Question about Novelty 96512 Cuckoo Phone
Cuckoo Clocks I have a cuckoo clock which fell off the wall, it has fallen off of the mechanism, and is in pieces. Is there a way to repair these. Please helpCindy
  • 4,102 Answers
You can repair them is their any damaged pieces i will try and get you some diagrams to show you how to put it back together but if you take it to repair shop ie watch repair they will build it for you and get any parts that are broke or they will be able to make them for you hope this is some help i will try find you some diagrams on how it is built i will post you back if i find it but need to know what make and model no if poss
Posted on Nov 02, 2007
Cuckoo and action doesn't work
Is this a mechanical cuckoo, or an electronic? If mechanical, probably the strike mechanism is jammed. You might barely, HEED: just barely pull on the weight a tiny bit and see if this does anything. If not, time to get it serviced. If it is an electronic cuckoo, check batteries and contacts.
Nov 04, 2017 | The Watches
How do I adjust the clock when it's running slow?
If your cuckoo runs too fast or slow, the best way to correct this problem is to set your cuckoo to an accurate watch or clock. After 24 hours, record how many minutes your cuckoo is running too fast or slow. Then adjust the bob up or down the pendulum stick to change the pendulms effective length. You'll need to take an educated guess as to the distance. Reset the cuckoo minute hand time to your watch or clock again. Repeat this process every 24 hours, recording the results, and readjusting the bob until you are within 3 minutes of the correct time. Then, switch from recording every day to recording every week. Use the same process described, recording the time difference, adjusting the bob up or down every week, until the cuckoo is accurate within approximately 3 minutes per week. Remember, mechanical cuckoo clocks are not as accurate as quartz or electric clocks! A three minute error per week is not bad. Maybe you can do better. What you are attempting to do is to obtain is the best timekeeping possible from your cuckoo clock. Afterwards, you will still need to sychronize the cuckoo (coo coo) clock minute hand to an accurate clock or watch, each week or as desired.
Feb 14, 2016 | Audio Players & Recorders
I need instructions for Acctim FELDBURG Cuckoo Wall Clock
Hi, not much info on this clock specifically. This might help though :)
Instructions Quartz Cuckoo Clocks
Jan 31, 2015 | Watches
How to fix a German Regula cuckoo clock?
As Larry said, you can pull the chain to spin the wheel in both directions. If you are having trouble with one chain being longer, you can even them out this way. I wouldn't suggest removing the weights.
Elisa Jed ' http://www.rockaroundtheclocks.com/category/34939958
Aug 10, 2014 | River City Clocks 6" Cuckoo Clock German...
How to fix a cuckoo clock
See this page... http://howtorepairclocks.com/clock-repair/cuckoo/pendulum-will-not-swing.html
Jul 04, 2014 | Home
Clock manuals
If you have replaced the two C cell batteries and the mechanism is still not operating, the clock needs to be repaired by a clocksmith If you can't get service from Kaiser. A mechanical weight driven cuckoo clock with proper service will far outlive a battery operated "novelty" clock.
Feb 01, 2014 | Home
Is the world's largest cuckoo clock in the U.S.?
It is currently in Schonach, Germany. However, the Amish community in Sugarcreek, Ohio is hoping to have them beat with the cuckoo clock they are currently building there.
Feb 11, 2013 | Home
Do cuckoo clocks need to be certified to be real?
There is a Black Forest Clock Association. They certify cuckoo clocks that are made from wood and made with parts produced in the Black Forest region and that meet the standards set by the association.
Feb 11, 2013 | Home
CUCKOO TIME ADJUSTMENT
http://antiqueclock.clockstop.com/CUCKOO.htm
1/8 inch movement of the pendulum bob is equal to about 3 min per 24 hours running.
-To increase the time of the clock, move pendulum up.
-To slow down the time move, pendulum down.
Regulation notes:
These novel clocks are at best only a "fair" time-keeper. You can expect 100 to 120 sec per 30-hour winding period. I recommend that if it is within a few minutes per winding, simply RE-set the time.
-The regulation obstacles are obvious:
1. Open pendulum, this allows even the slightest breeze from a fan, ceiling fan or even cross-winds inside your house to affect both time qualities and/or its running ability.
2. The Pendulum material is wooden, and sensitive to climatic condition, during times of high humidity the clock will slow down.
Hope this tip helps.
R/
David
Jan 26, 2009 | Novelty 96512 Cuckoo Phone
Novelty 96512 Cuckoo Phone Logo
326 people viewed this question
Top Novelty Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Novelty Lands Phone Expert? Answer questions, earn points and help others
