Question about Microwave Ovens
GE JES1358WL stopped working
I have a GE JES1358WL - a little more than a year old. It suddenly stopped working.
When I start it, it sounds just fine but does not heat at all. I am a novice with microwaves. Any help is appreciated.
I had a very similar situation with my microwave where it seemed like it was operating (light turns on, turn table turned, exhaust fan ran) but would not heat food. Everything else sounded normal (no electrical zaps or pops). If i tugged VERY gently on the door I could hear the magnetron kick on (deep hum). If I left the door alone teh magnetron would kick off. One of three door switches was acting up and prevented the magnetron from generating microwaves. Depending on the design of your microwave one (or more) door switch(es) will prevent the the magnetron from being energized and the other door switches operate the light, fans etc. I replaced one door switch and the everything worked great again.
Posted on Oct 28, 2015
  • 100 Answers
More than likely your H.V. Diode took out your Magnetron or vise virsa. Check your users manual about the warranty because after 1-1-06 the warranty on most appliances went to a straight 1 year parts and labor.
Posted on Nov 02, 2007
  • Microwave Ovens Master
  • 8,858 Answers
Since this is just over a year old, you'll still have a part warranty on the magnetron, at least, in case it went bad.
Plus you can save about $50-75 if you remove it from the wall and take it to a GE-authorized servicer, You can find one by calling GE Appliance Service 1-800-848-7620.
Removing it from the wall is ideally a 2-person job and you should have your installation instructions handy. If not, you should be able to find it here: http://www.geappliances.com/service_and_support/literature/
That being said, generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
We appreciate your thoughful rating of this answer.
Posted on Nov 01, 2007
  • William Miller
    William Miller Nov 01, 2007
    Yes, that's correct.
  • 790 Answers
HI!
can you see the power light? if yes! maybe you have defective thermal fuse thats connect to Filament, this is busted thats why your Filament is not working
My GE over the oven microwave does not heat (1.5 years old). The heating and turntable stopped working at the same time. When you start it, it sounds fine, but nothing heats. You can hear a relay or...
It does sound like a relay malfunction or similar switch. Could be repaired but call for a quote or better yet, take it to a repair depot (probably cheaper).
Dec 13, 2014 | GE Microwave Ovens
Ge jvm1850sm2ss suddenly does not heat food any longer
time for a new one... new ones are cheaper then the parts
Apr 08, 2014 | Microwave Ovens
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 06, 2010 | GE JES1358 Microwave Oven
My Panasonic Inverter S333 just suddenly stopped working. I get a "refer to manual" message. Manual has no help to offer. Even the "signal bell" sounds a little off. Up until today, it was working just...
My Panasonic Inverter S333 just suddenly stopped working April 30 after I used it for only two years, no showing in panel. It will run only when I open the door, it is strange.
Apr 19, 2010 | Panasonic NN-T694SF Microwave Oven
GE PVM1870 turntable not working
The little brown thing is broken. I have several break or melt. Pull it out and look at it.
Nov 18, 2009 | General Electric PVM1870 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE JVM 1650BB does not heat...
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.Mine had a ten year warranty on parts.
Oct 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
My spacemaker GE 1440 do not heat it 2 years old
Hi tony,
The units magnetron(the device that generates the micro waves) is failed or failing, this can be DIY depending on how mechanically inclined you are.
anaanymous
Oct 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave has stopped working and switched on suddenly!!
Sounds just like a bad door switch or door switch mount. Probably the upper one. Safety info, disassembly tips, and door switch test and replacement info are all available at our Web site. See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
300 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
