TV won't stay on
My Mitsubishi WS-65711 will not stay on. I turn it on, the green light is solid for about 5 seconds then I hear a click from the back and the green light goes out.
  • chefmarty200 Jun 17, 2009
    What are STK ICs?
  • 5,138 Answers
Replace both of your STK ICs will have part number on them.
Posted on Jun 17, 2009
  • ladywinn
    ladywinn Jun 18, 2009
    They are your convergence ICs most of the time one goes bad it is the one that controls start up,But you must replace both of them if they are STK392-110s use 180s,look for big black ICs with STK on them.
I have a WS65711 - 3 months ago I replaced the Convergence - Today the TV was on then turned itself off. I have tried to turn on but it just turns off after 30 seconds
Did you do the diagnostic self check:
when green power light goes off on the front of the set press and hold both Menu and Input(Device) buttons for 5 seconds and release both.
Power light will blink two digit error code like: 2 pause, 2 and repeat it at least 5 times.
Let me know what code you find and I will try to help you.
SD TECH
Jan 05, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65711 Front Lock
Bypass Mitsubishi WS-65711 Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Mitsubishi WS-65711 Manual Download
Reset Mitsubishi WS-65711 VChip Password
on May 04, 2010 | Televison & Video
Tip
I hope that helps.
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
Ws65711,8 years old, working great with out problem until this one..turned off the tv normally after use, then when tried to turn on again... it turns on (green light turns on. no pictureno...
SD TECH,
Just started experiencing convergence problem with my Mits ws-65711. I have decided to try to repair on my own and have the service manual. I see also you have step by step instructions for the repair and perhaps photos of the fuses. I could really use this info if you are able to provide.Thanks in advance. I did the self check by holding in MENU and INPUT buttons and got 1 green blink followed by 2 shorter/quicker green blinks?
Aug 30, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Tip
Bypass or Reset Mitsubishi WS-65711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Tip
I have a Mitsubishi WS 65711 When I power on the TV the green light (power...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a error or not and point you in the direction of your trouble.
Based on the error code I or others can tell you more based on the error code and the EXACT model number of the set.
Here is what you do if it turns on for a few seconds and then the power light goes off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “Menu and Input"(or device) buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If someone has one of these codes and needs help let me know.
SD TECH
on Dec 20, 2009 | Televison & Video
TV will not turn On
Call a good TV Tech and have him check for vented capacitors in the DM module or blown pico fuses on the -24 and the +24 volt lines.If fuses are blown,it indicates the convergence amp IC's are bad.The fuses solder into the board.
Jul 28, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Tv will not power up, shuts off after 10 second
http://serviceman.site88.net/index_files/MitsubishiTV.htm
Oct 01, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
