Question about RIM BlackBerry Bold 9000 Smartphone
Trackball does not functioning properly
It moves side to side, but doesn't go down
Settings could help some, but I tried that originally with my ball as the first step, and it did nothing. It was definitely the ball that was broken (I frequently use lotion and other products on my hands, and I think that created the buildup.) I would suggest getting a new one to fix that issue, if you can. I got a new blue trackball (go knicks!) at www.blackberrytrackball.com
Posted on Jul 01, 2009
    Master:
  • RIM Master
  • 996 Answers
Ball assembly should be change by anexpert
Posted on Jun 03, 2015
  • 541 Answers
Change the settings
select options --> select screen/keyboard --> change the proximity sensor for vertical as 100% --> select Menu --> select save.
Posted on Jun 17, 2009
My trackball doesn't move down on my8310 blackberry
Chances are it's just clogged with dirt
Ok. Follow this carefully cause more people break and destroy their trackballs by not following directions step by step
Carefully pry the grommet (ring around the trackball) off and set it aside. If you look at it. There is supposed to be only 3 pins. NOT 4 so if you have 3 your fine.
Carefully tip the phone over and tap it if you have to, to get the track ball to fall into your hand.
Then I suggest taking a cotton swab, and some alcohol, dip the swab.
Then run it all over the ball as you move the ball in all directions and free up what ever is in there, ie; dirt, dust, stuff from your hands...
Once the track ball can move in the down position or in a complete circle without any problems. Let it dry for like 5min.
Drop it back in carefully. Direction of the trackball doesn't matter. Then carefully put the grommet back in the exact way it came out.
Then it should work just fine.
I've used alcohol to clean mine many many times and never had a problem. Alcohol is different that water, it evaporates and doesn't leave a film or damage.
I hope that helps.
Aug 11, 2011 | RIM BlackBerry Curve 8310 Smartphone
I have blackberry 9630 tour trackball is not working upside rest sides its fine please help me out.
The trackball will move down and to the sides, just not up? Try blowing some compressed air into the gap around the trackball from all sides.
Sometimes the trackball gets sticky from food particles or dirt from your fingers. Wipe it clean with a dry lint-free cloth and see if that makes a difference.
If it still won't go up, there may be dust or dirt particles underneath the trackball. Get a thin strip of paper and try to work it in around the trackball to loosen any dirt or debris. Then blow the compressed air again to remove any dirt found.
Jul 11, 2010 | RIM BlackBerry Pearl 8100
Trackball for blackberry does not move smoothly
What do you mean...can it move in all four directions?
Most trackball movement problems can be rectified by cleaning the trackball. Try the following steps to see if it helps tp resolve the issue you are having;
1) Turn the unit off, open the back cover and pull the battery out,
2) Take a paper towel, dampen it with water...nothing else, making sure that the towel is only damp and not soaking wet,
3) Rub the damp paper towel on the trackball, over and over, making sure to rub up, down, side-to-side and every which way. This should clean the trackball and remove whatever is causing it to not move smoothly.
4) Wait a minute or two and replace the battery and cover. Once the unit has rebooted, try moving the trackball again. It should be better.
Cheers!
Dec 29, 2009 | RIM BlackBerry Curve 8310 Smartphone
My ball wont go left or right. only up & down. what do i need to do?
Cheers!
Dec 29, 2009 | AT&T Blackberry Curve 8300 Smartphone
Trackball only moves sideways not down
It sounds like the trackball has become dirty. If you prise of the silver plastic trackball surround, you can lift out the trackball component and give the small rollers at each side a clean.
Aug 22, 2009 | RIM BlackBerry Curve 8310 Smartphone
The tracking ball rotates but it does not move over the icons on the left side. Is there anything I can do to fix this?
Depending on how comfortable you are with removing the trackball it's not hard to fix... you may have some dirt or grit interfering with the trackball and/or sensors. Take a small screwdriver or blade and gently pop the silver ring around the trackball off. This will free the actual trackball housing. Use an old toothbrush to clean everything. I also soaked the trackball in a little rubbing alcohol. Just make sure it is completely dry before reassembling. If that doesn't work you can purchase replacement trackballs from places like crackberry.com.
Apr 18, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Trackball
Blow into the tracking ball. a little bit of dirt and dust can clog it up.
Oct 30, 2008 | T-Mobile Sidekick ID Cellular Phone
Trackball moves but cursor will only move down and left to right not up
try takign out the batery if that doesnt work click it a bunch of times to losen it up
Mar 27, 2008 | RIM BlackBerry Pearl 8100
Trackerball will go up and down,but when you are not able to select anthing.!
You can try these methods.
If you are having problems with your trackball, here are two ways to make it work better.
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Sidekick Skins
Mar 06, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick3 buttons
The keys may have gotten dirty. So when you push one, it also activates ones near by.
These tips apply to the trackball but you can also use them for the keyboard.
Jan 03, 2008 | T-Mobile Sidekick® 3 Cellular Phone
RIM BlackBerry Bold 9000 Smartphone Logo
485 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
