Question about Sharp AR-5320 Black and White Copier
Model AR 5320E. Giving H2 error.
Machine does not operate. It has a error H2. Urgenty
As we needed our copier very quick we had to call a qualified person to arrange the system.
Kind regards
Miriam4177
Posted on Jun 17, 2009
I HAVE COPY MACHINE SHARP AR-5320E DISPLAY ERRO H2 AND NO FUNCTION PLEASE I WANT TO KNOW WHATS PROBLEM AND HOW CAN I REST CODE 14
You have a heat issue. Go into service mode select code reset 14 and execute. Turn power off and on. Now if you don't know how to enter service mode. You need a qualified tech. You tap version twice that will give another screen select sim 14 and execute.
Nov 19, 2014 | Sharp Office Equipment & Supplies
I HAVE SHARP COPIER, THE MODEL NO IS AR-5320E. I AM HAVING THE PROBLEM OF H4 ERRO. PLEASE HELP ME
check heater section properly,(thermister,thermostat,heater lamp)go service mode and clear error code also
Sep 20, 2011 | Sharp AR-5320 Black and White Copier
My sharp copier AR-5320E is displaying error code u2
U2 04 Content EEPROM serial communication
error
Detail Error in communication with
EEPROM
AR-205
Jul 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
I need the software for ar-5320e
I need a share ar 5320e software .How can I get this software?
Jul 16, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
My copier sharp AR-5320E is showing number 2 and letter H on the
H2 IS HEATER UNIT PROBLEM.IF SUB CODE IS 00 THEN IT SHOWS THAT FUSER THERMISTOR IS OPEN.USE SIMULTIONS 14 TO RESET IT.PROBLEM WILL BI SOLVED .DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Jan 20, 2009 | Sharp AR-5320 Black and White Copier
MY SHARP AR-5320E COPPIER SHOWING CH ERROR CODE AND BLINKING RED TRIAGULAR LIGHT POINTING TO TRAIL
Some part/ unit (developer, drum, imaging unit, fuser) or something else is not installed properly or is not plugged into the machine. Check all assemblies that can be removed from the copier, and make sure they are installed and plugged in properly.
The 'ch' code will automatically reset when the fault is found.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Unit ig giving a 2H error code
the problem is h2 not 2h you need to replace the thermistor or try to clean it by an ordinary cloth
Jun 17, 2008 | Sharp AR-153E Copier
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
284 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
