Question about Brother MFC-5890cn Color Flatbed All-In-one Printer
Have the same problem
Printer keeps saying ........Unable to print 36? This printer is owned by me for about 6 months, never had this problem before. Downloaded a bunch of upgrades from Vista with no avail! Please let me know if you have any success, because I'm getting no where. Tried unplugging it several times. Paper also, at times just lays under paper feeder? Hope someone from Brothers reads this.
Jim
  • Tom
    Tom May 11, 2010
    When it was running OK was it on XP
    If not then go to www.brother.com and get the latest drivers from them
    You may find the site has a disclaimer notice saying that the machine will have problems on Vista
    Good Old "Uncle Bill", nothing Microsoft does is for the good of the end user
  • 37 Answers
This has nothing to do with printer drivers or O/S. It means the print head is not travelling correctly. Did this happen after a paper jam? If so see my previous post:
Check that there is no paper jammed up on each side of where the print head travels.
Easiest way to do this is to power off/on. While the machine is going through its initial startup listen for when the print head travels along its carriage (from right to left). When you hear it, immediately switch off the power.
Open the main body of the printer and hopefully the print head will be stopped midway, you can then check at each end for any jammed paper.
If this does not solve issue, it will require an engineer.
If you are in the UK, call Brother UK tech support on 0870 830 4000. They will arrange a warranty repair, or pass you on to a repair agent if the machine is out of warranty.
Posted on Jun 17, 2009
  • 135 Answers
I just finished with a MFC490CW, it had the "unable to print 36" code.
after looking at the mediocre replies other than "mechanical" and "print head" I started looking at obvious issues while CLEANING, there was ink on on the clear timing strip in front of the P.H .assy.
after cleaning ink off timing marks...no code..working fine
hope this helps
Posted on Aug 03, 2009
    President:
  • 1,185 Answers
Further note
According to Brother the code unable to print 36 does not exist ?
They do list unable to print but put that down to a mechanical rather than a software problem
Give me solutation of errore 36 came inb DCP165C Brother Printer
That error 36 - means "Head/carriage unit travel error" , if the printer is still under warranty, have it serviced. But if its out of warranty try to find any obstacles on the travel path of the head/carriage unit. If you cant find anything, it only means you need to replace some parts.
1. carriage PCB
2. head/carriage unit
3. CR encoder strip
4. carriage motor
5. main PCB
6. power supply PCB
7. maintenance unit
May 13, 2010 | Brother DCP 165C Compact Color Inkjet...
My brother printer is MFC-490CW and it just says "unable to print 36" what could this be?
Brother Error CodesRAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Mar 08, 2010 | Brother MultiFunction Center MFC-440CN...
I've refilled my black ink cartridge #36 and put it into my Lexmark 5650. My computer will not let me print - not even to "complete a page" print. It says that I need more ink. I have windows vistas. What...
Lexmark 36 and 37 cartridges cannot be refilled. When your ink levels drop below a certain point your printer deactivates the electronics on your cartridge so you cannot refill them. I own a Cartridge World ink refilling shop and I sell Lexmark originals for the 36 and 37 because of this reason. Unfortunately you purchased a machine that you have to buy expensive original ink for. You need to buy Lexmark original 36 and 37 to get your printer to work. As a refiller I never recommend someone buy a Lexmark printer if they ever want to use refills.
Jan 20, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Printer message "unable to print 36"
That error usually means a paper scrap or something is stopping the carriage from moving across the paper correctly, or there are scraps caught on either side of the carriage assembly.
Aug 28, 2009 | Brother MFC-465CN InkJet Printer
Error message on my printer that says unable to print 36
If this is a Brother clean the clear strip on the carriage assy. it is a timing strip for the carriage , I have seen ink on these cause the "36" code
Jun 05, 2009 | Office Equipment & Supplies
Wont work at all just says unable to print 36
"Machine Error 36" and "Unable to Print" are error messages indicating something physically making it impossible for the machine to work. Hopefully, you could find a stuck paper or parts of stuck paper by opening the different covers (front, back, paper trays etc), the problem should then be solved by removing the paper and rebooting your machine.
However, if this does not work or you're unable to find the stuck paper, you will need to have service on this unit, to open up the machine.
May 17, 2009 | Brother MFC 6490CW InkJet Printer
Unable to print 36
lift the lid to where the connections cable is
I have had this problem several times & this is the only fix
Jan 26, 2009 | Brother MultiFunction Center MFC-440CN...
Error #12288
problem in the driver call to the toll free no 1800110011 and ask for the resolution.....
Aug 17, 2008 | Samsung CLP 300 Laser Printer
Brother MFC-5890cn Color Flatbed All-In-one Printer Logo
807 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
