Question about AOC CT700G 17" CRT Monitor
My AOC 17" CRT monitor displays large veiw on DOS & some PC DOS games where the top portion is displayed at the bottom of the screen.
When in DOS mode & while running DOS-based games the top portion that's supposed to be displayed at the top overlaps the display at the bottom part of the screen.  I am using Palit GeForce FX5200 128MB/DDR nVidia, is there any software that can correct this?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
Sounds like you need to run a screen config wizard. If you have a true Nvidia driver you can do this. Otherwise, re-download the driver from the main website
and it'll work for you
Posted on Nov 01, 2007
I have an LG 17"
First thing to do is determine whether the problem is the monitor or the PC.
Do you have another PC you could try the monitor on, or perhaps a friend will lend you a monitor for an hour or two?
Obviously if the display is ok on another monitor, then the problem is your monitor, however if the display is still "too big" then the problem is the PC.
By the way, when you say the display is "too large" what EXACTLY do you mean?
Dec 13, 2010 | LG Flatron L1715S 17" LCD Monitor
if u are changing ur old monitor to new u may face problem ,
press F8 when the system starts and select the safe mode option and login admin mode change video settings resolution(control panel/display properties) into higer like (1020 pix) and if it visible give yes and restart
May 19, 2010 | AOC LM720 17" Flat Panel LCD Monitor
My monitor changes colors (e.g. normal then turns
Color changes on the display mostly occurs because of a faulty VGA cable or a loose connection of the cable to the VGA port at the back of your PC or Monitor. But if the cable is fixed securely at the back and the problem still persists, slightly move the cable's wire segment while observing its reaction on your monitor. Does it change colors while u do so? If it does even when the cable is securely plugged in to both the PC and the monitor, then u need to change the cable.
As for the visible display area size (technically called the Resolution) right click on an icon free area on the desktop and click Properties. At the top of the form click on the Settings tab. At the bottom of this form find Screen Resolution and adjust it to it your requirements and click Apply. On the confirmation dialogue that pops up click Yes if the displayed resolution suits u otherwise click No and try another resolution size. Hope this helps.
Nov 28, 2009 | AOC CT720G 17" CRT Monitor
No display on AOC 17" CRT Monitor
My AOC 17" flat monitor (model number P7S80) is not displaying properly. Only 80% of monitor is displaying and the edges at the bottom are tapered of. If somebody is having a solution please post it.
Sep 07, 2009 | AOC CT720G 17" CRT Monitor
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
1 Answer AOC 17" CRT monitor display on the screen says NOT SUPPORTED OUT OF RANGE... i try to change the screen resolution by using other monitor but still nothings happen..
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Dec 12, 2008 | AOC CT720G 17" CRT Monitor
"Not support Out of range"
You have to boot your PC in safe mode using press F8 key.
after that you decrease the resolution in the display setting section.
It will help you.
Nov 29, 2008 | AOC CT720G 17" CRT Monitor
AOC 17" Flat CRT Monitor
Could be problem of key switches!
Try replacing or check for leakage,high resistance across switches using ohmmeter.
Jul 26, 2008 | AOC CT720G 17" CRT Monitor
Monitor problem
open your pc remove the ram & clen the ram put it back then after tun it on
i hope your problm is sloved
Feb 27, 2008 | AOC 7 ELr 17 in.CRT Conventional Monitor
AOC CT700G 17" CRT Monitor Logo
131 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
