Question about Dishwashers
Normal cycle takes over 2 hours??? - Dishwashers
  • klcotton45 Jun 17, 2009
    Yeah there's a lot of steam. The dishwasher runs fine and cleans well, it just seems like an awfully long cycle. Is this typical?
  • 109 Answers
Is there any steam after this time coming out when you open the door?
If there is then either the dishwasher is heating ok or it fills from your hot water tap.
If not then the dishwasher may not be heating and may require a new heating element?
Posted on Jun 17, 2009
  • Adrian Jun 17, 2009
    As a rule a normal wash should roughly take 1 - 1/4 hours for a cycle.
    Depending on the brand and model, some dishwashers do more or less internally but overall do the same thing.
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 25, 2014 | KitchenAid Dishwashers
Dishwasher takes 3 hours to run through programme
3 hours isn't "extremely" long. If you run a normal cycle, it should run about 2-2:30 hours normally with the drying cycle. Now if it's over 3 hours, that would be a problem. Make sure that when you open the door that there is a lot of steam coming out, because that is the only thing that can extend the cycle is if the dishwasher isn't heating the water. Unfortunately this is a very common issue and it means that your control board inside the door has failed. There is a relay on the board that shorts out. This relay sends power to the heater, so when it fails the dishwasher doesn't wash well and it will run forever trying to heat the water which will never happen.
Sep 10, 2013 | Bosch Dishwashers
Is it true that it takes about 2 1/2 hours to go through a normal cycle? If not, how long does it take, approximately? I am asking about the 18 inch built-in.
I cannot find any mention of times for this particular machines run, I have found the Users Manual HERE. I don't think it should take 2 1/2 hours to run this unit through a cycle, perhaps 30 minutes to one hour.
I hope this answers your query.
Joe
Sep 20, 2011 | Danby DDW1899BLS Builtin Dishwasher
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
GOOD LUCK !
Aug 08, 2010 | Kenmore Dishwashers
I have purchased a house with the single door dishwasher and it takes forever to wash - about two hours - what could be the problem?
Check your program settings. If wash quality is good, it's OK. Check your inlet water has sufficient pressure! Refer user manual
Apr 07, 2010 | Fisher and Paykel DS603SS Stainless Steel...
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Aug 13, 2009 | Kenmore 56176
The washing cycle takes 2 hours to complete
Make sure the sani cycle is not selected, or pots and pans, also with the dry cycle most will take about 2 hours, if your dishes are not that dirty use the short cycle. Be sure your water is at least 130 F. Run hot water at faucet before starting the machine.
Feb 27, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Wash cycle
momrules, it could vary depending on the water entering the dishwasher. On a heavy cycle normal time is about 85 minutes not including thermal holds ( pauses that heat the water). On a normal wash, 68 to 75 minutes not including thermal holds. If the water entering the dishwasher is not at least 120 to 140 degrees the dishwasher will pause in cycles to heat the water before advancing. So 120 minutes is not unrealistic. The heaters in the dishwasher are low wattage and will only heat the water approx. 2 degrees every 5 minutes. Catriver.
Nov 30, 2007 | Kenmore 24 in. 17512 Built-in Dishwasher
Dishwashers Logo
164 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
