Question about Compaq Presario FX700 17" CRT Monitor
Fx700 mdl.321a I installed the driver recommended and used a usb cord between tower and monitor like recommended and my 700 is up and running(thank you),but the speakers on my monitor are still not working!!!All usb ports are functioning and all lights are on,but nothing else is working!! Help! Thank you again for the assistance you already gave.
    Problem Solver:
Re: fx700 mdl.321a
After searching and searching I get the same reply, it is NOT conpatable with win xp. There are no drivers for this monitor that will work with win xp. I beleave that this monitor has drivers for win 95 only??? Not positave but its all i came up with.
Posted on Feb 28, 2009
0 characters
3 Points
What is a USB receiver?
If your computer is a laptop, most of (all) laptops comes with a built-in wireless adapter. And if it is working, you don't need one.
If you have a desktop (a tower casing, monitor, keyboard and mouse) setup, mostly they don't have built in wireless receiver. But if your desktop is custom built like mine, I have installed a wireless card in my desktop. But not really recommended. Since it sits in the desktop tower casing and if you need to get more signal and have to move around, you get furious because it is not mobile.
USB receiver or adapter can be extended via a USB extension cable (3 meter, 7 meter, 10 meter) and put it where the signal strength is high or remove it and use it on any other computer (laptop or desktop) with a USB port.
So, if your computer is not equipped with a wireless adapter/card built in and need to have wireless access, you need to buy a usb wireless adapter. These days they are as cheap as 8$ to 50$.
Hope this helps.
Apr 29, 2014 | Dell Computer Monitors
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Oct 13, 2012 | Computer Monitors
Me han venido un monitor compac presario fx 700 mas no se el manejo de sus opciones por ejemplo para escuchar los puertos de usb no funcionan o que debo presionar o es qe no me han entregado todos los...
Lo único que puedo decir es ir a este sitio web, y descargar los controladores para el usb, y visite el sitio web de HP y encontrar el manual para ello. Lo siento por el español malo, yo estoy usando traductor Google para hacer esto.
Jan 29, 2011 | Compaq Presario FX700 17" CRT Monitor
My dell monitor usb ports don't work anyone how to fix it?
Please check if the monitor's usb port is connected to the tower, the monitor only acts like a USB hub / junction. If it is connected then disconnect it from the existing USB port and connect it to a different USB port. Please refer to the monitor manual link given below
Thank you for contacting Fixya.
Jan 03, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
Powers up screen is black, will work on external moniter
atomikhound, May need to find correct drivers for this unit. Try search at HP website using the unit's product number on rear of the monitor. What is date of manufacture on this unit? It seems that this monitor only works with a Presario 4800 series desktop computer for which it was custom designed for. The article I read at "" said it should be used as a boat anchor if you can't get a copy of original 48xx system restore disks that have the special "drivers" needed for it. Good luck. 12fixlouie
Apr 26, 2010 | Compaq Presario FX700 17" CRT Monitor
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computer Monitors
Samsung 713N screen goes black
Aug 31, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
I'm having problems locating a manual. Compaq doesn't seem to support the model anymore. Reading a review online, It almost looks like Compaq had an Application control this instead of practical buttons on the front. Here's the review I read that talked about it ->
Hope this helps a bit! Sorry I don't have much else, I've been digging for a few days now to find more.
Apr 23, 2008 | Compaq Presario FX700 17" CRT Monitor
Do you mean you can get it to turn on?
Compaq Presario FX700 17" CRT Monitor Logo
146 people viewed this question
Top Compaq Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Ricky Ostrom
Ricky Ostrom
Are you a Compaq Computer Monitor Expert? Answer questions, earn points and help others
