Question about Refrigerators
My fridge light is on but the compressor/condensor isn't running. Would the theromstat need replacing or would the compressor be the problem. Thanks.
  • jeremyastewa Jun 17, 2009
    Thanks Shafky,
    The power outlet is 240volt which i checked with a multimetre.
    The compressor does not start even when the thermostat is at the coldest level. I think the thermostat might need replacing.
    We had the Fridge running for 3-4 hours last night when the power went out to the house. I checked the circuit breaker and reset it, the fridge did not turn back on, I turned the fridge of at the outlet and the power hasn't gone out again.
    Do i try and fix the fridge or buy a new one?
    Thanks
  • 85 Answers
1st of all sure that ur voltage is enough to run the refergerator (220V or 110V) then UP the Thermostate Volume (i mean raise it to last point it have) and then On the refergirator, after 1 min touch the refergerator body to check that the compressor is running or not (Vibrating), if the Prob presists, contact your local Electrician to verify your voltage, its not a compressor problum u have (i mean not so bigger problum).
Good Luck
shafky
Posted on Jun 17, 2009
SMEG Fridge Freezer FA561XF - the frame of the fridge/freezer gets very hot and freezer isn't freezing stuff in bottom tray
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink.
Also, if the machine is too close to the wall or the condensor coils are dirty you'll get the same effect, so be sure to check those things out as well
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Smeg FA561X Side by Side Refrigerator
GE fridge not cooling. freezer working ok. compressor fan not working
This is an odd thing to hear. Normally when the condensor fan (}compressor fan) Isn't running the freezer is the one who's temperature rises and the fridge stays about the same. I would strongly suggest looking at the main control board, just for the simple fact that 9 out of 10 times thats the root of the problem
Jun 06, 2012 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Condensor getting power but not running
Bad overload/relay (part plugged onto the compressor ) Remove and make sure there is contunity between all 3 compressor terminals . See if there is continuity between the terminals and the copper tubing ( indicates a bad compressor ) . If all checks ok , then replace the o/relay .
Jul 19, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
No cooling in freezer or fridge. Still running with lights on and air coming into freezer from vent inside freezer at the back but not cold air.  Kenmore Side by Side circa 2001 with ice and filtered...
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Apr 26, 2009 | Kenmore 53642 / 53644 Side by Side...
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Skybox
Check the compressor to see if it is running. Is it too hot to touch. If so make sure the condensor has proper air circulation to cool it. If the compressor is cool to touch and running. There is a leak in the refrigerant sealed system.The compressor isn`t doing any work because there isn`t any refrigerant in it, therefore will not creat much heat. A humming and clicking sound is typical of an overheated or damaged compressor. If the compressor isn`t running and connot start. It could be a bad start relay on the side of the compressor or a bad compressor. If you can remove the start relay, shake it and listen for a rattle sound. If it rattles, it is bad.If not. then it is time consider the cost of a repairman verses the value of the appliance. Check the cost of repair to the sealed system or maybe even replacing the compressor.I hope I have been of some help to you.
Nov 12, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Refigerator Condensor Fan not Running
yes it is your getting proper voltage, fan simply went bad, center mullkion was the unit trying to disperse the heat the fan was not able to!
Nov 01, 2008 | Maytag MZD2766GES Side by Side...
Fridge compressor hot. inside of fridge/freezer is not. compressor humming(assumed to be running).Whats an indicator of low freon and can it be refilled? Thanks!
low refrigerant may be indicated by outside tubing at room temp (or at least most of tubing) when compressor running. can be confirmed by pressure checks on system. Refrigerant can only be checked or recharged by qualified (card carrying) appliance tech or refrigeration tech. be sure to clean condensor (outside) tubing and make sure fan next to compressor is running if there is one.
Jun 20, 2008 | Refrigerators
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
