Question about Epson laser Printer EPL-6200L Laser
Error in printing
I have an Epson EPL6200 printer. It was working fine until when I changed to a new PC. After installing the driver into the new PC, I cannot print documents as smoothly as I wish. When I first start the pc, I can print a few documents at one go. However, say, after a while, I try printing again, it will prompt " please check connection ........" and error is shown in a small window. With the error message still there, I am able to print the document by turning off and on again the printer. Can you kindly advise what is wrong? Thank you very much in advance.
    President:
  • 828 Answers
There is a printer options at control panel, try to see if the setting is printing immediately,...
Posted on Jun 17, 2009
I installed a new printer: Epson Stylus SX445W. When installing, the program announced an error and closed down. Scanning and printing photos from the SD card work well, but I cannot print from my...
Any number of possible reasons why the drivers didn't install properly but that's basically what seems to have happened.
Try uninstalling the driver, downloading the latest version (for your operating system) from the Epson Support section of their website and then reinstalling.
Remember to have the printer turned off and the usb cable disconnected until prompted to do so.
Might also be worth disconnecting from the internet (for safety) and disabling any of your anti-virus or other software while you install the drivers as they can sometimes cause problems.
Obviously once you're done, re-enable anything you disabled and reconnect to the internet as normal.
With a little luck that should cure the problem.
Aug 06, 2013 | Epson Stylus Sx445w Inkjet Print Scan 5760...
I have an Epson R 300. It worked fine with my PC. I recently got a new I-Mac and I cannot print CD/DVD's. I have the Epson "Print CD" application loaded but when I try to print on a DVD I keep getting an...
If you are using a leopard operating system, you have to install easyprint. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=26322&prodoid=37368458&infoType=Downloads&platform=Macintosh,
Trash / re-install epson print cd.
There is a work around for that. Please contact epson.
Apr 30, 2009 | Epson Stylus Color 300 InkJet Printer
Can't print from shared printer
Did you connect the printer directly to the laptop to install the drivers? If so, you need to change the port to the network location to //hostcomputer/printer. You should also have the same user name and password set on both machines and have the user rights assigned to the printer sharing.
Jan 24, 2009 | Epson Stylus RX500 All-In-One InkJet...
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Mac OS 10.5 Leopard
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
Nov 09, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson rx 420 comunication problem
But you install the software precisley as instructed? Remove all Epson software from the computer. Do a disk and registry clean. Come off line and disable the A/V software. Disconnect the printer Now reinstall from the disc and do exactly as the prompts. Epson is very fussy in installing .
Jul 12, 2007 | Epson Stylus RX425 Multifunction...
Epson laser Printer EPL-6200L Laser Logo
192 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
