Question about Kenwood KAC-9152D Car Audio Amplifier
Amp blowing fuses
I have my amp running off of a separate battery in my trunk (not sure if that matters) but yea....one of the two 30 watt fuses on my amp keeps blowing out when i turn the volume up, i have two 12'' cvrs in a sealed box, ran into one channel @ 2ohms which is good with my amp,(it was also blowing fuses with them hooked up in separate channels @ 4ohms) im pretty sure the wires arent pinched.....im not sure why its blowing...that amp has always been able to put out waay more power...i have the gain turned like halfway so i know its not set too high....any good advice appreciated
  • 199 Answers
Your amp is blowing fuses to protect your circuit. The type of 12V battery does not matter. For whatever reason you are over driving the amp. 2 Ohms sounds like a very low impedance for a car amplifier output. I am assuming you have the two 12" speakers wired in parallel. Most are rated at 4 Ohms which means you are pulling twice the current with the 2 Ohm load. Also, the bigger the speaker, the bigger the magnet, the bigger the coil, the larger the inductance, the heavier the load. Make sure these speakers are matched with your amp. A small amp driving large speakers will shut down at high volumes. Try putting them in different channels. Good Luck.
Posted on Jun 17, 2009
I've bought a pyramid crystal 1000 watt 2 channel amplifier used it states it runs at 4 ohms can I run it at 2 or 1 ohms and if so what will the wattage be?
Not to disappoint you too much, but the 1000 watts advertised is just marketing hype. If your amp is the PB781X, it should have only a single 15A fuse on it. Your battery provides 12.5 volts when the engine is off, so at most, your amp draws 187.5 watts of power. Draws, not outputs. No amp is 100% efficient due to heat. When your engine is running, assuming your alternator outputs 14.4 volts, your amp's maximum power draw is about 216 watts. Again, this is what your amp draws, not what it puts out. What you should focus on is the RMS (continuous) output, not Max or PMPO. Those numbers are useless, unfortunately.
Your amp is rated to output 50 watts per channel at 4 Ohms, and 75 watts per channel at 2 ohms. This is when wiring your channels separately, not bridged. I did not see true power specs for your amp while bridged, but it's possible you'll just get the full 150 watts to the single bridged output. Do not attempt to apply a 1 ohm load to your amplifier, as you will run the risk of damaging it. It's not designed to handle a 1 ohm load. If you're lucky, you'll blow a fuse before the amp is damaged, but either way, there is nothing to be gained by attempting it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Sep 12, 2017 | Pyramid Car Audio & Video
Tip
Save your charging,and electrical system when installing a audio amp.
Every one wants the BIG amp,the more powerful,the better right?When installing an audio amp,it is good to install a addition battery,in the trunk, it is the idea place,just ground the battery to the frame or body,to a good know ground,It needs to be a large cable,1/o wire,yeah,that is big,but will keep you from having problems,then run a 1/o positive cable from the aux battery you have just put in the trunk,to the main battery in the vehicle,use a 3/4 heater hose to insulate the positive cable you have just installed.This heater hose will prevent a portion of the cable to be rubbed threw on the insulation of the cable and shorting out.Then install the amp.Now ,for better electrical control over the charging system of the vehicle,you can install a isolator ,to separate the circuit,and still charge the battery up with the vehicles alternator.Install the isolator at the vehicles battery and the positive cable you just ran.The alternator will charge the aux battery,and the vehicles battery,and not affect the running of the vehicles engine,or charging system.Be sure to connect the amp to the aux battery only,and the aux battery needs to be a good strong battery such as a 65 style battery such as for a full size ford crown victoria.These batteries are full of power.There you are,you are ready to thump,and do it safely .You need to install a fuse holder between the positive cable from the aux battery and the isolator,use a max link fuse holder and fuse,and a strong 60 or 80 amp fuse,this will blow into before starting a fire,.
on May 28, 2010 | Car Audio & Video
Overchanging alternater (ECU?)
The ECU has no control on the voltage. Does your vehicle have a separate voltage regulator? If so that's your fault. A lot of alternators have the regulator built into them. The alternator needs to be put on a test rig away from the vehicle and the output tested, this will eliminate the vehicle, You could disconnect the wiring to the alternator, run three fly leads to the alternator and to a separate battery and run the engine and test the voltage on the spare battery. Wire 1: Battery neg to case of alternator Wire 2: Battery pos to + terminal on alt (the thick wire) Wire 3: Battery pos through a 5 watt bulb to the ind terminal (ignition light) 17 volt will blow another battery for sure.
Jan 07, 2014 | 2002 Hyundai Elantra GLS
My name is Gena. The VEC024B that is being used by our field technicians are having problems with the fuse blowing in their work vans. Their vans are equipped with laptops.
Hi Gena, the inverter is a 400 watt unit. This is not a rating for a continuous load. You do not mention which fuse is blowing. This could be the fuse in the inverter or the cigarette lighter (power source) fuse. In either case, a fuse blowing could be a short circuit, something in the inverter shorted, or too much load. I am going to look at the too much load side of things. Not knowing how many laptops are being used, with the inverter if you have a 20 amp fuse in the cig lighter, this will allow you 20 amps X 12 volts = 240 watts. I would not run the inverter over 240 watts because of overheating issues. So, 240 watts will run 3 laptops. Just the laptops. Most laptops draw around 70 watts. check your power supplies on them to find their rating. If you exceed the 240 watts by combining the ratings, then you can expect trouble with your inverter. It will give 400 watts, but this is a temporary condition only. Another inverter will be needed or a larger one installed and it being connected directly to the battery (with a fuse of sufficient size installed). You could also (let us say there are 6 computers) charge and run 3, and the other 3 are running on their batteries. After an hour, switch so that the 3 running on batteries now are charging as well as running. The other 3 are now charging.
I hope this helps. If you have any other questions please provide additional information. Such as the size and location of the fuse blowing. The laptop power supply ratings.
thank you
Oct 15, 2010 | Vector VEC024B MAXX SST Power Inverter
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
Amp keeps blowing the fuses
Serious short circuit on your output transistors, need replacing.
Sep 28, 2009 | JVC KSAX4504 MOSFET 600-Watt Amplifiers...
KEEPS BURNING FUSE FOR POWER WINDOWS/LOCKS ITS PINK SQUARE 30 AMP
check ur trunk where there is a cap thing back there where wires run to make sure that didnt burn i have 1998 camry that did the same as urs and i checked mine and i fixed mine and now everythings works now
May 27, 2009 | 1996 Toyota Camry
Hi Aaron from NZ BLOWING 30 AMP FUSE
Brother you got a dead short was salvage do to wreck if so check inside head light bezel for split or frade wires.
Jan 31, 2009 | 2000 kawasaki VN 1500 Vulcan Classic...
2000 watt inverter blows 60 amp fuse under load
I have a background in electronics so i hope i can help. Now after reading this i have the feeling this item does not put out 2000 watts cause if that were the case it should draw somewhere near 147amps. This is because to find out amps you need to take the 2000 watts and divide it by 13.6 volts (assuming what the vehicle runs at) that gives you amps. watts/volts=amps.
Jan 13, 2009 | Atd Tools 2000-Watt Power Inverter # 5955
Car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Jul 26, 2008 | Car Audio & Video
Kenwood KAC-9152D Car Audio Amplifier Logo
217 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
