I cannot cancel printing of a document.The status coloum keeps showing as 'deletinf''.
    President:
  • 828 Answers
Restart your computer...
Posted on Jun 17, 2009
Myy Brother MFC5460 will not print at all. Printer status says it is ready, but the printer never receives the print material. The information remains in the print queue. Work Offline is not checked, so I...
How is it connected?
If its connected via usb cable just follow the steps below:
1. Make sure that Mfc5460cn lcd shows date & time. 2. Disconnect the usb cable from the computer and printer. 3. Turn off the printer and unplug it from the power outlet. 4. On the computer, cancel the document on queu. Go to printers folder and right click on the Mfc5460cn icon and left click on cancel all documents. 5. Reconnect the usb cable from the printer then to your computer. Make sure that it is connected securely. 6. Plugged the printer back to the power outlet and then wait for the lcd to show date & time. 7. Open the printers folder again. Make sure that the status is ready document 0 8. Right click on MFC5460cn then left click on properties. ON the lower left side of the window click on print test page.
The printer should print a test page. And it should work,
Hope this helps. Rate if it works. Thanks
Apr 09, 2011 | Brother MFC-5460CN InkJet Printer
My printer will not print. When you check the status of the document it says printing. When you cancel that it doesn't cancel. DAYS later the document prints all by itself. What's that about?
It's because the print queue is saved on the printer's flash memory. This happens when you don't cancel the queues properly or terminated improperly. To get rid of the issue, always try to give the command slowly and don't over load. If you are printing photos, try to make the file size small so that it'll not take long to spool and prepare for printing.
When the problem occurs, so as follows:
Cancel the queues from the print status box ("Cancel all documents"), if they are not cancelled, then turn off the printer (directly unplug the power cord from the printer), it you still see the printing status, keep on cancelling until everything's gone.
If the problem persists, restart your computer. Definitely the problem will be fixed.
It's also important to press the cancel button while the printer powers On.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | HP Officejet 5510 All-In-One Thermal...
Lexmark z31 printer will not stop printing
Disconnect printer cable from PC. Power off printer and unplug power cord from outlet. Wait 15 seconds. Press the power button as if to turn on with unit still unplugged. Plug back into outlet and turn on printer.
Before reconnecting to PC, check the printer's queue status. Start, Control Panel, Printers. Select the printer by double clicking to open queue status. Select any remaining documents and choose cancel from document menu bar.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Lexmark Z31 InkJet Printer
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Printer Problems
have you tried to right click on the printer icon in your task bar at the bottom of your screen? once you do that, you can highlight the document that is showing, right click and cancel printing.. you can also cancel all jobs.. let me know if this helps, if not, do you have the original cd so you can uninstall and reinstall the drivers? if not, i'll need to know what type of printer to find you the link to the driver download--this will just reset the printer and it should work fine.. good luck, d
Mar 03, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
81 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
