Question about Black & Decker Leaf Hog Blower Bv4000
Replaced fuse, switch mechanism is not working
Unit works if i manually operate switch after replacing fuse. can not get switch mechanism to activate switch.
How to fix a window driver's side on a Nissan quest 2004....
First, you must establish what the issue is:
  1. Check for supply voltage to the actuator switch. If there is voltage TO the switch, activate the switch, and test for voltage on the switch output. If there is no voltage to to the switch, trace the issue back to the fuse panel. If there is voltage at the switch input AND voltage at the output of the switch, continue...
  2. Is the vehicle equipped with an "express" automatic window mode? If so, check to be sure the microswitch on the regulator is functioning. Also, verify that the automatic module (located in the armrest) is operating. Continue...
  3. When the actuator switch is operated, check for voltage at the motor. If there is voltage at the motor, make sure that the regulator mechanism is not jammed. (Has it been lubricated in the past 10 years?) Continue...
  4. If the actuator is operating and the regulator mechanism is operating correctly but the power window still does not work, replace the window motor.
May 07, 2015 | 2004 Nissan Quest
My power window and door locks fuse keeps blowing.
When the fuse blows figure out what you are doing, what switch is being pressed, then remove the needed panels to access the wiring to the switch and motor it operates, then you will find the damaged wiring and repair the short, no quick fix, just hard grunt work.
Mar 16, 2017 | 1996 Toyota 4Runner
Need a fuse box diagram for a 2004 mercury sable. Horn stopped working
1) Check for power to horn unit with steering wheel horn switch depressed. If power present, replace horn unit.
2) Check horn switch operation. Repair or replace.
3) Check continuity from driver's horn switch mechanism and horn wiring. If faulty, then trace wiring back to fuse box and relay assembly.
Make sure you haven't skipped any steps before attacking the fuse box issue.
Nov 03, 2012 | 2004 Mercury Sable
I have a 2001 lincoln ls and my wipers will not work ! changed the wiper motor and the clock spring and nothing ! any suggestions ?
IF the wiper motor is good, check the fuses and wiper relay. If both check out replace the control unit.
Oct 16, 2011 | 2001 Lincoln LS
I have replaced reverse light bulb, however new bulb will not work. I have checked the bulb, the fuses and the wiring, any ideas why can't get it work. Also indicator on dash still present.
The reverse light switch is a mechanical device used to control operation of the vehicle reverse lights. The switch is designed to complete the circuit when reverse gear is selected allowing reverse light operation (manual transmission only).
Aug 04, 2011 | Audi A3 Cars & Trucks
Dryer just stop working
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 30, 2009 | Dryers
1999 grand prix wiper fluid motor?
same fuse . Could also be washer switch. Needs to be checked out with 12V test light
Mar 30, 2009 | 1999 Pontiac Grand Prix
KitchenAid KEMC308KSS02 Microwave Error
The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
Jun 14, 2008 | KitchenAid KEMC308 Electric Double Oven
Tascam da-30mk2 keep getting error 01 message. I have tried turning unit on and off still wont load tape. I have not turned this unit on for about 6 months prior.
On the top of the cassette mechanism there are two micro switches on one small plate with 3 wires. These switches "tells" the electronics where the door is open or close & activate the rest of loading mechanism (second motor). If only one of the switches is not working, you will get this error (that's was my problem). The switch who is responsible for closing was broken. I replace the switch and everything is working fine and smoothly now.
Jun 08, 2008 | Audio Players & Recorders
Ionic Breeze Quadra Electrostatic Air Cleaner, Model S1637
http://www.allergybegone.com/ionbreezquad1.html
There is a manual for your purifier at this website.
It is in pdf form, free to download.
look for the sentence on the page.
it will take you to the download.
Feb 25, 2008 | Air Purifiers
Black & Decker Leaf Hog Blower Bv4000 Logo
218 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
