play on the player.
When your operating system on the computer is Windows:
Run the Sansa Firmware Updater to get the Sansa Media Converter: http://kb.sandisk.com/app/answers/detail/a_id/101/related/1
When your operating system on your computer is Mac, or when you want to update manually:
go to the Sansa forum: http://forums.sandisk.com/sansa/board?board.id=e200
note
Only when you have the e200 series version 2 player, videos can be viewed from the microSD card.
Accessing the microSD card:
http://kb.sandisk.com/app/answers/detail/a_id/167
Highest capacity of the microSD card:
Verify the version of the player. To check, go to Settings > Info.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
Differences between e200 version 1, 2 and Rhapsody player:
http://kb.sandisk.com/app/answers/detail/a_id/193
For supported files, see:
http://kb.sandisk.com/app/answers/detail/a_id/21
and
http://kb.sandisk.com/app/answers/detail/a_id/32
Aug 13, 2010 | SanDisk Sansa e250 MP3 Player
I have a Sansa e250 I have put a new Micro sd card with 8 gb memory into the card slot it has music loaded on to it ( when it is in the computer it comes up and shows what is on it ) the player does not...
The e-series uses microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot it is not electronically compatible and will not work in the e250. You need to stay with microSD cards, 2GB and smaller.
The newer Fuze series will accept microSDHC cards.
Jul 28, 2010 | SanDisk Sansa e250 MP3 Player
What kind of a sd card do I need to purchase inorder to expand the memory of my sansa c250
It depends on the firmware version of the player,
to determine the capacity and type SD card you can use.
note
player's firmware version can not be interchanged
Look in Settings > System Info for your version:
For 01.xx.xx firmware (c200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (c200 version 2) - up to 4GB microSDHC cards
Apr 10, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
I cant delete any songs
The e200 series players have 2 versions, plus a Rhapsody version.
How to check your version:
On the player
1. Go to the Main Menu
2. Select Settings
3. Select Info
4. Check the firmware version, if it says
v1 it is a version 1
( or Rhapsody
Rhapsody also supports Rhapsody service and channels
USB mode is Rhapsody/PlaysForSure instead of MSC/MTP for
the normal v1
Rhapsody fonts are smooth, antialiased )
v3 it is a version 2
Having a version 2 player, songs can be deleted on the player itself:
1. In playback mode, press submenu.
2. Select the Delete Song item.
For all versions you can delete songs:
1. Making a connection to a computer first.
2. Use the Windows explorer on the computer:
Select "My Computer" on the desktop and go to the internal memory or expansion card of the e250:
Go into the MUSIC folder. Select your songs inside the MUSIC folder and select delete.
Need more information ? Just post a comment.
Dec 31, 2009 | SanDisk Sansa e250 MP3 Player
How to delete the recordings??
The easiest way is to connect to your computer via a usb cable. Click on the local disc "E: or whatever yours is and do it on line. Remember to use the safe disconnection procedure.
Dec 30, 2009 | SanDisk Sansa c240 MP3 Player
Sansa 40gb e260 dont know how to put music on it . dont have manuel
For the Sansa e260 4 GB there are 2 versions for the e200 series players:
version 1 manual
version 2 manual
Check the version of your Sansa e200 series:
SD card compatibility:
NOTE: Firmware is not interchangeable.
Dec 09, 2009 | SanDisk Sansa e260 MP3 Player
I cannot play songs form my 4GB SD card
If it is v2 then it should not be a problem but v1 models can only support 2gb UNLESS you install rockbox firmware which can be found at http://www.rockbox.org/ and this will allow v1 models to play more than 2gb cards but this only works on v1 models so if you have v2 then this want help. But this sounds like you have a v1 model since its not playing.
Jul 18, 2009 | SanDisk Sansa e250 MP3 Player
How to add 8gb memory card in sandisk sansa e270
You have a v1 unit and the maximum is 2GB MicroSD unless you install a different firmware called Rockbox. Then you can load the MicroSDHC cards in your computer and play them in the Sansa.
Mar 06, 2009 | SanDisk Sansa e270 MP3 Player
I need to know the maximum GB external micro sd card I can put in a sansa E260 4 GB Mp3 player and a sansa express 1gb mp3 Player.
thank you for choosing Fixya.com
you can use 4GB it is the applicable memory on your mp3.
if you will try to use much higher than 4gb sometimes it is the reason why our player are hanging up.
please don't forget to rate our answers properly.
Mar 05, 2009 | SanDisk Sansa e260 MP3 Player
408 people viewed this question
 Grubhead
Grubhead
