My side by side kenmore refrigerator has stopped dispensing water and ice.There is ice in the bin.The water dispenser makes a click when pressed.The filter was changed and reset.
It sounds like your auger is jammed. Pull out the ice bin a nf see if you can turn it by hand. If not, dump all the ice out and what doesn't come out, melt it with hot water. You probably have ice that melted together which is jamming the auger or an ice cube is in the perfect spot to jam the auger.
Kenmore model numbers look like this example=> 321.1234578 Are you sure that the water in the ice maker is melting and flowing down into the ice bin? What may be happening is the water control valve for the ice maker may be allowing water to continue flowing into the ice maker tray even when off due to the water control valve being defective. If your refrigerator also has a water dispenser and the water is not continuing to leak is because the water control valve has to sides. One side is for the ice maker and the other side is for the water dispenser. I am here if you have questions, ThanksSea Breeze
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Open the door and hold the door switch down and try the ice
dispenser. Do you hear any thing. Take all the ice out of the bin and try.
Anything? Take the bin out and try. Anything? The motor is behind the back
cover where the bin sits. See if you get power to it using a voltmeter. If your
are, probably bad motor. If not dispenser switch.
