Question about HP mx705 17" CRT Monitor
On screen display keeps appearing on, and usually
About my HP mx 705 CRT monitor, on screen display keeps appearing on, and usually stays on screen for so long.
  • aquarhey Jun 18, 2009
    I did what the solution has suggested, but it didn't work, I've isolated the problem by connecting my problematic monitor to my other CPU, and same problem appears, on screen display still flashes relentlessly even though it was already connected to my other CPU.
    Champion:
  • 381 Answers
Hi..i think you have a problem the CPU/Computer that's whystays on screen for so long.1st step check the IDE cable connection form the mother board to Hard Drive and 2nd check the memory or check all hardware`s.Good Luck and Have a nice day
Posted on Jun 17, 2009
  • 109 Answers
This is a hp monitor problems, contact your nearest repair center!
Posted on May 09, 2010
How do I change the display settings for my hp mx 50 crt monitor 13 inch
for changing the display settings right click on desktop, then go to properties and then change all the settings that u want to change
May 19, 2010 | Computers & Internet
My hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.
<div style="FONT-SIZE: 14px; PADDING-TOP: 10px" itxtvisited="1"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblProblem" itxtvisited="1">my hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.</span> </div><!-- answer --><!-- from fixya rte -->
May 12, 2010 | HP S7540 17" CRT Monitor
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
The hp mx 705 monitor was working,then it just went blank and black. the power button light, just blinks green.
If the computer is attached properly and you get the flashing lights it is due to switch mode power supply being faulty, too expensive to fix I think you will find, never seems to be anything like just a fuse I'm afraid, modern worlds tells you its time for you next monitor..... do try to ensure it aint the pc by hooking laptop or something else to this unit, or hooking another monitor to your pc to be sure but I find power supply failure is normally how monitors leave this world...
Nov 07, 2009 | HP mx705 17" CRT Monitor
Hpm-705 crt monitor fault?
my monitor model is HPm705 CRT as and when i use the system the monitor screen gets switched off and on every 2mins... pls consider the issue and tell the solution for it... to get resolve......
Sep 05, 2009 | HP Computers & Internet
I have a ViewSonic flat screen monitor. The images on the sign in page are fuzzy and unreadable. I have Windows XP.
I would check the connections between the monitor and computer. Also the refresh rate and/or resolution might be wrong. To correct this, you will need to boot your computer in safe mode. (restart computer, right after the computer's logo appears rapidly press the F8 key until a black and white menu appears. Select SAFE MODE) once the computer boots to safe mode, the sign on screen will appear very large. Sign onto the computer once at the desktop, RIGHT CLICK the background and select PROPERTIES. Once the display properties window appears click on the last tab SETTINGS. Here is where you can adjust the resolution. Take the screen resoltution to a low setting. You can always change this later when you boot your computer normally to get a better view. Next click on the ADVANCED button click on the MONITOR tab, usually flat screens operate at a lower refresh rate then CRT monitors. I usually keep my refresh rate to 60 Hertz. Next click on the GENERAL tab. This will allow you to change the DPI setting. I usually keep mine set to 96 DPI. You may want to experiment with this as monitors vary. Once done, click on the APPLY button then OK. Restart the comptuer and see if this has improved your display. You may need to do this several times trying different settings until you get a clear display. If you've exhausted all these steps, try a different monitor or changing the cable. If that fixes the problem then you know you have a bad monitor or cable. Good luck, let me know how it turns out.
Dec 19, 2008 | Computers & Internet
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Hp mx 705 monitor the brightness menu appears andautomatically increases brightness to 100
Facing same issue in HP M704 from 12th Mar 08. It was working good for more than one year. Planning to contact customer support for service.
Mar 09, 2008 | HP mx705 17" CRT Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
HP mx705 17" CRT Monitor Logo
263 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
