Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
Bostitch N88 RH Framing Nailer
Can the nail depth be adjusted with this nailer? If so, how do I go about adjusting the depth.
  • 58 Answers
How do i control the depth the nail shoots in a bostitch coil nailer
The bostitch nailer pictured along along with your question is a RN46 roofing coil nailer. It has a dial on the front of the nose for adjusting depth. Some older nailers (roofing nailers) do no have a means of adjusting so were set at the factory for best performance. The question of depth usually comes up when lower bumper fails and the nail is driven too deep. Easy test. Remove nails and find a very soft piece of wood. Dry fire the gun against soft wood and measure how deep the driver is entering the wood. Harder test. Remove the head and use any handy tool to push driver down to bottom. Measure how far the driver extends past nose (should be about 1/8 to 3/16). If more, replace the lower bumper. Good luck
Jun 21, 2012 | Stanley Bostitch Nail Gun
Adjust nail depth 350 mag framing nailer
To adjust the depth of the nail on the coil 350, refer to the parts list listed below.
The safety foot, refrence # 430 or part # 904930 has a slot head bolt. Back off the bolt and move the safety foot down or up and retighten. If however the adjustment will not move enough to keep the driver from setting the nail too deep, then suspect that the bumper, refrence # 130 or part # 897337 has failed and is allowing the driver to travel down the cylinder further than normal. Easy fix. Remove the head and pull out the cylinder and driver to change the bumper. Good luck
http://www.ereplacementparts.com/porter-cable-coil350-type-coil-nailer-parts-c-129_1658_2177.html
Oct 10, 2011 | Porter Cable COIL350 3 12" Magnesium...
How do you adjust nail depth on Bostitch N80 framing nail gun?
i think this model has no adjustment. if it does it is on safety tip. if not you can only adjust air pressure.
Aug 05, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
I have been installing a treated pine deck, but the nails are been driven in to far, i have tried adjusting the pressure from the compressor but have had no luck is there a depth adjustment on the gun?
Yes, there is a depth adjustment. Most of the Bostitch models have a push button on the left side near where the nails come out. With the air unplugged, push in this button and you can slide the head assembly up or down to make your adjustment. Slide it out for less depth. It sounds like maybe yours is fully seated, providing the maximum depth.
Dec 13, 2010 | Stanley Bostitch Coil Framing Nailer
Adjusting airpresure
There is nothing on a nailer to adjust the air pressure. You have to do it at the pressure regulator. It is feasable to mount a regulator at the gun but more likely it's on the compressor. Most nail guns are rated for 90 to 120 psi. Set your regulator to hold the hose pressure between 90 and 100 psi. Using higher pressure to set the nail will ruin your nailer. Use the depth adjustment on the gun to set how far the nail is driven.
Sep 23, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Nail not going all the way in
sticking piston could cause this try some air tool lube and make sure that if there is a depth adjustment make sure its all the way down some bostitch havem
Jul 29, 2010 | Stanley Bostitch Coil Framing Nailer
Have a stanley bostitch framing nailer. Nails
Normally, yes- depends on how old the nailer is. But first, let's ask: are you getting at least 90 psi of pressure to the rig?
If so, you may adjust the nailer with an allen wrench, or with a thumbwheel, both of which are located near the firing mechanism.
IMPORTANT: before you mess with it, be sure no pressure is left in the unit, otherwise you may be on here asking how to extract a framing nail from your skull while your hand is attached!
Nov 25, 2009 | Stanley Air Tools & Compressors
Framing nailer not setting nails
If your compressor pressure is right (im sure it is) there is a plunger located above the point where the nails come out. A moderately size tool store (not home depot) should have a rebuild kit. For me.it was where I bought my nails
Apr 05, 2009 | Porter Cable FR350A Factory Reconditioned...
Nails won't set
The Bostitch should have a one-touch depth-mechanism with seven settings. You should make the required adustment(s) to this mechanism to alter the nail depth.
Note: While it is at first glance easy to use, after switching the settings a number of times it may become apparent that the coarse settings lack the refinement necessary for smooth and detailed adjustment.
Jan 14, 2009 | Stanley Bostitch N88rh Framing Nailer...
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
438 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
