Toshiba Satellite A60 Notebook Logo
A
Anonymous Posted on Apr 08, 2014
The power is on but the screen is not going to password
2answers
I cannot remember my password to get into my tablet
hi John.
i think you will have to do a hard reset to sort this out.
Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
More items...
What do I do if I forgot my password to unlock to my tablet? - Trio ...
https://support.triotablets.com/.../201746559-What-do-I-do-if-I-forgot-my-password-to-...
How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
or before you do anything go to this link and have some more off a read up.
cannot remember my password to get into my tablet Google Search
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
My screen closes after brief pause, goes back to start and password, i lose my work, have to find it again.
pls go to power option and select advance power options. select lid and power button select battery and ac adapter option as hibernate or sleep
details http://www.dummies.com/computers/pcs/how-to-change-what-closing-the-laptop-lid-does/
As sson as i power on my gateway LT2016U the is csreen requests a password. I can get to the the re_boot or system steup menus?
power off laptop........ (this is your laptop you are the Administrator?) yes.....ready power on .... while this is booting up press F2........ you want to get to BIOS screen (note press quickly this has to happen real fast). once the BIOS screen is up use the up/down left/right arrows to navigate....... there are four / five tabs (screens) you are going to disable the password that is on the hard drive.... (on the third or forth screen (tab))... some laptop bios have 4 and other have 5 (4 or 5 being where you can save and exit).... now using the arrows to navi disable all passwords (you can always re-engage) now save and exit, system should re-boot and hopefully bypass the password......... enjoy
5answers
I have a HP Compaq dc5700, and i want to set it to default settings. I do not have any passwords for it. It has windows vista. i tried going to setting(f10) and it asks for a password. I removed the...
Password Security
Establishing a Setup password:
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down >
Restart.
2. As soon as the computer is turned on, press F10 when the monitor light turns green to enter
Computer Setup. Press Enter to bypass the title screen, if necessary. If you do not press F10
when prompted, a restart will be necessary.
3. Select Security > Setup Password and follow the instructions on the screen.
4. Before exiting, click File > Save Changes and Exit.
Restart.
3. Select Security > Power-On Password and follow the instructions on the screen.
Changing a password:
1. Turn on or restart the computer. If you are in Windows, click Start> Shut Down > Restart.
To change the Setup password, go to step 2.
To change the Power-on password, go to step 3.
2. To change the Setup password, as soon as the computer is turned on, press F10 when the
monitor light turns green to enter Computer Setup. Press Enter to bypass the title screen, if
necessary.
3. When the key icon appears, type your current password, a slash (/) or alternate de-limiter
character, your new password, another slash (/) or alternate delimiter character, and your new
password again as shown:
current password/new password/new password.
NOTE: Type the new password carefully since the actual characters do not appear on the
screen.
4. Press ENTER.
The new password will take effect the next time the computer is restarted.
Deleting a password
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down > Restart.
To delete the Setup password, go to step 2.
To delete the Power-On password, go to step 3.
necessary.
3. When the key icon appears, type your current password followed by a slash (/) or alternate
delimiter character as shown. Example: currentpassword/
4. Press Enter.
from
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00794304/c007943
04.pdf
My Toshiba boots up with Black screen with a blue box saying Enter Current Password: in white lettering.
i think its power on password The Power On password is set in the System BIOS options. It prevents unwanted users from accessing the computer. By default, does not set the Power On password. If you set the Power On password in the System BIOS options you will be prompted for it immediately after you power on the Notebook PC
if you dont know the password go for a toshiba serviceing center for solve this
This black screen and blue sign that says enter password i don't know what to do...
It means that your laptop has a BIOS password associated with it powering on and will not go any further until the correct password is given. It will then go on to the boot up screen. IN most cases these passwords can be reset by "shorting" the teo pins on the cmos battery socket and then powering the laptop up. you then place the normal cmos battery plug back in place and reboot the laptop, there should be no more password but the BIOS will have to be reset as far as the correct time and date.
2answers
Forgot password
power yr pc and remove barrty wich is plase on mother board after 2 min re plug battry and restart pc yr password cleared
2answers
Power on password
Hi jrodk777,
If I understand you correctly you get a DOS screen asking for your password. If this is correct, its asking for the BIOS password. Actually your better off with a BIOS password than you are with a windows password, its more secure. When you reboot your going to see a quick screen for entering setup, hit what ever F button they offer for this option. Choose password, erase or leave it blank(this will reset the BIOS password to a default of no password. If you want a BIOS password type it in here save changes and exit and you should be okay. I hope this helps.
Thank you for using FixYa.com
Sincerely, cyyyd7
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
