Question about Microsoft Windows Vista Home Basic Edition for PC
It doesnt save the sever address, i get alot of disconnection
I cajnt do my work anymore since i have vista, the connection drops out all the time and i lose all my settings when i exit the program
  • Brett McGuigan
    Brett McGuigan May 11, 2010
    What program are you using?
  • 49 Answers
Bcoz your pc didnt have 1gb ram or your pc has virus
Posted on Aug 16, 2009
Fix charger port
This is a common problem, you may need to buy a new cord cause alot of the time its the cord that is faulty and it doesnt respond to the ipod.. If that doesnt help try resetting it on Itunes.
Sep 13, 2013 | Audio Players & Recorders
Error 8001000b wont allow me to connect to the playstation 3 network anymore. everytime i turn the ps3 on it says error 800100b on the screen then i go to the network settings to try and connect and the...
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the rounter. This is usually done my typing the router's IP address on your browser. ie http://192.158.0.1
3. Locate a tab for FILTERS
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
Read more: http://www.ps3news.com/forums/ps3-guides-tutorials/how-fix-wireless-internet-error-8001000b-ps3-98772.html#ixzz1FxUHQxte
Hope this helps. Please Rate
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
Can't resolve a W010 connection error
Let put all not IP Address in Obtain. I put all IP ADDRESS manually. Usually this will cause to your internet connection drop. I encounter your problem before but i use DUAL WAN or 2 Internet Provider.
And i hope it's the same problem to me.
Aug 29, 2009 | Actiontec GT704WG Wireless Router...
My wireless adapter keeps disconnecting me from the internet, and I can't figure out how to fix it. I have to restart the computer everytime. I also can't pick up my laptop or it freezes. I have a toshiba.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this. and your laptop is freezing because you might not have got it serviced from a very long time.
Jul 14, 2009 | Toshiba (PA3212U) Wireless Adapter
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
Jul 04, 2009 | Western Digital Computers & Internet
My 2Wire Wireless adapter connection keeps getting disconnected every 5-10 minutes(ATT U-Verse Internet Svc)Is there a better adapter to resolve my problem ? Thank you.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Computers & Internet
Modem drops connection. Must disconnect and reconnect to restore
There are plenty of aftermarket Cable Modems for sale at most major retailers (Best Buy, Target, Walmart, etc..)
I would go and buy a decent one of these and try it out to really test to see if the modem is indeed the issue here. If the new one works and doesn't drop the connection anymore then problem solved. If however the new one does do the same thing I would check for proper venting area (make sure you don't have anything on top of or burying your modem) first. If that's fine then it could possibly be issues with your actual line and in that case you'll need to harass the cable company until they actually send someone to test your lines.
May 17, 2009 | Arris SURFboard SB4200 Modem
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Bought a compaq 6710b. The wireless connection stability is very poor. I can find my wireless network at home on Vista platform, but the connection drops out after several seconds and is not able to find...
Hi there
if you are seeing the network and are able to connect to it but it is getting dropped normally this wouyld lead to the signal not being that strong you can try to move the computer it doesnt take tot much to change the signal strength and see if the signal get' s better it should tell you how your signal is ok
Feb 28, 2009 | Computers & Internet
Internet
  1. Look at the network connection icon wheter its blinking or not during refreshing the web page.
  2. If it does not blink check connection between router and pc
  3. check Netgear internet settings.
  4. Check if there is any block settings in the router.
Window Vista has lots of updates, and it's bit defender is working everyday to check your pc. This is really slowing your programs including Internet Explorer.
To test if your Windows is haveing problems or not, you might download a linux live CD such as PClinuxOS or Knoppix to test the connection.
If you can browse the internet no problem then it would be your Windows has a problem.
Mar 20, 2008 | Computers & Internet
Microsoft Windows Vista Home Basic Edition for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
