Question about Zebra S4M Thermal Label Printer
My S4M printer's light flashes, and it spews out label paper
My S4M printer's light flashes, and we get a paper out message, but printer has paper, then it just spews out the paper when you turn it on.
  • 32 Answers
You need to check to make sure media and ribbon (if used) are installed correctly. Follow the path on the inside of the door. The sensor is positioned in a place that the media and ribbon can be loaded in the same spot, causing it to not see one or the other.
Posted on Oct 27, 2009
Zebra S4M printer Alert Message: Ribbon out I'm using a thermal paper. There is no print method mode.
In the software printer driver- set it to direct thermal or no ribbon. It will override the printer setting.
Dec 09, 2010 | Zebra S4M Thermal Label Printer
How do I load/install the roller ribbon for the zebra stripe S4m printer?
If you GOOGLE "zebra s4m manual" you find a number of manuals you can download as a PDF and the instructions for loading the paper is in that manual.
Jul 12, 2010 | Zebra Stripe S400 Label Printer
My zebra printer gives me a message no paper, it does have paper what can i do
If your printer is set for Auto Calibration on power up or when the printhead is closed and the label doesn't calibrate, then check the position of the sensor which is the red light. You didn't say how wide the label is but it may that the sensor is not positioned under the label. If it's out of position, the label won't calibrate.
Hope that helps !
Jun 09, 2010 | Zebra S4M Thermal Label Printer
I have an S4M that is used in a stand-alone label printing app. It connected to a KDU and receives input via RS232 connection. It has a stored label file on the printer. The problem is occasionally the...
The printer file is recorded in flash memory? The printer have EPL or ZPL firmware? Using ZBI may be a better solution, developed an application that stays in the printer memory and allows many uses.
Roberto Martinez
Sep 30, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M prints one label then goes to flashing pause light.
most likely it is a printer driver issue. There's 2 drivers, one for 200dpi and one for 300dpi. Use the one for 200dpi. It could also be the label setting is incorrect. Try running a calibration.
Jan 21, 2009 | Zebra Z4M Printer
Zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Jan 16, 2009 | Zebra 105SL Thermal Label Printer
How to reset factory default S4M. I try Pause and feed at starting the printer but it does'nt works. I have a display message: ALERT RIBON OUT.
This may be related to the printing mode you have configured. If you're printing on a thermal paper (direct) and the printer is configured for thermal transfer the printer will notify you that you are out of ribbon.
If you are printing on a regular paper and using a ribbon (thermal transfer) and the printer is configured for direct printing, the printer will notify you that you have a ribbon when you don't need one.
I hope this helps.
Regards,
Fábio
Jan 13, 2009 | Zebra S4M Thermal Label Printer
S4m is not printing
zebra s4m barcode printer ,suppose if i print 10 Labels only 2 Label come out balance 8 in memory .then printer comes pause, disply showing paper out /ribbon in/please help me....
Dec 30, 2008 | Zebra S4M Thermal Label Printer
Alert code
What is the message that should be display in the LCD display? The Alert light signals a problem the printer thinks it has and usually display amessage in the LCD display to help a user determine what may or may not need repair or service.
Jan 21, 2008 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
1,460 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
