Question about ASUS F3E-B2 Intel Core 2 Duo T7250 2.0GHz 15.4in 120GB HDD 1GB DDR2 667 802.11 a/b/g DL DVD +- R/RW ... PC Notebook
The laptop appears to be rooted.
We installed sims 2. The computer stopped working (frozen). We managed to uninstall sims 2. The computer still wont work (still frozen) and when it does it is slower than anything on this planet. Its been reset a few times, and it wont even work in safe mode.
    President:
  • ASUS Master
  • 1,996 Answers
Clean out your temp files.
Run chkdsk c: /f (instructions here)
Follow the instructions in this link to scan for malware. Remove any problems mbam finds.
Report back...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 17, 2009
How to enable usb port LG 22LD330
On the desktop, right click on MY COMPUTER, and then select MANAGE option. a new window will appear, in that select SYSTEM TOOLS, in that click on DEVICE MANAGER, on the right side of the window pane, a list wil appear,
If USB is enabled in BIOS or EFI but the USB host controller does not appear in Device Manager (under Universal Serial Bus controllers), or a yellow warning icon appears next to the host controller name, then the version of BIOS or EFI may be outdated. Contact the maker or vendor for your computer and obtain the current version of BIOS or EFI.
If the controller appears in Device Manager, right-click the controller name and then click Properties. Problems and suggested actions are displayed under Device status.
USB ports have a separate entry in Device Manager. To check the device status, click Universal Serial Bus controllers, right-click USB Root Hub, and then click Properties. If you do not see USB Root Hub, you might not have a USB port installed on your computer
On the USB Root hub Properties page, it may tell you this device is working properly, or there is a Troubleshoot button. At the bottom you have an option to Enable or Disable the USB hub.
Jan 22, 2014 | LG Computers & Internet
Tip
USB DEVICE DOES NOT recognize
Issue:: USB DEVICE DOES NOT recognize
___________________________________
Manual Troubleshooting for this issue::
-Open device manager
-Right Click on USB Root Hub
-Choose Properties >>Selet Power Management
-Remove the Tick Mark Before "Allow the computer to turn off the power if device is not in use..."
-Do the same for all USB ROOT HUB
-Then Uninstall all USB ROOT HUB
-Restart your computer , USB device will be working.
on Jun 21, 2010 | Computers & Internet
Errorcode43
Windows has stopped this device because it has reported problems. (Code 43)
uninstall the device and install again the newer driver.If it happens again that mean that device is died and need to be replaced
Mar 11, 2012 | Computers & Internet
HP J6450 printer keeps going offline
Have you tried reinstalling the printer driver?
Have you also tried to restart the printer spooler service?
Here's how to do it:
To start and stop the print spooler
  1. Open Computer Management.
  2. In the console tree, click Services.
    Where?
    • Computer Management/Services and Applications/Services
  3. In the details pane, double-click Print Spooler.
  4. Do one of the following depending on the task you want to do:
    Click Stop to stop the service.
    Click Start to start the service.
Also you can try to uninstall / reinstall the USB Root Hubs in the Device Manager:
    Directions
  1. Step 1 Click on the "Start" icon on your computer's desktop screen and access the "Control Panel" menu, which will be listed as a Start menu subtopic. When the Control Panel window opens, select the "System & Maintenance" link, which will be the first option listed on the screen.
  2. Step 2 Select "Device Manager" when the system's components and operations appear on the following screen. Bypass the Administrative Control prompt by clicking "OK".
  3. Step 3 Select the "Universal Serial Bus" collapse tab, which will be the last option listed at the bottom of the Device Manager menu. A list of blank locations where your drivers should be located should appear in the collapse menu. The driver items in the list should read, "Driver Not Installed".
  4. Step 4 Right-click on one of the drivers that reads "Driver Not Installed." Select the "Properties" option in the drop box list that will appear. A pop-up dialog box, regarding the driver, will appear on your screen. Click on the "Driver" tab and select the "Update Driver" tab. The device will restore any missing components that are prohibiting the USB Root Hub's functionality.
Feb 27, 2010 | HP Office Equipment & Supplies
My Tata Photon Plus USB Modem is not being detected in my laptop. Previously it used to work (for almost 3 months). But now all of a sudden,it is not being detected no matter what. It works on my other...
I just solved the same problem on my laptop with the help of Tata's tech support -
first, plug in the Photon plus modem, remove any other usb devices (mouse, etc)
right click on My Computer, select "manage". Click on Device Manager, expand the list of Serial Bus Conductors.
Right click on each "USB Composite hub" (not root hub) and uninstall.
after all composite hubs are uninstalled, go to the "computer" section at the top of the list in the Computer Management box. Right-click on "Computer" and click on "scan for hardware changes". Yiur system will reinstall the drivers and give you a notification at the bottom right corner of your monitor. Once u get the message "drivers successfully installed", open the Photon plus dialler and connect. It worked for me, hope it works for you too!
Jan 28, 2010 | Computers & Internet
USB Hubs won't install
Please install the usb hub power surge patch from www.dell.com/support
Aug 24, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
Usb ports not responding
Ports are need to be re soldered or replaced.
Mar 18, 2009 | Computers & Internet
2 of 4 USB Ports Not Functioning
Most likely a motherboard problem, though you can try and re-do windows, best bet on getting it all to work is Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Though this might really get on your nerves having to do this multiple times, id get a new motherboard.
Dec 26, 2008 | Gateway 4540GZ Notebook
Keyboard
uninstall the driver and reinstall it.
goto:
start> control panel > admin settings> computer managment> device managment> human interface (keyboard joystick mouse etc...)
only uninstall the keyboard but realise when it is un installed it wont work! untill you reboot the computer and reinstall it.
good luck
Oct 29, 2007 | Toshiba Satellite M30X-S181ST Laptop
ASUS F3E-B2 Intel Core 2 Duo T7250 2.0GHz 15.4in 120GB HDD 1GB DDR2 667 802.11 a/b/g DL DVD +- R/RW ... PC Notebook Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
