Motorola Mobility RAZR V3i Cellular Phone Logo
Posted on Nov 01, 2007
Text messages how di i retrieve my text messages? I get a 10000000 code with the date but when i pres the options button it does not display the message.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 02, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
65
Points
Try this one first delete all read txt message in your inbox then you can read the incoming ones... but this has no assurance
2answers
How do i retrieve accidently deleted message from my AT&T phone model 1855
Unfortunately, once a text is deleted from the device it isn't able to be retrieved. Now if it's a different kind of message you may have some options. The only way to get that text back would be to have it resent.
tip
How to Retrieve Deleted Text Messages from iPhone 6 (Plus)
- PhoneRescue focuses on recovering the most important 22 types of iOS content, including messages, contacts, notes, photos, app documents etc.
- PhoneRescue is capable of retrieving SMS, iMessages, MMS, including the images and attachment.
- PhoneRescue allows you to selectively scan and recover the messages which greatly saves your efforts and time.
First of all, download and install an iOS data recovery tool PhoneRescue on your computer to start recovering the deleted messages from iPhone without any backup.
1. Open up PhoneRescue, and connect your iPhone 6 (Plus) to the computer.
2. On the homepage, click "Recover from an iOS Device".
3. Select Messages, and click "Start Scan" button.
4. Now you can view the deleted messages, and choose the text messages you want to retrieve, then click the Recover button on the bottom-right of the window.
Resource from:
How to Retrieve Deleted Text Messages from iPhone 6 Plus
on Dec 04, 2014 • Apple iPhone 6
tip
How to delete multiple text messages on a Samsung Intensity
On many mobile phones, you only have two options for deleting text messages: deleting one message at a time, or deleting a whole folder at a time. However, the Samsung Intensity (among other phones) gives you the option to delete multiple text messages at once without deleting an entire folder. You just have to know how to do it.
Go into the Messaging menu, either by pressing the upper left option button or by going into the main menu and selecting Messaging (option #2). Select your inbox, then press the upper right option button (Options). Select #9, Msgs View by Contact. The text messages in your inbox are now grouped according to who sent them.
From this view, you can delete multiple text messages at once. Press the upper right option button again and select choice #2, Erase Multiple. Now as your messages are displayed, there is an empty box next to each one. Scroll down through the list and select the messages you want to delete by pressing the center of the directional pad. A check will appear next to that message. To uncheck a message, repeat the same process.
The only messages you won't be able to delete are messages that you've previously marked as locked. If you want to delete a locked message, you'll have to unlock it first, then delete it.
Once you've put a check next to all of the messages that you want to delete, click the upper left option button (Done) and you'll see a confirmation message. Choose whether you want to delete all of the checked messages or only the unread ones, and then click the directional button (OK). The messages you selected will be deleted.
To resume having your messages displayed in chronological order, click the upper right option button and choose option #4, Msgs View by Time.
4answers
Recover deleted messages
There are lots of different methods to recover deleted messages. You can follow below steps to reach your aim.
After you delete messages on iPad, you suddenly find that the messages are useful, what should you do? Actually, the iPad delete messages can be recovered. This part will tell you how to retrieve deleted messages on iPad in detail. I recommend you use Leawo iOS Data Recovery to help you solve the issue on how to recover deleted iMessages on iPad, for this tool is quite useful to recover files and data on iDevices that have been lost, damaged or deleted. All iDevices can use Normal Mode of Leawo iOS Data Recovery. Only iPhone 4 and iPod Touch 4 can use DFU Mode now to solve how to recover deleted iMessages on iPad. You could refer to the following steps to check how to retrieve deleted messages on iPad.
1. Connect iPad to PC and Choose Normal Mode
Plug your iPad into PC and launch Leawo iOS Data Recovery, and then tap the option of "Recover from iOS Device". A window will pop up to ask you "Whether to enter DFU mode", and you need to click "Normal".
2. Click on "Start"
Tap "Start" button to start scanning the iPad data.
3. The Scanning Process
When the scanning starts, wait until the process is over.
4. Tap "Messages" and "Recover"
When the scanning process is over, your iPad data will show on the left side of the panel. Tap "iPad > Messages" to check all messages on the right side of the screen. Then tick "Only display the deleted items". Choose the iPad delete messages you want to recover, and click on "Recover" at bottom right of the interface.
5. Set Output Path and Recover Messages
A dialog will pop up to direct you to save the recovered messages to a folder you set. Tap "Open" on the right side of "Save to" to select a folder on PC to save the retrieved iPad delete messages. You can check "Automatically open the output folder after finishing recovery" if you need. Click on "Go" button to begin the data-recovery procedure, and you can recover the iPad delete messages to your computer.
