Question about Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive
1tb external hard drive connecting to a laptop
I use docking station for my 1tb hard drive. and the i connect it to my laptop. after shutting down my laptop makes a sound and after i couldn't boot my laptop again. i send it to the service center and eventually i have to change my laptop mainboard. it cost me around $300 and it's a large amount. whatever it is i just want to know is it a problem to connect a 1tb external hard drive to a laptop or maybe a problem if i use a docking station to connect my 1tb hard drive to the laptop? should i use the usual casing?
  • red_muskalad Jun 17, 2009
    so should i try it with my new motherboard?
    im afraid if it will breakdown again
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
No its nothing wrong with connecting a external harddrive to a laptop. Usually docking stations wouldn't cause this problem. It could have been just a bad luck of the draw with your laptop. Man made it and it can fail. Just normal wear and tear
Posted on Jun 17, 2009
  • Reco Wilson Jun 17, 2009
    Yea it should be fine.
  • 3,153 Answers
If you are connecting via a USB port and your HD docking station has no power supply of its own that could cause problems that might relate back to the motherboard. If that was the case then you should consider a proper USB HUB with its OWN power supply. This might avoid your problem from happening again.
many laptop usb ports cannot deliver the correct current AND voltage if many of them are being used at the same time. Manufacturers save money by building machines for "average" use and not for long term reliability and use. The average user may only plug a printer into his / her laptop and maybe a mouse. Not many treat a laptop the same way a desktop user would.
Posted on Aug 11, 2009
How can Western Digital hard disk drives be recognized by third party USB external docking stations?
The format on a disk, will not be relevant of recognition via an USB connector. To connect a drive via USB, the computer must have the correct driver for the hardware you are connecting. Be sure you connect the HD coerce to the external harness and make sure it is supplied with the correct voltages.
When you connect a working system on the USB connector and the drive does not have a format, the computer will see that and ask you if it should format the drive.
Mar 04, 2015 | Western Digital Computers & Internet
I bought my seagate free agent go in april of 2011 and registered it as well. I have all my important work layouts on this and the usb connector on the external hard drive broke off and now i cant connect...
First, since you purchased the product in 4/11, you should contact the manufacturer for a replacement housing for the hard drive. If that's unsuccessful (or if you don't have that much time), you can purchase an external docking station. Then remove the hard drive from it's case and insert it into the docking station.
Sep 14, 2011 | Seagate Momentus 5400.6 500GB SATA/300...
I backed up my system and recently lost the hard drive. A new hard drive was installed, and I connected my Verbatim to my PC, but I have no idea how to put all the backed up data back to my PC. Can you...
All you need to do to backup the files on your old hard drive is by using a Hard Drive Docking Station. you can take your hard drive to a local store and ask for a docking station that would fit on your hard drive, the docking station is like a device the you can connect to your computer using a USB cable.
Once you have it, your old hard drive will just function as an external storage device.
Jun 29, 2011 | Verbatim (96759) 1 TB USB Hard Drive
I have 1tb western digital external hard drive. It fell at the usb port got broken, so I went ahead and took it out of it's orginial casing. Placed it in a docking station and all i get is a blinking...
these have software in them for the board in the factory case ...you will have to use a data recovery software to recover contents then reformat the drive OR try installing it as a second drive inside the pc directly to the sata/ide cables not usb. good luck
May 08, 2011 | Western Digital My Book Essential 1TB...
The unit won't turn on... fry's on 8-17-2010...tooo much info to loose this is the 2nd, time that i have used it
You can still save your information if you remove the actual hard drive from its enclosure.
Simple as opening the enclosure, remove the hard drive then use an external hard drive dock - here
A hard drive dock instructions are here. Youtube: http://www.youtube.com/watch?v=OUrw9W3-FcA
and connect it to your computer for back up to a new hard drive.
A how-to can be found here. Youtube = http://www.youtube.com/watch?v=hQ_vjyvK28A
Let me know if this works.
Dec 21, 2010 | Hitachi External 1TB hard drive 7200RPM...
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Unable to transfer files from an acomdata external hard drive.
Borrow a friends "hard drive docking station" and remove the hard drive from the other external drive and place in the docking station and see if you can read the drives contents. The docking stations can be purchased at Best Buy or Office Depot if you want your own. Your external drive could have a faulty power supply or you really could have a hard drive that has developed bad sectors and that is a disaster for your data. When a drive starts acting up, you really need to act and transfer important files to a new drive or burn the data to DVD's.
Apr 14, 2017 | Computers & Internet
External hard drive connection through the dvr station
i have the same problem. as far as i know it is because large external hard drives require more power and the archos does not provide enough power. it would probably work if u got a hd which had a separate power source.
Jul 28, 2009 | Archos Internet Media Tablet MP3 Player
Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive Logo
262 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
