Question about Toshiba Qosmio G25-AV513 Notebook
Toshibapsl48e touchpad not working what do - Toshiba Qosmio G25-AV513 Notebook
    Scholar:
  • 76 Answers
There can be two problems
1. might be something wrong with ur HW, which is quite negligible, as there is very less possiilty of that.
2. most possibly you dont have installed the drivers for ur touchpad. pls install that and the problem will be resolved.This will definitely solve problem of urs
Posted on Jun 17, 2009
Touchpad won't scroll
hi there.
this is all i could find.
Why my TouchPad is not working in laptop Acer? Enable/disable your touchpad - Many systems allow you to turn the touchpad On or Off by pressing the FN and F7 keys at the same time. ... Reinstall touchpad drivers - Missing or incorrect drivers may cause your touchpad to not work properly. Check in device manager to make sure your touchpad is reporting properly.27 Oct 2014
Touchpad troubleshooting - Acer Community - 307854
community.acer.com/t5/Knowledge-Base/Touchpad-troubleshooting/ta-p/307854 Search for: Why my TouchPad is not working in laptop Acer?
or go to this link and read up some more if you need to.
Acer Aspire Notebook PC Touchpad won scroll Google Search
Nov 27, 2017 | Acer Aspire E1-571-6492 15.6" Notebook PC...
Laptop touchpad not working
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 09, 2012 | Toshiba Computers & Internet
Touchpad not active
hope this helps
Sep 05, 2012 | Computers & Internet
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Click "Start." Click "Control Panel" in the right panel.
Click "Accessibility Options."
Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
Click "OK" to unlock the keyboard, including the keypad.
Unlock Touchpad
Click "Start," then "Control Panel."
Click "hardware and Sound," then "Mouse."
Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Apr 13, 2012 | Dell Inspiron Computers & Internet
I recently bought a HP 430. It has a small touchpad light (left top corner)which is not working from the day i bought. I use mouse and touchpad sometimes. The Manual says by tapping the touchpad twice on...
i've installed this program http://touchpad-blocker.com/download/
it worked fine for me.
I had issues with the touchpad clicking while i type. it was so **king annoying
Aug 21, 2011 | HEWLETT-PACKARD ProBook 4320s C Notebook
How to unlock touchpad of hp probook 4520s laptop
Touchpad zone is on upper left of the touchpad:
Turning the TouchPad on and off
The TouchPad is turned on at the factory. When the TouchPad zone is active, the light is off.
To turn the TouchPad on and off, quickly double-tap the TouchPad off indicator.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 02, 2010 | HEWLETT-PACKARD ProBook 4520s
My touchpad stopped working on my acer 5532. I
> you just have to reinstall driver for your touchpad but if after doing that and still not working then touchpad might be busted
> sometimes a certain software might be causing the touchpad to not work and restoring computer to factory default might resolve the issue but this will cause your files so do a back-up first
> to get the driver for your touchpad please refer to your manufacturer or to the website of acer
Jun 05, 2010 | Computers & Internet
My touchpad buttons do not work
hi locate the FN key on lower left side of keyboard next locate the touchpad key usually one of the F1-F12 keys,press and hold the FN + the touchpad key together and release, now check the touchpad.
good luck,
let me know how it turns out.
ken
Apr 04, 2010 | Dell F3534 Touchpad
Dell Inspiron 600M Keyboard Replaced, now touchpad doesn't work
need to pick up the keyboard and make sure the ribbon cable to the mother board is fully seated. if it is. then the touchpad need to come out and clean it very carefully. the sugar and any sticky substances need to be clean off the machine, around the touchpad.
I hope the drink did not damage the touchpad.(it is heat senstive)
if it still don'e work aft reinstalled it. you need to call dell to get a replacement.
Nov 13, 2008 | Dell F3534 Touchpad
Toshiba Qosmio G25-AV513 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
