Question about EliteGroup P6STP-FL Motherboard
Sound driver no sound support i have wand a driver software ofmotherboard no: p6stp-fl at p3 system.
  • 555 Answers
Try this site my friend you can download your audio driver here: http://www.nodevice.com/driver/company/Elitegroup/Motherboard.html Kindly select and find the right audio device you have and hit the donwload text.
thanks
Posted on Jun 17, 2009
How can i set harddisk in motherboard model no. p6stp-fl
The motherboard has IDE hard disks connectors, so use jumpers to set as primary or slave
Jan 22, 2014 | ECS Computers & Internet
Adding discrete graphics card to p6stp-fl
!O_O!
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds. Let go. (HAS to be 10. Count)
Do this same procedure TWO more times.
(IF the Power On LED flashes for a second, keep repeating until it doesn't)
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup parameters back to the factory default settings.
3) FOLLOWING Anti-Static Precautions remove the graphics card.
Plug the monitor back into the Integrated (OnBoard) graphics, of the motherboard. (VGA connector)
4) Plug the computer back into power. WAIT 1 minute, turn the computer on.
5) When Windows has loaded wait a couple of minutes, then take that graphics card's Installation (CD) Disk, and put it in the optical drive.
If the disk doesn't start loading after 10 seconds, go to My Computer, and double-click on the drive letter, next to the optical drive, the Installation Disk is in.
When asked choose all software. Nvidia Control Panel, and drivers.
Your computer will keep on using the Integrated (OnBoard) drivers, for graphics. It will Not use the drivers, and software you are installing now, until the graphics card is physically installed.
Install all software. If you are asked to restart your computer -> NO
Close all windows, go back to your desktop screen.
Turn the computer off normally.
(Start > Turn Off Computer > Turn Off)
6) Unplug from power, follow Anti-Static Precautions.
Unplug the monitor from the motherboard. Physically install the graphics card.
Plug the monitor into the graphics card. Close the computer case.
7) Plug into power. WAIT 1 minute, turn the computer on.
You may have to go into Nvidia Control Panel, and set the correct parameters for your monitor. (Screen Resolution / Color quality )
Clear CMOS Error Codes, and reset BIOS Setup back to factory settings doesn't work?
You get to go back into BIOS Setup, and set the submenu you changed, (Or submenu's), back to the factory standard setting.
(F6?)
You are trying to use the OnBoard graphics drivers for the -> graphics card. This = NO.
You need THE drivers for the graphics card installed F-I-R-S-T.
(OnBoard. ON the motherBOARD.
Used to be used for Integrated Graphics.
Makes it easier to understand if you use OnBoard Graphics )
Why?
When a device, (In this case a graphics adapter card), is installed, Windows 'breaks it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = No.
You need THE drivers already installed. Windows looks to see what device is installed, then finds THE drivers needed.
Regards,
joecoolvette
Sep 13, 2012 | EliteGroup P6STP-FL Motherboard
I want to install audio drivers for p6stp-fl
P6STP-FL Motherboard has CMI8738 PCI 3D Audi. Drivers are available at Elite Group Web Sitehttp://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=9&detailid=106#Download-1
AND
http://driverscollection.com/?file_id=3109
Hope this helps....
Nov 02, 2010 | EliteGroup P6STP-FL Motherboard
Can the cpu be upgraded to BX80526C1000256! If yes what modifications need to be made? Motherboard is EliteGroup P6STP-FL
Hello!
If you want upgrade you CPU, you must first know, specification of motherboard.
If the motherboard can´t see a new CPU, more exactly bios, you can try only one upgrade bios.
I give you a link for a manual and upgrade bios.
When you upgrade bios, try new CPU, if bios again don´t see a CPU, you can´t do anything about that.
Nov 03, 2009 | EliteGroup P6STP-FL Motherboard
No sound on my LG LS50a Laptop
http://download.notebook-driver.com/driver/lg/LS40LS50/SoundMax.zip
Give that a shot.
Sep 29, 2009 | EliteGroup P6STP-FL Motherboard
I need the multimedia audio controller driver
for what board? Do you have the model number
Aug 08, 2009 | EliteGroup P6STP-FL Motherboard
My mother board is p6stp-fl of elite group I want to up grade to 160 gb hdd from 4o gb hdd
Yes you can upgrade it to 160 GIG of hard drive so just simply replace the old one and of coarse you need to install a new operating system to the new drive.....
Jun 16, 2009 | EliteGroup P6STP-FL Motherboard
Sound driver i have no sound driver to my board elite p6stp-fl
You can download the driver for this MOBO from this link http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=106&DetailName=New&DetailDesc=P6STP-FL%20%20(V1.1)&CategoryID=1&MenuID=82&LanID=0
Jun 10, 2009 | EliteGroup P6STP-FL Motherboard
My motherboard turn on but don't display anything
One thing to check is the Power Supply Unit. There is a switch on the back to select the voltage. Make sure it is all the way in the correct position. ie: 115v-230v Another is to clear your BIOS with the jumpers. Make sure you follow those directions and put the jumper on the right pins. One more: if possible, try a different PSU.
Feb 02, 2006 | EliteGroup P6STP-FL Motherboard
EliteGroup P6STP-FL Motherboard Logo
383 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
