Question about HP LaserJet 2840 All-In-One Printer
I have a hp laserjet 2840. Screen says scanner error 6. turning off and on did not help
    President:
  • 1,952 Answers
Tools:
1 - torx screwdriver
1 - flathead screwdriver
1 - microfiber or some cleaning that doesn't leave dust
Fix:
  1. Turn off the printer
  2. Take the ADF unit off: unplug the power connector of the ADF unit and pinch the holding brackets
  3. using torx screwdiver remove the screws on top of scanner unit
  4. using the flathead carefully lift the top of the scanner unit (including the glass)
  5. using microfiber clean the inside of the glass, especially the area with the "black/white" bars. This is the "Home" location of the scanning head. DON'T USE any spray or liquid!!!
  6. gently move the exposed scanner head (that's the thing the glows and moves) about 1/2 inch from the home location to the left.
  7. Reverse the steps above to put the glass and scanner
  8. Once the printer is on, the scanner head will be lost and will seek the "Home" location. Now that the "Home" location is clean, it will find it. Error should disappear. If it does not then you need to move the scanner head more the 1/2 inch.
Posted on Jun 17, 2009
  • mohammed marika thambi
    mohammed marika thambi Jun 17, 2009
    I hope engine error it went into service at an authorized service provider since
    they have the ability to call hp technical support which should have
    some answers as to what the problem may be.
    These errors can be cause by many
    reasons. Communication I/O errors, memory bus, image decompression and
    complex image printing are examples.
    Visit the CLJ2820 support web site at
    HP.com to compare the latest available firmware to what is indicated on
    the configuration sheet under the Product information block - firmware
    datecode.
I have an HP 2840 color laser jet that keeps presenting a Scanner Error Code 6. Might anyone know if and how I can repair this on my own? Thanks a ton! Mike
replace optical scanner assembly..(a unit located in flat bed scanner with florocent lamp moving left to right while scanninf & copying)
Sep 17, 2011 | HP LaserJet 2840 All-In-One Printer
Errore scanner 6 alla accensione su hpljcolor 2840
The printer needs to have the "scanner/copier" assembly replaced.
Mar 06, 2011 | HP LaserJet 2840 All-In-One Printer
Scanner error 5 on HP Color Laserjet 2840
Scanner Error 52 is a hardware error. If turning the power off , waiting 30 seconds and turning it back on does not solve the issue the the scanner assembly might need to be replaced. Another thing to try is make sure the printer is plugged into the wall not into a surge protector. Aside from that you may need to have the scanner assembly replaced.
Dec 09, 2010 | HP LaserJet 2840 All-In-One Printer
I am getting scanner error 5 massage on hp 2840
A tech needs to look at it. It could be as easy as just reseating the 4 wire bundle connector that comes off the scanner and connects to the formatter.
But, in any event a tech has to check it out.
Jul 29, 2010 | HP LaserJet 2840 Printer
52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Mar 22, 2009 | HP LaserJet 2840 All-In-One Printer
Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Dec 07, 2008 | HP LaserJet 3050 All-In-One Printer
Scanner Error 6
clean glass. switch off. clean the lightsource bulb. keep fingers off the glass when cleaning
Apr 17, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Apr 16, 2008 | HP LaserJet 2840 All-In-One Printer
Scanner error 6
in my network i have hp M1005 printer always i'm getting this msg "scanner error 6 turn off
then turn on"
when i make turn off and turn on again same msg comming
how can i solve this problem...
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 2840 All-In-One Printer Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