As mentioned, this software enables users to recover various kinds of files of iDevices. If you have deleted other kinds of files by mistake, you can also use this tool to help you. Once you use this program, you will find how powerful it is to help you solve how to recover deleted iMessages on iPad.
delete-messages-and-recover-deleted-messages-11-vrpz42mk1tbypv5oo32zlffx-3-0.jpg For more details, check: How to Recover Deleted iMessages from iPhone/iPad/iPod touch
2answers
iTunes and iCloud both backup the data in your iPhone as a whole so you can only get all the data in the iPhone backup together back to your iPhone. If you want to recover deleted text messages from iPhone 5s separately, you may need third party iPhone data recovery software. I would like to recommend Leawo iOS Data Recovery to you because this software is helpful and easy-to-use. It is used for recovering lost files from iDevices and iTunes backups. The software also enables users to backup iPhone, iPad and iPod touch files to computer. Leawo iOS Data Recovery will export the recovered text messages to CSV and HTML files so that you can view the files with your computer.
The following guidance will show you how to recover deleted text messages from iPhone. You are able to free download the software and have a try yourself. Note that the trial version stops at the preview window.
1. Run Leawo iOS Data Recovery on your computer, and you will see three recovery modes in the main interface, including "Recover from iOS Device", "Recover from iTunes Backup", and "Recover from iCloud Backup".
2. Choose "Recover from iOS Device", and connect iPhone to computer with the USB cable. The software will recognize your iPhone and check it at the bottom list. Click the "Start" button in the window to let the software analyze your iPhone 5s.
3. After the Analysis of the iPhone, the software will begin scanning the contents in the iPhone. When the scan is done, the names of the categories in the left sidebar will turn white. Choose "Messages" and then the contents will display in the right part of the window. Check the messages you need and then click the "Recover" button at the right bottom of the window.
4. The dialog of recovery settings pops up after clicking "Recover". Click "Open" in the dialog to choose a target folder on your computer and then click "Go" at the right bottom of the dialog.
For more methods, check: How to Recover Deleted Text Messages from iPhone
2helpful
2answers
How do i put a signature on a pantech link
Text message signatures are the post scripts at the end of text messages. Some people use text message signatures to provide an unrelated, off-top status update to the recipients of their text messages. Other people use text message signatures to attach a favorite quote with every outgoing message. If you own Pantech's Link handset, you use the device's messaging templates to attach a signature to your text messages.
steps:
  • Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
  • 2
    Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
  • 3
    Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
  • 4
    Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
  • 5
    Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
  • 6
    Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
  • 1helpful
    I have mms. how can i see it?
    1. If your message is received, you will see it in the INBOX folder.
    2. If it has not been retrieved, retrieve it (make sure you have proper settings for the MMS to work). Highlight the message and click left softkey (options) and look for similar options to retrieve message from your network operator.
    3. After you have retrieved it simply read like you are reading text messages.
    2answers
    I have a 1998 Chevrolet Corvette (C5), which after changing out the battery, has initiated theftlock. I was not the one who set the code to unlock it, so that poses a problem. On other forums, I noticed...
    TRY THIS TRICK .THE PASSIVE SWITCH IN OFF POSITION. STAND 5 FT OF THE VECHICLE .PRESS AND HOLD REMOTE TRANSMITTER LOCK AND UNLOCK BUTTONS FOR 7 SECONDS.HORN CHIRPS TO CONFIRM SYNCHRONIZATION. NOW SWITCH IGNITION ON. SWITCH RADIO OFF. PRESS THE RESET BUTTON ON THE DRIVER INFORMATION CENTER DIC IN ORDER TO CLEAR ANY INSTRUMENT PANEL CLUSTER IPC WARNING MESSAGES. PRESS AND RELEASE THE OPTIONS BUTTON ON THE DRIVER INFORMATION CENTER DIC TO SCROLL THROUGH OPTIONS UNTIL THE INSTRUMENT PANEL CLUSTER IPC DISPLAY IS BLANK.PRESS AND HOLD THE RESET BUTTONS FOR 3 SECONDS. PRESS THE OPTIONS BUTTON UNTIL FOB TRAINING MESSAGE IS DISPLAYED.PRESS THE RESET BUTTON IN ORDER TO START THE PROGRAMMING MODE.THE MESSAGE HOLD LK +.UNLK 1ST FOB WILL BE DISPLAYED. IF THIS DONT WORK DEALERSHIP FIX.THEY HAVE TO USE DIAGNOSTIC EQUIPMENT TO RESET THEFT SECURITY SYSTEM.
    2answers
    On my incoming mail with Yahoo, the type face is very small and hard to read, any ideas on how to increase this size
    "Ctrl" + "+"
    ie. hit "+" key while Ctrl key is pressed.
    Please Rate if you find above info useful.
    3helpful
    4answers
    Deleted text message that i need
    if it was deleted after you last synced with iTunes you can restore your phone this will put all messages and data that was on the phone when last synced
    i can email you instructions
    Top Motorola Mobility Cell Phones Experts
    AFIFUL HAQUE MUFTI...
    Level 1 Expert
    vince
    john h
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
