Question about Fisher Washing Machines
Fand P smartdrive 9 fault codes
I have a Fand P smartdrive 9 with the following fault code displayed. Shortwash light on, rinse right hand light on and the spin light on. Can anybody help me??
  • 109 Answers
Does the machine start when you press start?
Have a look at this page for more info (I hope it helps you?)
http://www.fisherpaykel.com.au/admin/pdfs/pdf_usecares/529589BDD605userguideNZAUw.pdf
Posted on Jun 17, 2009
Hi there i got a fisher and paykel intuitive and i got a code 9 error.
Scroll down to fault code 9:
https://www.manualslib.com/manual/787840/Fisher-And-Paykel-Smartdrive-Phase-7.html?page=34
Jan 13, 2018 | The Computers & Internet
Abs on vr commodore light stays on solutions
Error logs are a great thing. They will help you find intermittent problems and start you off in a general direction of where a problem could be. There is a great level of detail on the justcommodores site on checking error codes logged by the engine management system, but this does not detail anything about the abs system. The abs warning light is not as common as the check engine warning light. Reading through the posts, I haven't found any detail on checking error codes logged by the abs system.
So here it is. For those of you familiar with checking the engine error codes, this procedure is so simple its not funny.
Basically, to check the engine error log, you bridge the 5th (ground) and 6th pins in the ODB connector under the steering wheel.
To check the ABS error log, using the same trusty calibrated paper clip, you simply bridge pins 5 and 12 of the connector.
To find pins 5 and 12, start at the top left hand corner. That is pin one. Going to the right, you count pin 2,3,4 etc. Once you get to the end, jump back to the start of the bottom left level of pins and keep counting. Pin 5 is about halfway along the top row, pin 12 is a little left of the middle in the bottom row.
Reading the error codes is the same procedure (counting the flashes), except now, the ABS light flashes (as opposed to the engine light when checking the engine codes).
The ABS log also uses code 12 firstly, with any errors logged shown after that. If no errors are logged, the 12 will flash again.
Error codes for the ABS error log (VR/VS) are as follows:
12 Diagnostic system operational
21 Right hand front wheel speed sensor fault
23 Right hand front wheel speed sensor continuity fault
25 Left hand front wheel speed sensor fault
27 Left hand front wheel speed sensor continuity fault
28 Wheel speed sensor frequency error
31 Right hand rear wheel speed sensor fault
33 Right hand rear wheel speed sensor continuity fault
35 Left hand rear wheel speed sensor fault
37 Left hand rear wheel speed sensor continuity fault
41 Right hand front inlet solenoid valve circuit fault
42 Right hand front outlet solenoid valve circuit fault
45 Left hand front inlet solenoid valve circuit fault
46 Left hand front outlet solenoid valve circuit fault
55 Rear inlet solenoid valve circuit fault
56 Rear outlet solenoid valve circuit fault
61 Pump motor relay circuit fault
63 Valve relay circuit fault
71 ABS control module internal fault
The above guide has been verified on a VR/VS. Checking the error log on all models prior to VR/VS is the same for the engine log, and I would assume that the same can be said for the ABS log, would be happy if someone could verify this for me.
Sep 21, 2013 | 2005 Mazda Tribute
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
My fisher and paykel top loading q washing machine won't start. It beeps and lights 5 and 8 come on. Any ideas what the issue might be?
That is fault code 9 machine not sized
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
My top loading fisher and paykel q washing machine beeps with lights 5 and 8 on - what is the problem?
That is Error code 9 machine needs resizing.
MODE.
LEDs will change.
memory.
(560mm wide).
(600mm wide).
517790C
35
(650mm wide).
Fault 9 come on
MODE.
LEDs will change.
memory.
(560mm wide).
(600mm wide).
517790C
35
(650mm wide).
