Question about Kenmore 51840 Kitchen Hood
Dimmer light won't work.
Kenmore model 233.52052002. The bright light works but the dimmer (lower intensity) does not. The hood has 2 bulbs and I tested both - they're ok. It seems to be something electrical within the hood, because when I which to dim (lower light), it simply goes dark. ???? Thank you.
  • 146 Answers
You are using incandescent bulbs because most dimmer will not work with Fluorescent otherwise sound like a bad switch, if it new return it. They are fairly easy to replace. Hope this Helps Paul
Posted on Jun 19, 2009
Viking range hood dimmer switch
Sorry we have no part locating services here at this website.
Apr 17, 2017 | Kitchen Ranges
Dash lights do not work 2000 ford exploier
All go out at once, first check fuses,then dimmer switch for dash lights, finally headlight switch. To check dimmer switch, pull connection off back, on harness with test light and headlight switch activated, 1 of the leads should have power, if so, use ohm meter on dimmer to make sure it has reading between 0 and some value, if no value, open, dimmer is bad, if there wasn't power then check headlight switch, there should be heavier gauge wire that powers switch and 1 for output to hi/lo switch, smaller gauge wires for tail lamps, dash lights, license plate lamps, parking lights. The color wires from dimmer would correspond to the same colored wires on headlamp switch, probe that connection on headlamp switch with switch engaged and see if you have power, if not replace switch, if so, check wire from switch to dimmer.Now if the lights slowly went from bright one day, to less bright some other day, to not working, then the bulbs are bad... good luck...
May 14, 2012 | Cars & Trucks
I want to set up two household light (AC) both of which are to be controlled from one switch with a dimmer. can I connect the lights in in series or do I have to connect them in parallel with two separate...
The dimmer controls the intensity of the electric current flowing in the circuit, hence controlling the light intensity emitted from the bulbs. I believe a series connection with one switch will suffice.
Jul 23, 2011 | Office Equipment & Supplies
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
Lutron dimmers throught the house, lights go high brightness to low all by themselves, is this just a bad dimmer?
I have spent considerable time on the Lutron site past couple days looking at their dimmers.
Lutron has a lot of dimmer varieties. The basic breakdown is 600Watt and 1000Watt. But different dimmers control different types of lighting.
Here is the long list of Lutron dimmer manuals:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
I cannot find a specific troubleshoot manual for Lutron dimmers
So I suggest 4 things:
1) Feel the dimmer switch for heat >>> if it is getting hot (not warm), then that dimmer is dangerous, so remove dimmer immediately, add up your total bulb wattage to make sure you're below the 600 or 1000 watt capacity of you model dimmer
2) Look at the list of manuals shown at link, and make sure your dimmer matches the type of bulb you are using. Your dimmer model number and wattage should be printed on side or back of dimmer.
3) These dimmers use electronics to control the lights. Electronics go bad. The higher the wattage controlled by your dimmer, the more heat, and the shorter the dimmer life.
4) Short in the wires. Replace your dimmer with one from Home Depot and see if the condition persists. If it does, then a short is probably somewhere in that circuit. Troubleshooting a short is another long answer that needs more wiring detail ... please repost if you have a short.
Oct 17, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Dimmer Switch
It could be how you have it wired. 2 way switches can be tricky. One of switches will have a wire run to the chandelier and this is where your dimmer should go. Here's a link to a explanation of 2 way wiring. Hopefully this will help. If you want to check to see if it is the bulbs, you could put in non energy efficient bulbs although I think it's another problem. If it was the bulbs, the dimmer would at least turn on the energy efficient bulbs in the low position. Good luck!
Link to 2 way switch diagram
http://2wayswitch.com/2-way-switch-wiring-diagram/
Mar 15, 2010 | Leviton Toggle Touch Dimmer - TGI06-1LB -...
I have installed dimmer switches in the living room. They started off reasonably bright, but after time the maximum brightness is considerably reduced. I have replaced one of the dimmer switches, which...
when you dim a light it increases the resistance,when you increase resistance it causes heat, the more watts you are trying to dim the more heat you create, heat will cause anything to break down, so add up all your light bulbs and make sure your dimmer can handle that many watts, use lower wattage bulbs and maybe a higher wattage dimmer
Dec 30, 2009 | Electrical Supplies
Light flickers when dimmer switch isn't ''just right''
Compact fluorescent bulbs do not work on dimmers.  You have to use standard incandescent bulbs or not dim the lights.
Mar 20, 2009 | Hampton Bay 52 In. Brushed Nickel Romano...
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Kenmore 51840 Kitchen Hood Logo
216 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
