Question about Craftsman Garden
Sent blower in for repair,was fixed. Told it was a muffler issue. Started using it, it ran for a while,then it just died out. Will not start again.
  • 1,041 Answers
Does it have fire, (spark)?
If so, then: You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Posted on Jun 17, 2009
  • 4 more comments
  • Jim Parker
    Jim Parker Jun 21, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Did this solution solve the problem? Hope so.
    Jim
  • Jim Parker
    Jim
  • Jim Parker
    Did this solve the problem?
    Jim
  • Jim Parker
    SORRY FOR ALL THE POSTS!!!!
    My bad.
    Jim
  • Jim Parker
    Jim Parker Jun 23, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
    Jim
Ran blower with reg gas will it run again or is it junk now
It is likely that you have scored the cylinder and therefore its probably junk. A compression test will tell for sure. 120-140 is ideal. Less than 110 it may run till it gets warm then die. Remove the muffler and look at the cylinder and piston. If you see scoring ( lines running up and down) then it is not cost effective to repair regardless of the compression reading.
Aug 31, 2014 | Sears Craftsman 25cc 2-Cycle Gas...
Poulan Leaf Blower
you may need to turn the Hi screw on the carb in 1/4 of a turn. Make sure the gas and mix are fresh.
Jul 22, 2013 | Poulan Garden
Just turns off on it's own, Wait 60 sec. restart press pedel it dies.
This engine is electronically controlled so the first thing that must be done here is to have the systems control computer tested for fault codes and then do the proper diagnostics based on those codes.
Jun 07, 2012 | 1995 Plymouth Voyager
Homelite model UT21566 string trimmer runs only on full choke and at lower RPM. I have disassembled and cleaned carburetor but that did not fix problem. Steve
Your carb high and low settings may need tweaking if it's not a fuel or muffler issue. I believe needles are made only to be adjusted by a technician. If you want to try adjusting it yourself, google and you tube your to see how.
May 03, 2010 | Homelite Carburetor Trimmer Blower...
My homelite will no longer stay running.
i would start at the muffler & pull it off ,,ck out the exhaust port where u just took the muffler off,,see if it is loaded up with carbon,,need to clean it out,,i find then in the trash,,& take them apart,,and most of the time its just that,,because u are using a gas & oil mix,,try it ,, hoped it helped,,
Apr 15, 2010 | Homelite Consumer Products MightyLite...
RYOBI Expand It 2 stroke engine. RY26000 won't start. Changed spark plug and confirmed the right mixture of oil and gas. I am going to try to start from scratch. Meaning fresh fuel /oil mixture, newer...
I had the same issue. I disassembled carb and cleaned. Started up, but ran poorly. Looked at a few google searches and found a forum about his issue. I came across a write up about failed muffler bearings. I did some research, but to no avail. on part numbers. I went to a repair shop and inquired about how to get a muffler bearing ordered for my unit. It has been about a week since I was at the shop and I did call, but they assure me that they are working on getting this part for me. Apparently these motor parts are made in China and that can create some issues when trying to get parts. I may have to let the repair shop do the repair since I was told it may be a bit complicated to replace without having the experience. If it is as difficult to locate, I would not want to damage it when trying to install and have to get another. I will be glad to repost once it has been repaired. Perhaps this muffler bearing is an issue with a lot of other units and we may be able to contact the manufacturer for a refund or a free muffler bearing? I hope!!! Good luck out there and hang tight. I may be on to something here, I've got a good feeling about this.
Apr 13, 2010 | Ryobi Garden
14hp ohv engine getting very hot,briggs
Sounds like a mice in your muffler. Its stuck, stop using it, you'll be damaging the valve on the motor. Remove it and test it. Try to remove thing in, i know some people put it in the fireplace to turn it red and burn things (like mice) inside and open up things...
Aug 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
152 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
