Question about Frigidaire Washing Machines
I have a Frigidaire easy load super capacity washer model GLTF2940FEI when I push the start or cancel button it reads lock what can I do to clear this mode?
SOURCE: kenmore super capacity 3.5 front loading washer
It only cost me $86.85 for a service guy and about 2 minutes, but it's running again. There was a magnet that fell out of the soap tray. The magnet is for a sensor. It simply clicks into the right side of the tray. You must unclip the white front part from the gray tray. In the right side of the white peice is a slot for the magnet. Clip the magnet back in andclip the white and gray parts together. Slide the tray in and it should go.
Posted on Feb 11, 2008
Jimster
  • 240 Answers
SOURCE: WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Posted on Feb 15, 2008
  • 1073 Answers
SOURCE: Frigidaire Washer machine with burning smell
burnt belt, tight center tub bearing, motor going bad, loose idler pulley spring, wiring issues at the motor, a lot of could bees
Posted on Apr 12, 2008
  • 1073 Answers
SOURCE: FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
SOURCE: Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
Posted on Aug 19, 2008
Why can I not clear the e1 f5 on electric stove super capacity by pushing cancel on whirlpool super cacity 465
No model or manufacture but F5E1 usually relates to door latch not operating properly the computer reads the position of the micro switches located with in the latch if the motor on the latch goes bad and does not return the latch to the correct position code will pop up power off the unit wait 15 seconds turn back on you should hear the latch motor it will lock then unlock if it doesn't move it will fault out hopes this helps.
Feb 20, 2015 | Whirlpool Kitchen Ranges
Washer won't start - sometimes
Jason, take a look at this link and follow the steps very carefully. Were insulated golves. How to Fix an LG Front load washer machine that wont spin
Feb 28, 2014 | Frigidaire Washing Machines
I just got this washer and no book. I pushed all buttons to get started and it keeps flashing CL. We have un pluged to clear it out so I can start over but no luck there.
CL is Child lock. Press the start/Pause and cancel button for 3 seconds to clear. If your unit has a padlock led press and hold that for 3 seconds to clear the child lock.
Somehow I get the feeling the model listed above is not for your machine as it is a top loader with manual controls.
Your use and care manual can be found here:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
If that link does not work use this one and type in your model number WPRE6100GWT.
May 19, 2010 | GE Profile WPRE6100G Top Load Washer
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
Kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
Jun 24, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Machine shows Cl on dispay
cl is over loaded push stop clear to clear then try again with a lighter load
Jan 30, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
206 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
