Question about Hotpoint Washing Machines
Hotpoint wm53 unknown problem
Hi. i have recently bought a second hand hotpoint wm53 washing machine it works fine. recently when the cycle reaches the rinse stage it is cutting off the power to all my downstairs plug sockets. any time after this that i try and turn it on it will keep tripping the switches. after a period of time (a day or so) it will start working again but the problem will recur. the machine also makes a lot of noise when spinning i dont know if this is normal or attributed to the problem. hope you can help.
Joe
  • Hotpoint Master
  • 3,463 Answers
Hi.
Unplug the motor and try it again, if it does not trip, then the prob is the motor, could be worn carbons.
Re the noise, remove belt, and spin drum round by hand, if it is noisy and rumbling, then main bearings have failed, quite a big job to put right.
Please rate my comments.
Thanks.
Posted on Jun 17, 2009
Hi got a hotpoint wm53 when i turn the dial to A all the trip goes ,checked motor is ok .hope you can help (will rate comment) WebRepOverall ratingThis site has no rating(not enough votes)
Posted on Nov 06, 2012
HI! I HAVE A MESSAGE ON MY HOTPOINT WMF760P WASHING MACHINE OF ' DOOR ' COMING UP & IT'S STOPPING SHORT OF THE WASH CYCLE & THEN YOU CAN HEAR THE LOCK MECHANISM
http://www.ebay.co.uk/itm/HOTPOINT-WMD9692-WMF520-WMF540-WMF560-WMF720-WMF740-DOOR-INTERLOCK-SWITCH-/390558604486?pt=UK_Irons_Presses&hash=item5aef1b5cc6
you need one of these
take the lid off and open the door
isolate the mains supply and water supply
remove the two screws that secure the interlock
this is what the doors catch sits in
reach down and tilt slide it out
remove the plug
plug in the new one
and remount
screw back in the two screws hand tight avoid stripping the plastic
and return the lid in position
now reconnect the water and mains and test
the door closes and the machine should now work aok
did one the other day
Dec 08, 2014 | Hotpoint Washing Machines
Hi, i got a hotpoint ultima extra washer dryer, code WDM73, it does a wash but at the end of a cycle it wont drain the water, it says check the outlet pipe but theres nothing wrong with it, i dont have a...
try bottom front right hand side is a filter ,...undo ..water will come out so have some towels ready... clean and refit... bsc appliances 07779933829 spares and repairs.
Feb 27, 2011 | Hotpoint Washing Machines
My WD420 washing machine has been working fine up until recently. First the dryer stopped drying so bought a seperate one as all else was fine. Now I cannot get washer to work. It seems to not be pumping....
Hi from retired Englishman in SW France @21:39 Sat evening
Most filters are found behind the bottom front cover. The cover will either pull off or be held in by some plastic screws which need turning 90 degrees anticlockwise.
Now-
POWER OFF AND HAVE A WATER RECEPTACLE AND/ OR RAGS TO SOAK UP ANY WATER!
There will be a panel which can be turned anticlockwise and the filter will either be attached to it or remain in its housing. Remove and clean as necessary! At the same time normally the pump can be seen and should be able to be turned by hand/finger ensuring nothing is stuck in it (needle, tooth pick etc).
If there was a blockage the machine should now work.
If it does not may I suggest raising another problem ticket with the same heading as this one but state in the detail that you have already ensured that there is no blockage.
Hope this works for you!
Cheers,
John C
Jan 29, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing machine motor works fine on spin but on wash, very weak w
Hi Dave, you got the answer right all on your own mate, it is brushes related, I had a similar problem ages ago and as it turned out it was the brushes breaking down, what you need to do is remove them both and clean the armature with some fine glass paper, inspect the brushes and make sure they slide in and out of their housing easily (no obstructions) then if they do, fit them back in to make sure they can reach the armature.
Mar 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wd440 confusion over washing machine pipes
Hi is there another valve? If so then you can connect them by a Y piece. Problem solved.....
Feb 26, 2009 | Washing Machines
Hotpoint Aquarius WMA46 1300 , front loader
half loads will vibrate more than full load
check transit bolts are removed
if vibration persists, then fault is probably shock absorbers worn
Sep 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD420 1200 Spin
Hi I have an Indesit WE16 with some of those symptoms and cannot figure it out - so please don't rate this as useless yet! I am beginning to suspect a bad connection to the motor and I have noticed that the drum only turns anticlockwise in my case - if the program calls for clockwise rotation the machine just hums for a few seconds and then stops.
Does this apply to your machine?
Please add a comment and maybe together we can sort both of them out. D
Jul 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
222 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
