I have a Bush flat screen television which will work for a couple of hours after being switched on, but then there is a "popping" sound and the picture becomes a series of coloured lines appearing vertically from top to bottom and the only way to clear them is to switch it off at the mains, wait a few seconds and switch back on. The picture then returns and is okay for about 20/30mins before it does it again. What is causing it and how can it be cured?
  • 3,230 Answers
HI there,
You need to set the Convergence.
Go to the below link to know how to adjust -
http://www.ehow.com/how_2034880_perform-convergence--tv.html
Good Luck!!
Thanks
Posted on Jun 17, 2009
Why does the sound keep going off on my Bush LED tv
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 06, 2014 | Bush Televison & Video
Bush lcd32tv009hd
Could be a bad connector on the set or a bad cable.
It could also be a bad circuit board. If the connections are good, take it to a repair shop.
Apr 03, 2014 | Televison & Video
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
When I switched on my Bush Television this morning there was no sound, what do I need to do to get it back. This has never happened before. Thank You
Switch off power remove plug and keep aside for an hour. Now after reconnecting if there is no sound you need to test the audio input and audio output to confirm if the fault is relative of the preamp or the power output amp. connect an input source to TV and another from TV output to Amplifier.
Once confirmed then the section can be checked , for power supply failure or the processing section IC.
Sep 15, 2011 | Bush Industries IDLCD15W008HD LCD TV
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Mar 20, 2009 | Polaroid FLM-3225 32 in. LCD Television
Bush 29" Flat Screen TV IN INDIA CITY OF CHENNAI NEEDS REPAIR.
Please contact below address for Madras branch as they are authorised Bush service centre
Location : U/12 A, Yogi Complex, New Rander Road, Surat - 395009 Phone : (0261) 3066848, 6548278 Regards//Ravin//London
Jun 13, 2008 | Bush 2871NTX 28" TV
I have got bush lcd27tv006hd tv. When it is switched on the light on the bottom right just flashes and nothing happens no picture no sound.
I know this problem was a couple of years ago . . however, I bought a BUSH 27" 'factory refurbished' for my son and it lasted a couple of years and then this problem with the standby lamp,etc occured. I followed a couple of threads regarding 1000uF capacitors on the power supply board relating to the 6volt output side and now all is well. TV now working :-)
(Did change for higher voltage spec. as recommended!)
Many thanks to all who supply info on websites like this one.
Mar 30, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
