Philips SA3125\02 MP3 Player Logo
Posted on Nov 01, 2007
Inability to play recorded songs
OnceĀ I have selected my song, I am unable to play it by pressing the play button
A
Anonymous
Maybe the music you are trying to play is protected as many music you buy over the internet is. try loading your player with music you ripped from a cd or make sure the protected music is transfered directly to your player with the program you bought the music with.
6helpful
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
Hi I have windows7 on my laptop. I am unable to remove songs from my Scandisk. Media player also should be latest. Can you guide me how to remove or add songs in my e260 .
By pressing and holding the Select button while listening tomusic, the player will automatically detect whether the current song isalready in the "Favorite List" and guide you to add/remove the songfrom the Favorite list.
STEP 1 - Enable "Advanced mode"
1. From the Main menu, select Settings > Advanced
2. Select On.
STEP 2 - Add song to the "Favorite List"
1. During music playback, press and hold the Select button.
NOTE: If the song is in not in the list, a confirmation message for adding the song to the list will be shown.
2. To add, press the Select button when the check box is highlighted. To cancel, press the |<< button to highlight X check box then press the Select button.
STEP 3 - Remove a song from the "Favorite List"
1. During playback, press and hold the Select button.
NOTE: If the song is already in the list, a confirmation message for removing the song from the list will be shown.
2. To remove, press the Select button when the check box is highlighted. To cancel, press the |<< button to highlight X check box then press the Select button.
I can't drag and drop music from my library to the sansa clip. I have downloaded songs using Rhapsody and I can see where my device is but it wont allow me to drag my songs to it... I have purchased the...
Account Status
You need to connect to Rhapsody once every 30 days to continue playing your subscription tracks. When you reconnect, the 30 day license is renewed. The indicator will change from full circle to a quarter cycle as the days pass, and you will be warned when your tracks are about to expire.
Rate This Song
1. In playback mode, press the Submenu button.
2. Select Rate This Song.
3. Press |<< or >>| to change the rating (Negative to 5 Stars)
4. Select Negative to ban this track from playing again.
Purchase
2. Select Purchase This Song.
3. When you connect the player to Rhapsody To Go, the track will be added to your Purchase Bin. You can decide if you would like to purchase it at your leisure.
Add To Library
2. Select Add Track to Library
3. A confirmation message, "Song has been added to your Library". Your song will now be a part of your device Library.
Artist Info
To display the artist information, press the center button 2 times when the song is playing back.
Account Info
1. From the Main Menu, select Settings.
2. Select Account Info.
6helpful
The ma933a nextar model skips over songs every 10 secs!
you have the play mode set to "intro",
how to solve this;
1) start playing a song.
2)Press the "Mode" button quickly, don't hold it down, just press it quick.
3)Select Play Mode by pressing the Mode button
4)Select "N" normal
all done.
2helpful
2answers
Cant delete files from mp3 player
While the song is playing press and hold down the MENU button. That should take you to the list of songs otherwise you'll get an option for either File Navigator or Playlists. If so, make sure File Navigator is highlighted, press the OK button (centrally located on lower front). In either case, make sure the song you want to delete is highlighted then press the Record button (the one with the dot on it). Use up or down, if Delete is not already highlighted, then press the OK button.
It will not let me delete all my songs at once....I really dont want to go one at a time! Any help?
1. Go to the MSC menu
2. Press MENU button
3. When you see a song displayed in the LCD, press the Play key to pause the song
4. Once song is paused, press the MENU button
5. Select “Delete All”
6. Use the Menu left/right keys to toggle between “Yes” delete and “No” don’t delete
-Tha Mp3 Doctor
I cant figure out how to delete songs off my mp3.
5. Select “Delete All” (all) or “Delete File” (one-by-one)
-Tha Mp3 Doctor
3helpful
2answers
ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
1helpful
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
2answers
Graig MP3 problem
will not connect to PC
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