May 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Check engine light on
1990-95 FOUR CYLINDER ACCORD AND 1992-95 PRELUDE
See Figures 7, 8, 9, 10, 11 and 12
On 1990-95 Accord (except V-6) and 1992-95 Prelude, the codes are read from the check engine light after the two-wire service connector has been jumpered. On Accords, the service connector is under the dash on the passenger side. On Preludes, it is located behind the center console. Codes 1 through 9 are indicated by a series of short flashes; two-digit codes use a long flash for the first digit followed by the appropriate number of short flashes. For example, Code 14 would be indicated by 1 long flash followed by 4 short flashes. Codes are separated by a pause between displays. Multiple codes are transmitted in an alternating pattern. For example, a code 3 and 14 would be displayed as 3 short flashes (for Code 3) followed by the separator pause, then 1 long flash and 4 short flashes (for Code 14).
Fig. Fig. 7: Fault codes are read from the check engine light on most late-model vehicles
Fig. Fig. 8: On Accords, the service connector is located under the dash on the passenger side
Fig. Fig. 9: The service connector on Preludes is located behind the center console
  1. Use a jumper wire to connect the two terminals of the service connector together.
  2. Turn the ignition switch ON ; the check engine light will display any stored codes by rhythmic flashing.
In the event that a code is encountered which is not on the chart, re-count the number of flashes. If the code is truly wrong, it will be necessary to swap the ECU for a known-good unit and recheck. Since this can be expensive, you may wish to bring the car to a reputable repair facility if no other cause of the failure can be found. This may save you the expense of purchasing an unnecessary part.
  1. If no codes are displayed but a driveablity problem exits, testing of the system individual components is necessary to find the problem. If codes are displayed, follow the appropriate troubleshooting chart in this section.
Fig. Fig. 10: Fault code chart for 1990-93 Accords
Jan 28, 2011 | 1990 Honda Accord
Need to find obd in 1990 honda accord
TROUBLE CODES System Diagnosis READING CODES When the "Check Engine'' warning light on the dashboard comes on and stays on, it indicates a problem in the fuel injection/emissions system. Check the ECU for fault codes. On certain models, some codes will not trigger the check engine light; if driveability has suffered, check for stored fault codes. The most common error when using fault codes is to assume the indicated component has failed rather than checking the entire circuit. The presence of a trouble code means simply that the electrical circuit for the named component is not functioning properly. For example, a code for the oxygen sensor circuit does not automatically mean the oxygen sensor has failed. A wire terminal may simply be loose or corroded at the connector. When using diagnostic or fault codes, always remember that the entire circuit including the component must be checked carefully. On 1990-95 Accord (except V-6) and 1992-95 Prelude, the codes are read from the check engine light after the two-wire service connector has been jumpered. On Accords, the service connector is under the dash on the passenger side. On Preludes, it is located behind the center console. Codes 1 through 9 are indicated by a series of short flashes; two-digit codes use a long flash for the first digit followed by the appropriate number of short flashes. For example, Code 14 would be indicated by 1 long flash followed by 4 short flashes. Codes are separated by a pause between displays. Multiple codes are transmitted in an alternating pattern. For example, a code 3 and 14 would be displayed as 3 short flashes (for Code 3) followed by the separator pause, then 1 long flash and 4 short flashes (for Code 14). Fig. 7: Fault codes are read from the check engine light on most late-model vehicles 86804048.gif
Fig. 8: On Accords, the service connector is located under the dash on the passenger side 86804049.gif
Fig. 9: The service connector on Preludes is located behind the center console 86804050.gif
  2. Turn the ignition switch ON; the check engine light will display any stored codes by rhythmic flashing. NOTE: In the event that a code is encountered which is not on the chart, re-count the number of flashes. If the code is truly wrong, it will be necessary to swap the ECU for a known-good unit and recheck. Since this can be expensive, you may wish to bring the car to a reputable repair facility if no other cause of the failure can be found. This may save you the expense of purchasing an unnecessary part.
  3. If no codes are displayed but a driveablity problem exits, testing of the system individual components is necessary to find the problem. If codes are displayed, follow the appropriate troubleshooting chart in this section. Fig. 10: Fault code chart for 1990-93 Accords 86804051.gif
    Fig. 11: Fault code chart for 1994-95 Accords (four cylinder) 86804052.gif
    Fig. 12: Fault code chart for 1992-95 Preludes 86804053.gif
Dec 14, 2010 | 1990 Honda Accord
Fisher & paykel smartdrive MW095AU wont spin
press start cold water starts then stops and starts about 3 times followed by error which stops machine to protect it ?
Dec 28, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
566 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
