Question about Dell W5300N Laser Printer
Paper Jam When I print from tray 2 it paper jams. It seems to not pick up the paper all the way as it doesn't even really jam it just tries to pick up the paper, doesn't and then displays paper jam error 13.01.00 If I keep clearing it a few times then one page will print out but that's it. So for the last 2 weeks I have had to use the auto feed tray 1.  I am not sure if it's the pick up roller that's worn our or a part that's dirty. But I want to make sure if it's a part that needs to be replaced that I replace the right part.
  • 2 more comments
  • HeatherR Nov 01, 2007
    I tried cleaning the roller and that part of the printer with a cloth and alcohol and it definitely helped and now prints! With a slight hitch...it's making a rattling sound that comes from the front right side of the printer (HP 2420d) everytime it's picking up the paper.
    Heather
  • Ukpriceok Apr 09, 2008
    We regularly have paper jams which occur more frequently when the paper tray is low, so we always keep it full up but we still get the jams now and again which include single sheet and multiple sheet jams. We are looking for a solution. Please don't tell us to fan the paper!
  • Anonymous May 03, 2008
    Onlly one page peekup then error 13.01.00 massage sow in control pannel,
    we need to cleen all sencers, refix the cabels and connectors, but probem is same.
  • deb11 Jun 12, 2008
    Rollers are not feeding the paper through correctly, the paper goes down then stops, at times I can push it through till it catches. Any solutions?
    Novelist:
  • 188 Answers
Hi Heather,
It is a common problem with this series of printer ( lexmark t-series, optra series, and the Dell 5200 5300). The pickup rollers are worn and not picking up the paper.
Have you checked with Dell to see if it is under warranty? They are very good about their warranty, especially with Printers.
The Feed rollers are part of the maintenance kit, but can also be purchased seperately.
Since the printer is actually manufactured for Dell by Lexmark, I can give you the Lexmark part number for the feed rollers, which are 100% the same as the feed roller for the Dell printer ( even if you order them from Dell, they are a lexmark part ).
The part number is 40X0070.
If you have any doubt that this is the problem, simply move the rollers from tray 1 to tray 2 and visa versa.
If the rollers are totally worn, then tray 1 will no longer pull paper and tray 2 will.
you may also find that the problem will disappear because tray 1 auto compensator has a little more pressure on the paper then tray 2, and thus extend the life of the rollers for now.
the rollers ARE directional though. when you put them on, make sure that you note the arrow direction printed on the plastic.
The tires rotate clockwise on the right side, and counter clockwise on the left side of the pickup assembly. if this is confusing, just remember the tires push the paper towards the front, so imagin the tire in your hand rotating in the direction that will PUSH the paper forward.
Good luck,
Cory
Posted on Nov 22, 2008
  • 3 Answers
Try cleaning the torque limiter it is located on the paper try behind the feed roller. Remove the feed roller and you will see it behind it. Slide the torque limiter off and take off the end that does not have long part sticking out. Then you would see the metal shaving around it. The torque limier is a magnet so just pinch off some of the metal shavings not all of of them though. And then put everything back together. If that doesn't not work try repalcing the paper feed assembly.
Posted on Jul 02, 2008
  • 1,113 Answers
We need to the model/make to help you
but using some detective skills I've decided you are using a HP machine
Yup Dirty damaged worn feed roller but what model machine is it they are all different but pull out tray 2 cassette all the way and look in, there is probally a cylinder like rubber roller 5cm wide front centre of where cassette slides in, there might be roller on the cassette too at the front center as well.
Most modern printers feed rollers just slide off after lifting small plastic tabs on them and gently pulling, feed rollers are available but you can sometimes also get results by cleaning them with a dash of metho or water on a rag.
If paper feeds 2wo sheets at once then you need to change the seperation pad/roller too.
Posted on Nov 01, 2007
  • Soulvisitor
    Soulvisitor Nov 01, 2007
    Not sure about your rattle, I would ensure rollers are located properly (all the way on shaft) and isolate if noise is present when feeding from tray 1 and also if noise is nothing to do with paper feed but is cart related.
    Replace feed roller if in doubt, could be noisy clutch mech too, hard to identifie without being able to hear it.
    Cheers
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
It is sying i have a paper jam but there is no paper in it
There are two types of paper jams:
1) A jammed piece of paper at or near a sensor. Or a shred of paper is stuck under a sensor.
2) A paper feed operation that does not send paper into the printer will get reported as a jam it the paper does not reach a sensor in the time that is allotted to reach the sensor. The printer knows that the page is late and suspects a jam occurred prior to the sensor.
To determine if there is a “Pick” problem in the tray, place a mark (line or scribble) on the top sheet in the paper tray. Send a print operation to the printer. If a jam is reported, check the tray. If the marked page is still in the tray then you know the paper pick failed.
There are dozens of reasons for paper to fail to pick. The simplest fix to try is to remove the paper and fan it to remove any possible static charge causing the paper to stick together.
Don
Dec 12, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
Paper Jam at 2
Its probably not picking up paper from that tray, thus the jam error. For me that is typically because the tray isn?t pushing the paper up high enough to be caught by the pickup roller or the pickup rubber band is worn.
Feb 02, 2007 | HP Color LaserJet 2600n Printer
Dell W5300N Laser Printer Logo
663 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
